Vraag acer laptop van mijn vrouw werkt soms erg traag. en regelmatig dat internet via ms edge blijft hangen.
schults2005
Soms wil outlook als het ware niet openen en moet ze pc opniuew opstarte. soms werken outlook en facebook prima, maar wil ze in 3de tabblad naar ingbank of iets anders blijft dat hangen gaat ze terug naar bijv outlook, niets aan de hand met die site.
Heb alvast minitoolbox gedraaid en hieronder de log
Ran by Gebruiker (administrator) on 24-10-2018 at 14:27:47
Running from "C:\Users\Gebruiker\Desktop"
Model: Aspire E1-530 Manufacturer: Acer
Boot Mode: Normal
Windows IP Configuration
Proxy is not enabled.
No Proxy Server is set.
Broadcom NetLink (TM) Gigabit Ethernet = Ethernet (Disconnected)
Qualcomm Atheros AR956x Wireless Network Adapter = Wi-Fi (Connected)
Bluetooth Device (Personal Area Network) = Bluetooth-netwerkverbinding (Media disconnected)
# IPv4 Configuration
pushd interface ipv4
reset
set interface interface="LAN-verbinding* 3" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="LAN-verbinding* 2" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="LAN-verbinding* 4" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="Wi-Fi 2" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="LAN-verbinding* 5" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="LAN-verbinding* 6" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="LAN-verbinding* 7" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="LAN-verbinding* 16" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="Bluetooth-netwerkverbinding" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
popd
# End of IPv4 configuration
Host Name . . . . . . . . . . . . : Acer
Ethernet adapter Ethernet:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Broadcom NetLink (TM) Gigabit Ethernet
Physical Address. . . . . . . . . : 20-1A-06-B3-2A-8A
Wireless LAN adapter LAN-verbinding* 6:
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter #4
Physical Address. . . . . . . . . : 12-F0-2F-2C-AC-1A
Wireless LAN adapter LAN-verbinding* 7:
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter #5
Physical Address. . . . . . . . . : 22-F0-2F-2C-AC-1A
Wireless LAN adapter LAN-verbinding* 16:
Description . . . . . . . . . . . : Microsoft Hosted Network Virtual Adapter #2
Physical Address. . . . . . . . . : 52-F0-2F-2C-AC-1A
Wireless LAN adapter Wi-Fi:
Description . . . . . . . . . . . : Qualcomm Atheros AR956x Wireless Network Adapter
Physical Address. . . . . . . . . : 40-F0-2F-2C-AC-1A
Link-local IPv6 Address . . . . . : fe80::2577:a0c9:972:199c%21(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.11.13(Preferred)
Lease Obtained. . . . . . . . . . : woensdag 24 oktober 2018 10:30:00
Lease Expires . . . . . . . . . . : woensdag 24 oktober 2018 15:12:24
Default Gateway . . . . . . . . . : 192.168.11.1
DHCP Server . . . . . . . . . . . : 192.168.11.1
DHCPv6 IAID . . . . . . . . . . . : 104919087
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-1A-2C-AF-AF-20-1A-06-B3-2A-8A
DNS Servers . . . . . . . . . . . : 62.238.255.69
212.115.192.100
212.115.192.193
Ethernet adapter Bluetooth-netwerkverbinding:
Description . . . . . . . . . . . : Bluetooth Device (Personal Area Network)
Physical Address. . . . . . . . . : 40-F0-2F-2D-09-12
Server: resolver.zeelandnet.nl
Address: 62.238.255.69
Addresses: 2a00:1450:400e:804::200e
172.217.17.142
Pinging google.com [172.217.17.142] with 32 bytes of data:
Reply from 172.217.17.142: bytes=32 time=11ms TTL=57
Reply from 172.217.17.142: bytes=32 time=12ms TTL=57
Ping statistics for 172.217.17.142:
Minimum = 11ms, Maximum = 12ms, Average = 11ms
Addresses: 2001:4998:44:41d::4
2001:4998:58:1836::10
2001:4998:44:41d::3
2001:4998:c:1023::5
2001:4998:c:1023::4
2001:4998:58:1836::11
72.30.35.10
98.137.246.8
98.138.219.232
98.138.219.231
98.137.246.7
72.30.35.9
Pinging yahoo.com [72.30.35.10] with 32 bytes of data:
Reply from 72.30.35.10: bytes=32 time=100ms TTL=54
Reply from 72.30.35.10: bytes=32 time=98ms TTL=54
Ping statistics for 72.30.35.10:
Minimum = 98ms, Maximum = 100ms, Average = 99ms
Interface List
11...20 1a 06 b3 2a 8a ......Broadcom NetLink (TM) Gigabit Ethernet
19...12 f0 2f 2c ac 1a ......Microsoft Wi-Fi Direct Virtual Adapter #4
20...22 f0 2f 2c ac 1a ......Microsoft Wi-Fi Direct Virtual Adapter #5
10...52 f0 2f 2c ac 1a ......Microsoft Hosted Network Virtual Adapter #2
21...40 f0 2f 2c ac 1a ......Qualcomm Atheros AR956x Wireless Network Adapter
3...40 f0 2f 2d 09 12 ......Bluetooth Device (Personal Area Network)
IPv4 Route Table
Active Routes:
0.0.0.0 0.0.0.0 192.168.11.1 192.168.11.13 55
192.168.11.0 255.255.255.0 On-link 192.168.11.13 311
192.168.11.13 255.255.255.255 On-link 192.168.11.13 311
192.168.11.255 255.255.255.255 On-link 192.168.11.13 311
224.0.0.0 240.0.0.0 On-link 192.168.11.13 311
255.255.255.255 255.255.255.255 On-link 192.168.11.13 311
Persistent Routes:
None
IPv6 Route Table
Active Routes:
1 331 ::1/128 On-link
21 311 fe80::/64 On-link
21 311 fe80::2577:a0c9:972:199c/128
On-link
1 331 ff00::/8 On-link
21 311 ff00::/8 On-link
Persistent Routes:
None
Catalog5 02 C:\WINDOWS\SysWOW64\pnrpnsp.dll [70656] (Microsoft Corporation)
Catalog5 03 C:\WINDOWS\SysWOW64\pnrpnsp.dll [70656] (Microsoft Corporation)
Catalog5 04 C:\WINDOWS\SysWOW64\NLAapi.dll [64000] (Microsoft Corporation)
Catalog5 05 C:\WINDOWS\SysWOW64\mswsock.dll [341920] (Microsoft Corporation)
Catalog5 06 C:\WINDOWS\SysWOW64\winrnr.dll [24064] (Microsoft Corporation)
Catalog5 07 C:\WINDOWS\SysWOW64\wshbth.dll [51712] (Microsoft Corporation)
Catalog9 01 C:\WINDOWS\SysWOW64\mswsock.dll [341920] (Microsoft Corporation)
Catalog9 02 C:\WINDOWS\SysWOW64\mswsock.dll [341920] (Microsoft Corporation)
Catalog9 03 C:\WINDOWS\SysWOW64\mswsock.dll [341920] (Microsoft Corporation)
Catalog9 04 C:\WINDOWS\SysWOW64\mswsock.dll [341920] (Microsoft Corporation)
Catalog9 05 C:\WINDOWS\SysWOW64\mswsock.dll [341920] (Microsoft Corporation)
Catalog9 06 C:\WINDOWS\SysWOW64\mswsock.dll [341920] (Microsoft Corporation)
Catalog9 07 C:\WINDOWS\SysWOW64\mswsock.dll [341920] (Microsoft Corporation)
Catalog9 08 C:\WINDOWS\SysWOW64\mswsock.dll [341920] (Microsoft Corporation)
Catalog9 09 C:\WINDOWS\SysWOW64\mswsock.dll [341920] (Microsoft Corporation)
Catalog9 10 C:\WINDOWS\SysWOW64\mswsock.dll [341920] (Microsoft Corporation)
Catalog9 11 C:\WINDOWS\SysWOW64\mswsock.dll [341920] (Microsoft Corporation)
Catalog9 12 C:\WINDOWS\SysWOW64\mswsock.dll [341920] (Microsoft Corporation)
Catalog9 13 C:\WINDOWS\SysWOW64\mswsock.dll [341920] (Microsoft Corporation)
Catalog9 14 C:\WINDOWS\SysWOW64\mswsock.dll [341920] (Microsoft Corporation)
x64-Catalog5 01 C:\Windows\System32\napinsp.dll [67072] (Microsoft Corporation)
x64-Catalog5 02 C:\Windows\System32\pnrpnsp.dll [84992] (Microsoft Corporation)
x64-Catalog5 03 C:\Windows\System32\pnrpnsp.dll [84992] (Microsoft Corporation)
x64-Catalog5 04 C:\Windows\System32\NLAapi.dll [80896] (Microsoft Corporation)
x64-Catalog5 05 C:\Windows\System32\mswsock.dll [401968] (Microsoft Corporation)
x64-Catalog5 07 C:\Windows\System32\wshbth.dll [63488] (Microsoft Corporation)
x64-Catalog9 01 C:\Windows\System32\mswsock.dll [401968] (Microsoft Corporation)
x64-Catalog9 02 C:\Windows\System32\mswsock.dll [401968] (Microsoft Corporation)
x64-Catalog9 03 C:\Windows\System32\mswsock.dll [401968] (Microsoft Corporation)
x64-Catalog9 04 C:\Windows\System32\mswsock.dll [401968] (Microsoft Corporation)
x64-Catalog9 05 C:\Windows\System32\mswsock.dll [401968] (Microsoft Corporation)
x64-Catalog9 06 C:\Windows\System32\mswsock.dll [401968] (Microsoft Corporation)
x64-Catalog9 07 C:\Windows\System32\mswsock.dll [401968] (Microsoft Corporation)
x64-Catalog9 08 C:\Windows\System32\mswsock.dll [401968] (Microsoft Corporation)
x64-Catalog9 09 C:\Windows\System32\mswsock.dll [401968] (Microsoft Corporation)
x64-Catalog9 10 C:\Windows\System32\mswsock.dll [401968] (Microsoft Corporation)
x64-Catalog9 11 C:\Windows\System32\mswsock.dll [401968] (Microsoft Corporation)
x64-Catalog9 12 C:\Windows\System32\mswsock.dll [401968] (Microsoft Corporation)
x64-Catalog9 13 C:\Windows\System32\mswsock.dll [401968] (Microsoft Corporation)
x64-Catalog9 14 C:\Windows\System32\mswsock.dll [401968] (Microsoft Corporation)
Application errors:
Error: (10/24/2018 12:44:07 PM) (Source: Microsoft-Windows-SpellChecker) (User: ACER)
Description: brave hendrikbrave hendrik-2147467263
Error: (10/24/2018 12:18:09 PM) (Source: Application Error) (User: )
Description: Naam van toepassing met fout: svchost.exe_WpnUserService, versie: 10.0.17134.1, tijdstempel: 0xa38b9ab2
Naam van module met fout: NotificationController.dll, versie: 10.0.17134.165, tijdstempel: 0xe0385185
Uitzonderingscode: 0xc0000005
Foutmarge: 0x000000000007a24d
Id van proces met fout: 0x1f8c
Starttijd van toepassing met fout: 0xsvchost.exe_WpnUserService0
Pad naar toepassing met fout: svchost.exe_WpnUserService1
Pad naar module met fout: svchost.exe_WpnUserService2
Rapport-id: svchost.exe_WpnUserService3
Volledige pakketnaam met fout: svchost.exe_WpnUserService4
Relatieve toepassings-id van pakket met fout: svchost.exe_WpnUserService5
Error: (10/24/2018 11:33:10 AM) (Source: Application Error) (User: )
Id van proces met fout: 0x3128
Error: (10/24/2018 11:02:00 AM) (Source: Application Error) (User: )
Foutmarge: 0x000000000007c686
Id van proces met fout: 0x1c08
Error: (10/24/2018 10:37:19 AM) (Source: Microsoft-Windows-SpellChecker) (User: ACER)
Error: (10/23/2018 11:09:11 PM) (Source: Application Error) (User: )
Description: Naam van toepassing met fout: ctfmon.exe, versie: 10.0.17134.1, tijdstempel: 0x0ac88d37
Naam van module met fout: InputLocaleManager.dll, versie: 10.0.17134.319, tijdstempel: 0xa2066dc6
Uitzonderingscode: 0x00000675
Foutmarge: 0x0000000000007055
Id van proces met fout: 0x29b8
Starttijd van toepassing met fout: 0xctfmon.exe0
Pad naar toepassing met fout: ctfmon.exe1
Pad naar module met fout: ctfmon.exe2
Rapport-id: ctfmon.exe3
Volledige pakketnaam met fout: ctfmon.exe4
Relatieve toepassings-id van pakket met fout: ctfmon.exe5
Error: (10/23/2018 11:09:03 PM) (Source: Application Error) (User: )
Id van proces met fout: 0x1d94
Error: (10/23/2018 08:17:18 PM) (Source: Microsoft-Windows-SpellChecker) (User: ACER)
Error: (10/23/2018 07:33:59 PM) (Source: Microsoft-Windows-SpellChecker) (User: ACER)
Error: (10/23/2018 04:21:10 PM) (Source: Application Error) (User: )
Id van proces met fout: 0x144c
System errors:
Error: (10/24/2018 02:18:07 PM) (Source: DCOM) (User: NT AUTHORITY)
Description: toepassingsspecifiekLokaalActiveren{D63B10C5-BB46-4990-A94F-E40B9D520160}{9CA88EE3-ACB7-47C8-AFC4-AB702511C276}NT AUTHORITYLOCAL SERVICES-1-5-19LocalHost (via LRPC)Niet beschikbaarNiet beschikbaar
Error: (10/24/2018 02:15:47 PM) (Source: DCOM) (User: NT AUTHORITY)
Error: (10/24/2018 02:13:02 PM) (Source: DCOM) (User: ACER)
Description: toepassingsspecifiekLokaalActiveren{D63B10C5-BB46-4990-A94F-E40B9D520160}{9CA88EE3-ACB7-47C8-AFC4-AB702511C276}AcerGebruikerS-1-5-21-1014441568-1594974271-3246346139-1001LocalHost (via LRPC)Niet beschikbaarNiet beschikbaar
Error: (10/24/2018 12:24:13 PM) (Source: DCOM) (User: ACER)
Description: "C:\WINDOWS\system32\backgroundTaskHost.exe" -ServerName:App.AppXr6cxj2m7qt53ysmsgy75gtey09djqa6k.mca0Microsoft.WebMediaExtensions_1.0.12341.0_x64__8wekyb3d8bbwe!App.AppX5mvjzgfkp7zwcj41y2acxgs5c976dxda.mcaNiet beschikbaarNiet beschikbaar
Error: (10/24/2018 12:24:12 PM) (Source: DCOM) (User: ACER)
Microsoft Office Sessions:
Error: (10/24/2018 12:44:07 PM) (Source: Microsoft-Windows-SpellChecker)(User: ACER)
Error: (10/24/2018 12:18:09 PM) (Source: Application Error)(User: )
Description: svchost.exe_WpnUserService10.0.17134.1a38b9ab2NotificationController.dll10.0.17134.165e0385185c0000005000000000007a24d1f8c01d46b7ca01ac741C:\WINDOWS\system32\svchost.exeC:\Windows\System32\NotificationController.dll470b1242-3316-47d4-b899-cadaf16f4b31
Error: (10/24/2018 11:33:10 AM) (Source: Application Error)(User: )
Description: svchost.exe_WpnUserService10.0.17134.1a38b9ab2NotificationController.dll10.0.17134.165e0385185c0000005000000000007a24d312801d46b7870eb74f2C:\WINDOWS\system32\svchost.exeC:\Windows\System32\NotificationController.dlla472f7ff-81aa-4b95-80b6-0d10f45ecd9f
Error: (10/24/2018 11:02:00 AM) (Source: Application Error)(User: )
Description: svchost.exe_WpnUserService10.0.17134.1a38b9ab2NotificationController.dll10.0.17134.165e0385185c0000005000000000007c6861c0801d46b74cdf24a72C:\WINDOWS\system32\svchost.exeC:\Windows\System32\NotificationController.dll53e9419d-c246-43a1-8de3-f3159ff42b27
Error: (10/24/2018 10:37:19 AM) (Source: Microsoft-Windows-SpellChecker)(User: ACER)
Error: (10/23/2018 11:09:11 PM) (Source: Application Error)(User: )
Description: ctfmon.exe10.0.17134.10ac88d37InputLocaleManager.dll10.0.17134.319a2066dc600000675000000000000705529b801d46b1492c5326eC:\WINDOWS\system32\ctfmon.exeC:\WINDOWS\system32\InputLocaleManager.dlla34054aa-276a-44fa-8995-4c1815db14f8
Error: (10/23/2018 11:09:03 PM) (Source: Application Error)(User: )
Description: svchost.exe_WpnUserService10.0.17134.1a38b9ab2NotificationController.dll10.0.17134.165e0385185c0000005000000000007c6861d9401d46b11c3b94d7eC:\WINDOWS\system32\svchost.exeC:\Windows\System32\NotificationController.dllfe04a054-77c9-4184-9040-ffbdc826d8c8
Error: (10/23/2018 08:17:18 PM) (Source: Microsoft-Windows-SpellChecker)(User: ACER)
Error: (10/23/2018 07:33:59 PM) (Source: Microsoft-Windows-SpellChecker)(User: ACER)
Error: (10/23/2018 04:21:10 PM) (Source: Application Error)(User: )
Description: svchost.exe_WpnUserService10.0.17134.1a38b9ab2NotificationController.dll10.0.17134.165e0385185c0000005000000000007c686144c01d46ad94b33a9b3C:\WINDOWS\system32\svchost.exeC:\Windows\System32\NotificationController.dll62de6f07-d01d-4ec5-8edc-39311a266a71
CodeIntegrity Errors:
Date: 2018-10-23 16:29:39.670
Description: Code Integrity determined that a process (\Device\HarddiskVolume4\Program Files\AVAST Software\Avast\wsc_proxy.exe) attempted to load \Device\HarddiskVolume4\Program Files\AVAST Software\Avast\dbghelp.dll that did not meet the Custom 3 / Antimalware signing level requirements.
Date: 2018-10-23 16:28:39.063
Date: 2018-10-23 16:28:33.014
Date: 2018-10-23 11:53:04.644
Date: 2018-10-23 07:27:32.234
Date: 2018-10-22 23:33:34.888
Date: 2018-10-22 23:32:24.082
Date: 2018-10-22 23:32:22.912
Date: 2018-10-22 23:30:52.259
Date: 2018-10-22 23:00:45.853
Acer Docs (HKLM-x32\...\{CA4FE8B0-298C-4E5D-A486-F33B126D6A0A}) (Version: 1.01.3006 - Acer Incorporated)
Acer Games (HKCU\...\Pokki_03d432a7e610c3e908213e7689d4342ce2111caf) (Version: 1.1.9.43466 - Pokki)
Acer Launch Manager (HKLM\...\{C18D55BD-1EC6-466D-B763-8EEDDDA9100E}) (Version: 8.00.8101 - Acer Incorporated)
Acer Media (HKLM-x32\...\{E9AF1707-3F3A-49E2-8345-4F2D629D0876}) (Version: 2.02.3104.3 - Acer Incorporated)
Acer Photo (HKLM-x32\...\{B5AD89F2-03D3-4206-8487-018298007DD0}) (Version: 2.02.3104.6 - Acer Incorporated)
Acer Power Management (HKLM\...\{91F52DE4-B789-42B0-9311-A349F10E5479}) (Version: 7.00.8100 - Acer Incorporated)
Acer Quick Access (HKLM\...\{C1FA525F-D701-4B31-9D32-504FC0CF0B98}) (Version: 1.00.3000 - Acer Incorporated)
Acer Recovery Management (HKLM\...\{07F2005A-8CAC-4A4B-83A2-DA98A722CA61}) (Version: 6.00.8100 - Acer Incorporated)
Acer Remote Files (HKLM\...\{13885028-098C-4799-9B71-27DAC96502D5}) (Version: 1.00.3007 - Acer Incorporated)
Adobe Acrobat Reader DC - Nederlands (HKLM-x32\...\{AC76BA86-7AD7-1043-7B44-AC0F074E4100}) (Version: 19.008.20080 - Adobe Systems Incorporated)
Adobe Flash Player 18 NPAPI (HKLM-x32\...\Adobe Flash Player NPAPI) (Version: 18.0.0.160 - Adobe Systems Incorporated)
Avast Free Antivirus (HKLM-x32\...\Avast Antivirus) (Version: 18.7.2354 - AVAST Software)
Avast Update Helper (HKLM-x32\...\{A92DAB39-4E2C-4304-9AB6-BC44E68B55E2}) (Version: 1.4.136.333 - AVAST Software) Hidden
Broadcom Card Reader Driver Installer (HKLM\...\{67AA948F-8D83-4566-B84A-7CAABCF64E3F}) (Version: 16.0.2.8 - Broadcom Corporation)
Broadcom NetLink Controller (HKLM\...\{D1D7ED66-5C08-40A0-AEC0-B6DF977697BB}) (Version: 16.2.1.2 - Broadcom Corporation)
CCleaner (HKLM\...\CCleaner) (Version: 5.42 - Piriform)
Corel Paint Shop Pro Photo XI (HKLM-x32\...\{E1C7EF5E-3A7B-4ED4-A48B-F70F1B36EAB4}) (Version: 11.00.0000 - Corel Inc)
Corel Painter Essentials 3 (HKLM-x32\...\{0C180787-F8C8-42FD-A9D3-689BA44BEAAF}) (Version: 3.0 - Corel Corporation)
Corel Snapfire (HKLM-x32\...\{0EE4030A-8FD4-4798-A21D-17E525B1F7CF}) (Version: 1.00.0000 - Uw bedrijfsnaam)
CyberLink PowerDVD 12 (HKLM-x32\...\InstallShield_{B46BEA36-0B71-4A4E-AE41-87241643FA0A}) (Version: 12.0.3126.57 - CyberLink Corp.)
D3DX10 (HKLM-x32\...\{E09C4DB7-630C-4F06-A631-8EA7239923AF}) (Version: 15.4.2368.0902 - Microsoft) Hidden
eBay Worldwide (HKLM-x32\...\{91589413-6675-4C27-8AFC-EFB9103B90A5}) (Version: 2.4.0105 - OEM)
ELAN Touchpad 11.15.0.18_X64 (HKLM\...\Elantech) (Version: 11.15.0.18 - ELAN Microelectronic Corp.)
Facebook (HKCU\...\Pokki_a65116cdc0b4377bed428e280c19949d56248d11) (Version: 1.1.4 - SweetLabs)
Google Chrome (HKLM-x32\...\Google Chrome) (Version: 69.0.3497.100 - Google Inc.)
Google Toolbar for Internet Explorer (HKLM-x32\...\{18455581-E099-4BA8-BC6B-F34B2F06600C}) (Version: 1.0.0 - Google Inc.) Hidden
Google Update Helper (HKLM-x32\...\{60EC980A-BDA2-4CB6-A427-B07A5498B4CA}) (Version: 1.3.33.17 - Google Inc.) Hidden
Host App Service (HKCU\...\SweetLabs_AP) (Version: 0.269.8.414 - Pokki)
Identity Card (HKLM-x32\...\{3D9CB654-99AD-4301-89C6-0D12A790767C}) (Version: 2.00.8100 - Acer Incorporated)
inSSIDer Home (HKLM-x32\...\{9E54E4AE-B67A-4925-8E92-0E1F9817FD73}) (Version: 3.1.2.1 - MetaGeek, LLC)
Intel(R) Management Engine Components (HKLM-x32\...\{65153EA5-8B6E-43B6-857B-C6E4FC25798A}) (Version: 9.5.14.1724 - Intel Corporation)
Intel(R) Processor Graphics (HKLM-x32\...\{F0E3AD40-2BBD-4360-9C76-B9AC9A5886EA}) (Version: 10.18.10.4276 - Intel Corporation)
Junk Mail filter update (HKLM-x32\...\{0BE9E708-5DC0-4963-9CFD-0AA519090E79}) (Version: 16.4.3528.0331 - Microsoft Corporation) Hidden
Kobo (HKLM-x32\...\Kobo) (Version: 4.0.5579 - Rakuten Kobo Inc.)
Live Updater (HKLM-x32\...\{EE26E302-876A-48D9-9058-3129E5B99999}) (Version: 2.00.8102 - Acer Incorporated)
Microsoft Office 2000 Premium (HKLM-x32\...\{00000413-78E1-11D2-B60F-006097C998E7}) (Version: 9.00.2720 - Microsoft Corporation)
Microsoft OneDrive (HKCU\...\OneDriveSetup.exe) (Version: 18.172.0826.0010 - Microsoft Corporation)
Microsoft Visual C++ 2005 Redistributable (HKLM-x32\...\{A49F249F-0C91-497F-86DF-B2585E8E76B7}) (Version: 8.0.50727.42 - Microsoft Corporation)
Microsoft Visual C++ 2008 Redistributable - x64 9.0.30729.17 (HKLM\...\{8220EEFE-38CD-377E-8595-13398D740ACE}) (Version: 9.0.30729 - Microsoft Corporation)
Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.4148 (HKLM-x32\...\{1F1C2DFC-2D24-3E06-BCB8-725134ADF989}) (Version: 9.0.30729.4148 - Microsoft Corporation)
Microsoft Visual C++ 2015 Redistributable (x64) - 14.0.24212 (HKLM-x32\...\{323dad84-0974-4d90-a1c1-e006c7fdbb7d}) (Version: 14.0.24212.0 - Microsoft Corporation)
Microsoft Visual C++ 2015 Redistributable (x86) - 14.0.24212 (HKLM-x32\...\{462f63a8-6347-4894-a1b3-dbfe3a4c981d}) (Version: 14.0.24212.0 - Microsoft Corporation)
Nero BackItUp 12 Essentials OEM.a01 (HKLM-x32\...\{551AC8F2-FEA2-4B45-ACF7-C98681233CC9}) (Version: 12.5.01200 - Nero AG)
Office Addin (HKLM-x32\...\{6D2BBE1D-E600-4695-BA37-0B0E605542CC}) (Version: 2.02.2009 - Acer)
PaintShop Photo Pro X3 Registration Incentive (HKLM-x32\...\{3DA41E54-9526-40C0-8456-66B09379DFCC}) (Version: 1.00.0000 - Uw bedrijfsnaam) Hidden
Prerequisite installer (HKLM-x32\...\{3AAB08A3-F129-4BD5-B409-AE674F93759D}) (Version: 12.0.0003 - Nero AG) Hidden
Qualcomm Atheros Bluetooth Suite (64) (HKLM\...\{A84A4FB1-D703-48DB-89E0-68B6499D2801}) (Version: 8.0.1.305 - Qualcomm Atheros Communications)
Qualcomm Atheros WLAN and Bluetooth Client Installation Program (HKLM-x32\...\{28006915-2739-4EBE-B5E8-49B25D32EB33}) (Version: 12.07 - Qualcomm Atheros)
QuickTime (HKLM-x32\...\{8DC42D05-680B-41B0-8878-6C14D24602DB}) (Version: 7.55.90.70 - Apple Inc.)
Realtek High Definition Audio Driver (HKLM-x32\...\{F132AF7F-7BCA-4EDE-8A7C-958108FE7DBC}) (Version: 6.0.1.7027 - Realtek Semiconductor Corp.)
Silhouette Link (HKLM-x32\...\{C2136C80-F9D4-4096-86D4-C641BB36DFF3}) (Version: 1.0.096 - Silhouette America)
Silhouette Studio (HKLM-x32\...\{40EFBD87-9DDB-412B-A93E-D582790AD500}) (Version: 4.1.468 - Silhouette America)
Visual Studio 2005 Tools for Office Second Edition Runtime (HKLM-x32\...\Microsoft Visual Studio 2005 Tools for Office Runtime) (Version: - Microsoft Corporation)
Visual Studio Tools for the Office system 3.0 Runtime (HKLM-x32\...\Visual Studio Tools for the Office system 3.0 Runtime) (Version: - Microsoft Corporation)
Visual Studio Tools for the Office system 3.0 Runtime Service Pack 1 (KB949258) (HKLM-x32\...\{8FB53850-246A-3507-8ADE-0060093FFEA6}.KB949258) (Version: 1 - Microsoft Corporation)
Windows Live Essentials (HKLM-x32\...\WinLiveSuite) (Version: 16.4.3528.0331 - Microsoft Corporation)
Windows Media Encoder 9 Series (HKLM-x32\...\Windows Media Encoder 9) (Version: - )
Percentage of memory in use: 36%
Total physical RAM: 3985.27 MB
Available physical RAM: 2515.16 MB
Total Virtual: 6929.27 MB
Available Virtual: 4629.01 MB
1 Drive c: (Acer) (Fixed) (Total:447.79 GB) (Free:339.54 GB) NTFS
Gebruikersaccounts voor \\ACER
Gebruiker WDAGUtilityAccount
De opdracht is voltooid.
No minidump file found
**** End of log ****
schults2005
schults2005
#2
Anvulling
MBAM vind niets aan malware.
Zag in andere posts dat ook FRST gedraaid mag worden.
Hier log frst zet addition in vlg reply
Scanresultaten van Farbar Recovery Scan Tool (FRST) (x64) Versie: 10.10.2018
Gestart door Gebruiker (Beheerder) op ACER (24-10-2018 15:08:53)
Gestart vanaf C:\Users\Gebruiker\Desktop
Geladen Profielen: Gebruiker & Administrator (Beschikbare Profielen: Gebruiker & Administrator)
Platform: Windows 10 Home Versie 1803 17134.345 (X64) Taal: Nederlands (Nederland)
Internet Explorer Versie 11 (Standaardbrowser: Edge)
Boot Modus: Normal
Handleiding voor Farbar Recovery Scan Tool: http://www.geekstogo.com/forum/topic/335081-frst-tutorial-how-to-use-farbar-recovery-scan-tool/
==================== Processen (gefilterd) =================
(Als een item is opgenomen in de fixlist, zal het proces worden gesloten. Het bestand zal niet worden verplaatst.)
(Intel Corporation) C:\Windows\System32\igfxCUIService.exe
(AVAST Software) C:\Program Files\AVAST Software\Avast\AvastSvc.exe
(Microsoft Corporation) C:\Windows\Microsoft.NET\Framework64\v3.0\WPF\PresentationFontCache.exe
(ELAN Microelectronics Corp.) C:\Program Files\Elantech\ETDService.exe
(Intel(R) Corporation) C:\Program Files\Intel\iCLS Client\HeciServer.exe
(Acer Incorporate) C:\Program Files\Acer\Acer Launch Manager\LMSvc.exe
() C:\Program Files (x86)\Silhouette America\Silhouette Link\Resources\Resources\SPEC_LK\SilhouetteLinkServer.32.exe
(Intel Corporation) C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL\jhi_service.exe
(Intel Corporation) C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\LMS\LMS.exe
(Nero AG) C:\Program Files (x86)\Nero\Update\NASvc.exe
(AVAST Software) C:\Program Files\AVAST Software\Avast\AvastUI.exe
(ELAN Microelectronics Corp.) C:\Program Files\Elantech\ETDCtrl.exe
(ELAN Microelectronics Corp.) C:\Program Files\Elantech\ETDCtrlHelper.exe
(Intel Corporation) C:\Windows\System32\igfxEM.exe
(Intel Corporation) C:\Windows\System32\igfxHK.exe
(Intel Corporation) C:\Windows\System32\igfxTray.exe
(Microsoft Corporation) C:\Windows\System32\dllhost.exe
(Microsoft Corporation) C:\Windows\SystemApps\Microsoft.LockApp_cw5n1h2txyewy\LockApp.exe
(Microsoft Corporation) C:\Program Files\Windows Defender\MSASCuiL.exe
(Realtek Semiconductor) C:\Program Files\Realtek\Audio\HDA\RAVCpl64.exe
(Piriform Ltd) C:\Program Files\CCleaner\CCleaner64.exe
() C:\Program Files\WindowsApps\Microsoft.Windows.Photos_2018.18081.14710.0_x64__8wekyb3d8bbwe\Microsoft.Photos.exe
(Microsoft Corporation) C:\Windows\System32\smartscreen.exe
(Microsoft Corporation) C:\Windows\SystemApps\Microsoft.MicrosoftEdge_8wekyb3d8bbwe\MicrosoftEdge.exe
(Microsoft Corporation) C:\Windows\System32\browser_broker.exe
(Microsoft Corporation) C:\Windows\SystemApps\Microsoft.MicrosoftEdge_8wekyb3d8bbwe\MicrosoftEdgeCP.exe
(Pokki) C:\Users\Gebruiker\AppData\Local\SweetLabs App Platform\Engine\ServiceHostApp.exe
(Pokki) C:\Users\Gebruiker\AppData\Local\SweetLabs App Platform\Engine\ServiceHostAppUpdater.exe
(Malwarebytes) C:\Program Files\Malwarebytes\Anti-Malware\MBAMService.exe
(Malwarebytes) C:\Program Files\Malwarebytes\Anti-Malware\mbamtray.exe
Kon geen toegang krijgen tot proces -> mbamtray.exe
(Microsoft Corporation) C:\Windows\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.17134.281_none_eada712a1d8142be\TiWorker.exe
==================== Register (gefilterd) ===========================
(Als een item is opgenomen in de fixlist, zal het registeritem worden teruggezet naar de standaardwaarden of verwijderd. Het bestand zal niet worden verplaatst.)
HKLM\...\Run: [SecurityHealth] => C:\Program Files\Windows Defender\MSASCuiL.exe [638872 2018-04-12] (Microsoft Corporation)
HKLM\...\Run: [ETDCtrl] => C:\Program Files\Elantech\ETDCtrl.exe [3242696 2015-10-07] (ELAN Microelectronics Corp.)
HKLM\...\Run: [RTHDVCPL] => C:\Program Files\Realtek\Audio\HDA\RAVCpl64.exe [13647576 2013-08-27] (Realtek Semiconductor)
HKLM\...\Run: [Corel Photo Downloader] => C:\Program Files (x86)\Corel\Corel Snapfire\Corel Photo Downloader.exe [462336 2006-08-04] (Corel, Inc.)
HKLM\...\Run: [AvastUI.exe] => C:\Program Files\AVAST Software\Avast\AvLaunch.exe [242392 2018-10-22] (AVAST Software)
HKLM-x32\...\Run: [QuickTime Task] => C:\Program Files (x86)\QuickTime\QTTask.exe [413696 2008-09-06] (Apple Inc.)
HKLM Group Policy restriction on software: %systemroot%\system32\mrt.exe <==== AANDACHT
HKLM\...\Policies\Explorer\Run: [BtvStack] => C:\Program Files (x86)\Qualcomm Atheros\Bluetooth Suite\BtvStack.exe
HKU\S-1-5-19\...\RunOnce: [WAB Migrate] => C:\Program Files\Windows Mail\wab.exe [518144 2018-04-12] (Microsoft Corporation)
HKU\S-1-5-20\...\RunOnce: [WAB Migrate] => C:\Program Files\Windows Mail\wab.exe [518144 2018-04-12] (Microsoft Corporation)
HKU\S-1-5-21-1014441568-1594974271-3246346139-1001\...\Run: [CCleaner Monitoring] => C:\Program Files\CCleaner\CCleaner64.exe [18334528 2018-04-12] (Piriform Ltd)
HKU\S-1-5-21-1014441568-1594974271-3246346139-500\...\RunOnce: [WAB Migrate] => C:\Program Files\Windows Mail\wab.exe [518144 2018-04-12] (Microsoft Corporation)
Startup: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\Microsoft Office.lnk [2015-03-20]
ShortcutTarget: Microsoft Office.lnk -> C:\Program Files (x86)\Microsoft Office\Office\OSA9.EXE (Microsoft Corporation)
==================== Internet (gefilterd) ====================
(Als een item is opgenomen in de fixlist en een registeritem is, wordt het verwijderd of hersteld naar de standaard.)
Tcpip\Parameters: [DhcpNameServer] 62.238.255.69 212.115.192.100 212.115.192.193
Tcpip\..\Interfaces\{6872b6f3-6680-43c2-b59c-ad621d06a36c}: [DhcpNameServer] 150.200.3.2
Tcpip\..\Interfaces\{c5bcfde8-1796-4ea9-99f3-bb164a7851e1}: [DhcpNameServer] 62.238.255.69 212.115.192.100 212.115.192.193
Internet Explorer:
HKU\S-1-5-21-1014441568-1594974271-3246346139-1001\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = hxxp://acer13.msn.com/?pc=ACJB
HKU\S-1-5-21-1014441568-1594974271-3246346139-500\Software\Microsoft\Internet Explorer\Main,Start Page = hxxp://acer13.msn.com/?pc=ACJB
HKU\S-1-5-21-1014441568-1594974271-3246346139-500\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = hxxp://acer13.msn.com/?pc=ACJB
SearchScopes: HKLM -> {AA9A4890-4262-4441-8977-E2FFCBFB706C} URL = hxxp://nl.yhs4.search.yahoo.com/yhs/search?hspart=acer&hsimp=yhs-acer_001&p={searchTerms}
SearchScopes: HKLM-x32 -> {AA9A4890-4262-4441-8977-E2FFCBFB706C} URL = hxxp://nl.yhs4.search.yahoo.com/yhs/search?hspart=acer&hsimp=yhs-acer_001&p={searchTerms}
SearchScopes: HKU\S-1-5-21-1014441568-1594974271-3246346139-1001 -> DefaultScope {9D5C3D52-6D64-478F-BB1B-395671A86269} URL =
SearchScopes: HKU\S-1-5-21-1014441568-1594974271-3246346139-1001 -> {9D5C3D52-6D64-478F-BB1B-395671A86269} URL =
SearchScopes: HKU\S-1-5-21-1014441568-1594974271-3246346139-1001 -> {AA9A4890-4262-4441-8977-E2FFCBFB706C} URL = hxxp://nl.yhs4.search.yahoo.com/yhs/search?hspart=acer&hsimp=yhs-acer_001&p={searchTerms}
Toolbar: HKU\S-1-5-21-1014441568-1594974271-3246346139-1001 -> Geen Naam - {2318C2B1-4965-11D4-9B18-009027A5CD4F} - Geen bestand
DPF: HKLM-x32 {1ABA5FAC-1417-422B-BA82-45C35E2C908B} hxxp://kitchenplanner.ikea.com/nl/Core/Player/2020PlayerAX_IKEA_Win32.cab
FireFox:
FF HKLM\...\Firefox\Extensions: [{4ED1F68A-5463-4931-9384-8FFF5ED91D92}] - C:\Program Files (x86)\McAfee\SiteAdvisor\saffplg.xpi => niet gevonden
FF HKLM-x32\...\Firefox\Extensions: [{4ED1F68A-5463-4931-9384-8FFF5ED91D92}] - C:\Program Files (x86)\McAfee\SiteAdvisor\saffplg.xpi => niet gevonden
FF HKLM-x32\...\Thunderbird\Extensions: [msktbird@mcafee.com] - C:\Program Files\McAfee\MSK => niet gevonden
FF Plugin: @adobe.com/FlashPlayer -> C:\WINDOWS\system32\Macromed\Flash\NPSWF64_18_0_0_160.dll [2016-04-19] ()
FF Plugin: @mcafee.com/MSC,version=10 -> C:\Program Files\mcafee\msc\npMcSnFFPl64.dll [Geen bestand]
FF Plugin-x32: @adobe.com/FlashPlayer -> C:\WINDOWS\SysWOW64\Macromed\Flash\NPSWF32_18_0_0_160.dll [2016-04-19] ()
FF Plugin-x32: @intel-webapi.intel.com/Intel WebAPI ipt;version=4.0.5 -> C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\IPT\npIntelWebAPIIPT.dll [2013-09-04] (Intel Corporation)
FF Plugin-x32: @intel-webapi.intel.com/Intel WebAPI updater -> C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\IPT\npIntelWebAPIUpdater.dll [2013-09-04] (Intel Corporation)
FF Plugin-x32: @mcafee.com/MSC,version=10 -> C:\Program Files (x86)\McAfee\msc\npMcSnFFPl.dll [Geen bestand]
FF Plugin-x32: @tools.google.com/Google Update;version=3 -> C:\Program Files (x86)\Google\Update\1.3.33.17\npGoogleUpdate3.dll [2018-05-19] (Google Inc.)
FF Plugin-x32: @tools.google.com/Google Update;version=9 -> C:\Program Files (x86)\Google\Update\1.3.33.17\npGoogleUpdate3.dll [2018-05-19] (Google Inc.)
FF Plugin-x32: Adobe Reader -> C:\Program Files (x86)\Adobe\Acrobat Reader DC\Reader\AIR\nppdf32.dll [2018-09-20] (Adobe Systems Inc.)
Chrome:
CHR DefaultProfile: Default
CHR HomePage: Default -> hxxps://homepage-web.com/?s=acer&m=home
CHR StartupUrls: Default -> "hxxps://homepage-web.com/?s=acer&m=start"
CHR DefaultSearchURL: Default -> hxxps://secure.homepage-web.com/?partner=acer&src=omnibox&q={searchTerms}
CHR DefaultSearchKeyword: Default -> homepage-web.com
CHR DefaultSuggestURL: Default -> hxxps://secure-suggest.homepage-web.com/suggest?format=json&locale={language}&q={searchTerms}
CHR Profile: C:\Users\Gebruiker\AppData\Local\Google\Chrome\User Data\Default [2018-10-24]
CHR Extension: (Presentaties) - C:\Users\Gebruiker\AppData\Local\Google\Chrome\User Data\Default\Extensions\aapocclcgogkmnckokdopfmhonfmgoek [2018-02-06]
CHR Extension: (Documenten) - C:\Users\Gebruiker\AppData\Local\Google\Chrome\User Data\Default\Extensions\aohghmighlieiainnegkcijnfilokake [2018-01-29]
CHR Extension: (Google Drive) - C:\Users\Gebruiker\AppData\Local\Google\Chrome\User Data\Default\Extensions\apdfllckaahabafndbhieahigkjlhalf [2015-11-24]
CHR Extension: (YouTube) - C:\Users\Gebruiker\AppData\Local\Google\Chrome\User Data\Default\Extensions\blpcfgokakmgnkcojhhkbfbldkacnbeo [2015-11-24]
CHR Extension: (Google Search) - C:\Users\Gebruiker\AppData\Local\Google\Chrome\User Data\Default\Extensions\coobgpohoikkiipiblmjeljniedjpjpf [2015-12-18]
CHR Extension: (Avast SafePrice) - C:\Users\Gebruiker\AppData\Local\Google\Chrome\User Data\Default\Extensions\eofcbnmajmjmplflapaojjnihcjkigck [2018-04-29]
CHR Extension: (Spreadsheets) - C:\Users\Gebruiker\AppData\Local\Google\Chrome\User Data\Default\Extensions\felcaaldnbdncclmgdcncolpebgiejap [2018-01-29]
CHR Extension: (McAfee® WebAdvisor) - C:\Users\Gebruiker\AppData\Local\Google\Chrome\User Data\Default\Extensions\fheoggkfdfchfphceeifdbepaooicaho [2018-04-29]
CHR Extension: (Offline Documenten) - C:\Users\Gebruiker\AppData\Local\Google\Chrome\User Data\Default\Extensions\ghbmnnjooekpmoecnnnilnnbdlolhkhi [2018-08-20]
CHR Extension: (Avast Online Security) - C:\Users\Gebruiker\AppData\Local\Google\Chrome\User Data\Default\Extensions\gomekmidlodglbbmalcneegieacbdmki [2018-08-20]
CHR Extension: (Betalingen via Chrome Web Store) - C:\Users\Gebruiker\AppData\Local\Google\Chrome\User Data\Default\Extensions\nmmhkkegccagdldgiimedpiccmgmieda [2018-08-20]
CHR Extension: (Gmail) - C:\Users\Gebruiker\AppData\Local\Google\Chrome\User Data\Default\Extensions\pjkljhegncpnkpknbcohdijeoejaedia [2015-03-30]
CHR Extension: (Chrome Media Router) - C:\Users\Gebruiker\AppData\Local\Google\Chrome\User Data\Default\Extensions\pkedcjkdefgpdelpbcmbmeomcjbeemfm [2018-08-20]
CHR HKLM\...\Chrome\Extension: [fheoggkfdfchfphceeifdbepaooicaho] - C:\Program Files (x86)\McAfee\SiteAdvisor\McChPlg.crx <niet gevonden>
CHR HKLM-x32\...\Chrome\Extension: [eofcbnmajmjmplflapaojjnihcjkigck] - C:\Program Files\AVAST Software\Avast\WebRep\Chrome\aswWebRepChromeSp.crx <niet gevonden>
CHR HKLM-x32\...\Chrome\Extension: [fheoggkfdfchfphceeifdbepaooicaho] - C:\Program Files (x86)\McAfee\SiteAdvisor\McChPlg.crx <niet gevonden>
CHR HKLM-x32\...\Chrome\Extension: [gomekmidlodglbbmalcneegieacbdmki] - C:\Program Files\AVAST Software\Avast\WebRep\Chrome\aswWebRepChrome.crx <niet gevonden>
==================== Services (gefilterd) ====================
(Als een item is opgenomen in de fixlist, wordt het uit het register verwijderd. Het bestand zal niet worden verplaatst tenzij apart vermeld.)
S3 aswbIDSAgent; C:\Program Files\AVAST Software\Avast\x64\aswidsagenta.exe [8188768 2018-10-22] (AVAST Software)
R2 avast! Antivirus; C:\Program Files\AVAST Software\Avast\AvastSvc.exe [325024 2018-10-22] (AVAST Software)
S3 AvastWscReporter; C:\Program Files\AVAST Software\Avast\wsc_proxy.exe [57504 2018-10-22] (AVAST Software)
S3 ePowerSvc; C:\Program Files\Acer\Acer Power Management\ePowerSvc.exe [663592 2013-07-06] (Acer Incorporated)
R2 ETDService; C:\Program Files\Elantech\ETDService.exe [144072 2015-10-07] (ELAN Microelectronics Corp.)
R2 igfxCUIService1.0.0.0; C:\WINDOWS\system32\igfxCUIService.exe [337888 2016-05-03] (Intel Corporation)
R2 Intel(R) Capability Licensing Service Interface; C:\Program Files\Intel\iCLS Client\HeciServer.exe [733696 2013-05-12] (Intel(R) Corporation) [Bestand niet getekend]
S3 Intel(R) Capability Licensing Service TCP IP Interface; C:\Program Files\Intel\iCLS Client\SocketHeciServer.exe [822232 2013-05-12] (Intel(R) Corporation)
R2 jhi_service; C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL\jhi_service.exe [169432 2013-09-04] (Intel Corporation)
R2 LMSvc; C:\Program Files\Acer\Acer Launch Manager\LMSvc.exe [457768 2013-08-03] (Acer Incorporate)
R2 MBAMService; C:\Program Files\Malwarebytes\Anti-Malware\mbamservice.exe [6347056 2018-09-19] (Malwarebytes)
S3 QASvc; C:\Program Files\Acer\Acer Quick Access\QASvc.exe [457768 2013-08-03] (Acer Incorporate)
R2 SilhouetteLink; C:\Program Files (x86)\Silhouette America\Silhouette Link\Resources\Resources\SPEC_LK\SilhouetteLinkServer.32.exe [897200 2016-12-06] ()
S4 ssh-agent; C:\WINDOWS\System32\OpenSSH\ssh-agent.exe [495616 2018-03-10] ()
S3 WdNisSvc; C:\ProgramData\Microsoft\Windows Defender\platform\4.18.1809.2-0\NisSrv.exe [3847376 2018-09-29] (Microsoft Corporation)
S3 WinDefend; C:\ProgramData\Microsoft\Windows Defender\platform\4.18.1809.2-0\MsMpEng.exe [114200 2018-09-29] (Microsoft Corporation)
S2 avast; "C:\Program Files (x86)\AVAST Software\Browser\Update\AvastBrowserUpdate.exe" /svc [X]
S3 avastm; "C:\Program Files (x86)\AVAST Software\Browser\Update\AvastBrowserUpdate.exe" /medsvc [X]
===================== Drivers (gefilterd) ======================
R1 aswArPot; C:\WINDOWS\System32\drivers\aswArPot.sys [201408 2018-10-22] (AVAST Software)
R1 aswbidsdriver; C:\WINDOWS\System32\drivers\aswbidsdrivera.sys [230512 2018-10-22] (AVAST Software)
R0 aswbidsh; C:\WINDOWS\System32\drivers\aswbidsha.sys [201928 2018-10-22] (AVAST Software)
R0 aswblog; C:\WINDOWS\System32\drivers\aswbloga.sys [346760 2018-10-22] (AVAST Software)
R0 aswbuniv; C:\WINDOWS\System32\drivers\aswbuniva.sys [59664 2018-10-22] (AVAST Software)
R0 aswElam; C:\WINDOWS\System32\drivers\aswElam.sys [15360 2018-06-24] (AVAST Software)
R1 aswHdsKe; C:\WINDOWS\System32\drivers\aswHdsKe.sys [185240 2018-10-22] (AVAST Software)
S3 aswHwid; C:\WINDOWS\System32\drivers\aswHwid.sys [47064 2018-10-22] (AVAST Software)
R1 aswKbd; C:\WINDOWS\System32\drivers\aswKbd.sys [42456 2018-10-22] (AVAST Software)
R2 aswMonFlt; C:\WINDOWS\System32\drivers\aswMonFlt.sys [163376 2018-10-22] (AVAST Software)
R1 aswRdr; C:\WINDOWS\System32\drivers\aswRdr2.sys [111968 2018-10-22] (AVAST Software)
R0 aswRvrt; C:\WINDOWS\System32\drivers\aswRvrt.sys [88112 2018-10-22] (AVAST Software)
R1 aswSnx; C:\WINDOWS\System32\drivers\aswSnx.sys [1028840 2018-10-22] (AVAST Software)
R1 aswSP; C:\WINDOWS\System32\drivers\aswSP.sys [467904 2018-10-22] (AVAST Software)
S2 aswStm; C:\WINDOWS\System32\drivers\aswStm.sys [208640 2018-10-22] (AVAST Software)
R0 aswVmm; C:\WINDOWS\System32\drivers\aswVmm.sys [381144 2018-10-22] (AVAST Software)
R1 ESProtectionDriver; C:\WINDOWS\system32\drivers\mbae64.sys [152688 2018-09-11] (Malwarebytes)
R3 LMDriver; C:\WINDOWS\System32\drivers\LMDriver.sys [31000 2018-05-15] (Acer Incorporated)
R2 MBAMChameleon; C:\WINDOWS\System32\Drivers\MbamChameleon.sys [200232 2018-10-24] (Malwarebytes)
R3 MBAMFarflt; C:\WINDOWS\System32\DRIVERS\farflt.sys [118584 2018-10-24] (Malwarebytes)
R3 MBAMProtection; C:\WINDOWS\system32\DRIVERS\mbam.sys [58400 2018-10-24] (Malwarebytes)
R3 MBAMSwissArmy; C:\WINDOWS\System32\Drivers\mbamswissarmy.sys [260384 2018-10-24] (Malwarebytes)
R3 MBAMWebProtection; C:\WINDOWS\system32\DRIVERS\mwac.sys [110424 2018-10-24] (Malwarebytes)
R3 MEIx64; C:\WINDOWS\system32\DRIVERS\TeeDriverx64.sys [99288 2013-09-04] (Intel Corporation)
R3 RadioShim; C:\WINDOWS\System32\drivers\RadioShim.sys [25368 2018-05-15] (Acer Incorporated)
S3 WdBoot; C:\WINDOWS\system32\drivers\wd\WdBoot.sys [46184 2018-09-29] (Microsoft Corporation)
S3 WdFilter; C:\WINDOWS\system32\drivers\wd\WdFilter.sys [352424 2018-09-29] (Microsoft Corporation)
S3 WdNisDrv; C:\WINDOWS\System32\drivers\wd\WdNisDrv.sys [60584 2018-09-29] (Microsoft Corporation)
==================== NetSvcs (gefilterd) ===================
==================== Een Maand Aangemaakt bestanden en mappen ========
(Als een item is opgenomen in de fixlist, word de map of het bestand verplaatst.)
2018-10-24 15:08 - 2018-10-24 15:09 - 000018318 _____ C:\Users\Gebruiker\Desktop\FRST.txt
2018-10-24 14:54 - 2018-10-24 14:54 - 080793256 _____ (Malwarebytes ) C:\Users\Gebruiker\Desktop\mb3-setup-consumer-3.6.1.2711-1.0.463-1.0.7485.exe
2018-10-24 14:52 - 2018-10-24 14:52 - 000000000 ____D C:\Users\Gebruiker\AppData\Local\mbamtray
2018-10-24 14:51 - 2018-10-24 14:55 - 000110424 _____ (Malwarebytes) C:\WINDOWS\system32\Drivers\mwac.sys
2018-10-24 14:51 - 2018-10-24 14:51 - 000260384 _____ (Malwarebytes) C:\WINDOWS\system32\Drivers\mbamswissarmy.sys
2018-10-24 14:51 - 2018-10-24 14:51 - 000200232 _____ (Malwarebytes) C:\WINDOWS\system32\Drivers\MbamChameleon.sys
2018-10-24 14:51 - 2018-10-24 14:51 - 000118584 _____ (Malwarebytes) C:\WINDOWS\system32\Drivers\farflt.sys
2018-10-24 14:51 - 2018-10-24 14:51 - 000058400 _____ (Malwarebytes) C:\WINDOWS\system32\Drivers\mbam.sys
2018-10-24 14:50 - 2018-10-24 14:50 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Malwarebytes
2018-10-24 14:50 - 2018-10-24 14:50 - 000000000 ____D C:\ProgramData\Malwarebytes
2018-10-24 14:50 - 2018-10-24 14:50 - 000000000 ____D C:\Program Files\Malwarebytes
2018-10-24 14:50 - 2018-09-11 13:18 - 000152688 _____ (Malwarebytes) C:\WINDOWS\system32\Drivers\mbae64.sys
2018-10-24 14:37 - 2018-10-24 15:08 - 000000000 ____D C:\FRST
2018-10-24 14:27 - 2018-10-24 14:28 - 000036360 _____ C:\Users\Gebruiker\Desktop\MTB.txt
2018-10-24 14:26 - 2018-10-24 14:26 - 002414592 _____ (Farbar) C:\Users\Gebruiker\Desktop\FRST64.exe
2018-10-24 14:25 - 2018-10-24 14:25 - 000892416 _____ (Farbar) C:\Users\Gebruiker\Desktop\MiniToolBox.exe
2018-10-23 16:28 - 2018-10-23 16:28 - 000000000 ___HD C:\OneDriveTemp
2018-10-22 23:38 - 2018-10-22 23:37 - 000042456 _____ (AVAST Software) C:\WINDOWS\system32\Drivers\aswKbd.sys
2018-10-22 23:37 - 2018-10-22 23:37 - 000378584 _____ (AVAST Software) C:\WINDOWS\system32\aswBoot.exe
2018-10-19 10:07 - 2018-10-19 10:07 - 008986280 _____ C:\Users\Gebruiker\Downloads\Sofilantjes-Sylva-Onesie-Coloring-Pages.pdf
2018-10-19 10:06 - 2018-10-19 10:06 - 000458480 _____ C:\Users\Gebruiker\Downloads\Sofilantjes-Sylva-Onesie-Romper-Pattern-Pieces-A4-and-Letter-size.pdf
2018-10-19 10:05 - 2018-10-19 10:05 - 009383564 _____ C:\Users\Gebruiker\Downloads\Sofilantjes-Sylva-Onesie-instructies-NL.pdf
2018-10-19 09:41 - 2018-10-19 09:41 - 004758959 _____ C:\Users\Gebruiker\Downloads\Nadinchen Reloaded Anleitung (1).pdf
2018-10-19 09:40 - 2018-10-19 09:40 - 002107030 _____ C:\Users\Gebruiker\Downloads\Nadinchen Schnitt (1).pdf
2018-10-09 20:50 - 2018-09-21 11:18 - 021386888 _____ (Microsoft Corporation) C:\WINDOWS\system32\shell32.dll
2018-10-09 20:50 - 2018-09-21 05:41 - 003396096 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppXDeploymentServer.dll
2018-10-09 20:50 - 2018-09-20 11:23 - 006602240 _____ (Microsoft Corporation) C:\WINDOWS\system32\twinui.dll
2018-10-09 20:50 - 2018-09-20 10:34 - 012500992 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\wmp.dll
2018-10-09 20:50 - 2018-09-20 06:29 - 006569856 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Media.Protection.PlayReady.dll
2018-10-09 20:50 - 2018-09-20 06:29 - 006039368 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\windows.storage.dll
2018-10-09 20:50 - 2018-09-20 06:21 - 022013440 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\edgehtml.dll
2018-10-09 20:50 - 2018-09-20 06:15 - 019404288 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mshtml.dll
2018-10-09 20:50 - 2018-09-20 06:11 - 005777920 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Chakra.dll
2018-10-09 20:50 - 2018-09-20 06:09 - 009089848 _____ (Microsoft Corporation) C:\WINDOWS\system32\ntoskrnl.exe
2018-10-09 20:50 - 2018-09-20 06:09 - 007520096 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Media.Protection.PlayReady.dll
2018-10-09 20:50 - 2018-09-20 06:09 - 007432136 _____ (Microsoft Corporation) C:\WINDOWS\system32\windows.storage.dll
2018-10-09 20:50 - 2018-09-20 06:08 - 004191232 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\wininet.dll
2018-10-09 20:50 - 2018-09-20 05:53 - 025851392 _____ (Microsoft Corporation) C:\WINDOWS\system32\edgehtml.dll
2018-10-09 20:50 - 2018-09-20 05:46 - 022715392 _____ (Microsoft Corporation) C:\WINDOWS\system32\mshtml.dll
2018-10-09 20:50 - 2018-09-20 05:44 - 008188928 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Data.Pdf.dll
2018-10-09 20:50 - 2018-09-20 05:44 - 004383744 _____ (Microsoft Corporation) C:\WINDOWS\system32\EdgeContent.dll
2018-10-09 20:50 - 2018-09-20 05:42 - 004866560 _____ (Microsoft Corporation) C:\WINDOWS\system32\jscript9.dll
2018-10-09 20:50 - 2018-09-20 05:41 - 007577088 _____ (Microsoft Corporation) C:\WINDOWS\system32\Chakra.dll
2018-10-09 20:50 - 2018-09-20 05:37 - 004615680 _____ (Microsoft Corporation) C:\WINDOWS\system32\wininet.dll
2018-10-09 20:50 - 2018-09-08 10:07 - 001610552 _____ (Microsoft Corporation) C:\WINDOWS\system32\appraiser.dll
2018-10-09 20:50 - 2018-09-08 09:38 - 001288192 _____ (Microsoft Corporation) C:\WINDOWS\system32\SystemSettings.Handlers.dll
2018-10-09 20:50 - 2018-09-08 05:44 - 001980984 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\KernelBase.dll
2018-10-09 20:50 - 2018-09-08 05:30 - 003601920 _____ (Microsoft Corporation) C:\WINDOWS\system32\Microsoft.Bluetooth.Service.dll
2018-10-09 20:50 - 2018-09-08 05:29 - 004771840 _____ (Microsoft Corporation) C:\WINDOWS\system32\InputService.dll
2018-10-09 20:50 - 2018-09-08 05:27 - 003348992 _____ (Microsoft Corporation) C:\WINDOWS\system32\msftedit.dll
2018-10-09 20:50 - 2018-09-08 05:25 - 003553792 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\InputService.dll
2018-10-09 20:50 - 2018-09-08 05:24 - 001457664 _____ (Microsoft Corporation) C:\WINDOWS\system32\dosvc.dll
2018-10-09 20:49 - 2018-09-21 11:01 - 000171520 _____ (Microsoft Corporation) C:\WINDOWS\system32\itss.dll
2018-10-09 20:49 - 2018-09-21 10:22 - 020381784 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\shell32.dll
2018-10-09 20:49 - 2018-09-21 10:12 - 000150016 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\itss.dll
2018-10-09 20:49 - 2018-09-21 06:14 - 000661056 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\evr.dll
2018-10-09 20:49 - 2018-09-21 06:13 - 000480568 _____ (Microsoft Corporation) C:\WINDOWS\system32\dcntel.dll
2018-10-09 20:49 - 2018-09-21 06:12 - 001035256 _____ (Microsoft Corporation) C:\WINDOWS\system32\ApplyTrustOffline.exe
2018-10-09 20:49 - 2018-09-21 06:11 - 000753056 _____ (Microsoft Corporation) C:\WINDOWS\system32\evr.dll
2018-10-09 20:49 - 2018-09-21 06:09 - 004790160 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mfcore.dll
2018-10-09 20:49 - 2018-09-21 06:09 - 002253696 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\iertutil.dll
2018-10-09 20:49 - 2018-09-21 06:09 - 001427968 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\AppxPackaging.dll
2018-10-09 20:49 - 2018-09-21 06:09 - 001062920 _____ (Microsoft Corporation) C:\WINDOWS\system32\SecConfig.efi
2018-10-09 20:49 - 2018-09-21 06:09 - 000129088 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mfps.dll
2018-10-09 20:49 - 2018-09-21 06:08 - 004404720 _____ (Microsoft Corporation) C:\WINDOWS\system32\mfcore.dll
2018-10-09 20:49 - 2018-09-21 06:08 - 002765344 _____ (Microsoft Corporation) C:\WINDOWS\system32\iertutil.dll
2018-10-09 20:49 - 2018-09-21 06:08 - 001566720 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppxPackaging.dll
2018-10-09 20:49 - 2018-09-21 06:08 - 001456720 _____ (Microsoft Corporation) C:\WINDOWS\system32\winload.efi
2018-10-09 20:49 - 2018-09-21 06:08 - 001257864 _____ (Microsoft Corporation) C:\WINDOWS\system32\winload.exe
2018-10-09 20:49 - 2018-09-21 06:08 - 001140672 _____ (Microsoft Corporation) C:\WINDOWS\system32\winresume.efi
2018-10-09 20:49 - 2018-09-21 06:08 - 000982600 _____ (Microsoft Corporation) C:\WINDOWS\system32\winresume.exe
2018-10-09 20:49 - 2018-09-21 06:08 - 000709936 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\cng.sys
2018-10-09 20:49 - 2018-09-21 06:08 - 000261008 _____ (Microsoft Corporation) C:\WINDOWS\system32\mfps.dll
2018-10-09 20:49 - 2018-09-21 06:08 - 000170808 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\ksecpkg.sys
2018-10-09 20:49 - 2018-09-21 06:07 - 000604664 _____ (Microsoft Corporation) C:\WINDOWS\system32\securekernel.exe
2018-10-09 20:49 - 2018-09-21 05:58 - 005307392 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\d2d1.dll
2018-10-09 20:49 - 2018-09-21 05:57 - 002900992 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\dwmcore.dll
2018-10-09 20:49 - 2018-09-21 05:57 - 001361408 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\MSPhotography.dll
2018-10-09 20:49 - 2018-09-21 05:56 - 000331264 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\edgeIso.dll
2018-10-09 20:49 - 2018-09-21 05:54 - 000251904 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msIso.dll
2018-10-09 20:49 - 2018-09-21 05:53 - 001006080 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\wpnapps.dll
2018-10-09 20:49 - 2018-09-21 05:43 - 001627136 _____ (Microsoft Corporation) C:\WINDOWS\system32\enterprisecsps.dll
2018-10-09 20:49 - 2018-09-21 05:42 - 000209408 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppXApplicabilityBlob.dll
2018-10-09 20:49 - 2018-09-21 05:40 - 002368000 _____ (Microsoft Corporation) C:\WINDOWS\system32\WebRuntimeManager.dll
2018-10-09 20:49 - 2018-09-21 05:39 - 003320320 _____ (Microsoft Corporation) C:\WINDOWS\system32\dwmcore.dll
2018-10-09 20:49 - 2018-09-21 05:39 - 001708544 _____ (Microsoft Corporation) C:\WINDOWS\system32\MSPhotography.dll
2018-10-09 20:49 - 2018-09-21 05:39 - 001535488 _____ (Microsoft Corporation) C:\WINDOWS\system32\lsasrv.dll
2018-10-09 20:49 - 2018-09-21 05:39 - 000625152 _____ (Microsoft Corporation) C:\WINDOWS\system32\PsmServiceExtHost.dll
2018-10-09 20:49 - 2018-09-21 05:38 - 002172928 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppXDeploymentExtensions.onecore.dll
2018-10-09 20:49 - 2018-09-21 05:38 - 001551360 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppXDeploymentExtensions.desktop.dll
2018-10-09 20:49 - 2018-09-21 05:37 - 002904064 _____ (Microsoft Corporation) C:\WINDOWS\system32\wuaueng.dll
2018-10-09 20:49 - 2018-09-21 05:37 - 002236928 _____ (Microsoft Corporation) C:\WINDOWS\system32\win32kbase.sys
2018-10-09 20:49 - 2018-09-21 05:37 - 001211904 _____ (Microsoft Corporation) C:\WINDOWS\system32\wpnapps.dll
2018-10-09 20:49 - 2018-09-21 05:37 - 000604160 _____ (Microsoft Corporation) C:\WINDOWS\system32\updatehandlers.dll
2018-10-09 20:49 - 2018-09-21 05:36 - 001159680 _____ (Microsoft Corporation) C:\WINDOWS\system32\rpcss.dll
2018-10-09 20:49 - 2018-09-21 05:36 - 001034240 _____ (Microsoft Corporation) C:\WINDOWS\system32\modernexecserver.dll
2018-10-09 20:49 - 2018-09-21 05:36 - 000932352 _____ (Microsoft Corporation) C:\WINDOWS\system32\rasmans.dll
2018-10-09 20:49 - 2018-09-21 05:36 - 000505344 _____ (Microsoft Corporation) C:\WINDOWS\system32\edgeIso.dll
2018-10-09 20:49 - 2018-09-21 05:36 - 000401920 _____ (Microsoft Corporation) C:\WINDOWS\system32\rascustom.dll
2018-10-09 20:49 - 2018-09-20 11:40 - 000348160 _____ (Microsoft Corporation) C:\WINDOWS\system32\MusNotifyIcon.exe
2018-10-09 20:49 - 2018-09-20 11:37 - 001634944 _____ (Microsoft Corporation) C:\WINDOWS\system32\gdi32full.dll
2018-10-09 20:49 - 2018-09-20 11:22 - 013572096 _____ (Microsoft Corporation) C:\WINDOWS\system32\wmp.dll
2018-10-09 20:49 - 2018-09-20 11:19 - 001121792 _____ (Microsoft Corporation) C:\WINDOWS\system32\TSWorkspace.dll
2018-10-09 20:49 - 2018-09-20 11:18 - 003649024 _____ (Microsoft Corporation) C:\WINDOWS\system32\win32kfull.sys
2018-10-09 20:49 - 2018-09-20 11:18 - 000392192 _____ (Microsoft Corporation) C:\WINDOWS\system32\iedkcs32.dll
2018-10-09 20:49 - 2018-09-20 11:17 - 002874368 _____ (Microsoft Corporation) C:\WINDOWS\system32\themeui.dll
2018-10-09 20:49 - 2018-09-20 11:17 - 001856000 _____ (Microsoft Corporation) C:\WINDOWS\system32\msxml3.dll
2018-10-09 20:49 - 2018-09-20 11:17 - 001364992 _____ (Microsoft Corporation) C:\WINDOWS\system32\bcastdvruserservice.dll
2018-10-09 20:49 - 2018-09-20 11:16 - 000127488 _____ (Microsoft Corporation) C:\WINDOWS\system32\wmpshell.dll
2018-10-09 20:49 - 2018-09-20 10:46 - 001454440 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\gdi32full.dll
2018-10-09 20:49 - 2018-09-20 10:35 - 005669888 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\twinui.dll
2018-10-09 20:49 - 2018-09-20 10:30 - 000344576 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\iedkcs32.dll
2018-10-09 20:49 - 2018-09-20 10:29 - 002891776 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\win32kfull.sys
2018-10-09 20:49 - 2018-09-20 10:29 - 002824704 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\themeui.dll
2018-10-09 20:49 - 2018-09-20 10:29 - 001586176 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msxml3.dll
2018-10-09 20:49 - 2018-09-20 10:28 - 000102400 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\wmpshell.dll
2018-10-09 20:49 - 2018-09-20 08:43 - 001008640 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Media.MixedRealityCapture.dll
2018-10-09 20:49 - 2018-09-20 07:52 - 000868864 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Media.MixedRealityCapture.dll
2018-10-09 20:49 - 2018-09-20 06:29 - 001989232 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msxml6.dll
2018-10-09 20:49 - 2018-09-20 06:29 - 001513032 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\WindowsCodecs.dll
2018-10-09 20:49 - 2018-09-20 06:29 - 000357056 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\bcryptprimitives.dll
2018-10-09 20:49 - 2018-09-20 06:28 - 001129544 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msvproc.dll
2018-10-09 20:49 - 2018-09-20 06:28 - 000581792 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\MSVideoDSP.dll
2018-10-09 20:49 - 2018-09-20 06:28 - 000567256 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\CoreMessaging.dll
2018-10-09 20:49 - 2018-09-20 06:17 - 006661632 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Data.Pdf.dll
2018-10-09 20:49 - 2018-09-20 06:13 - 003711488 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\jscript9.dll
2018-10-09 20:49 - 2018-09-20 06:12 - 000272200 _____ (Microsoft Corporation) C:\WINDOWS\system32\SgrmEnclave.dll
2018-10-09 20:49 - 2018-09-20 06:12 - 000269128 _____ (Microsoft Corporation) C:\WINDOWS\system32\SgrmEnclave_secure.dll
2018-10-09 20:49 - 2018-09-20 06:11 - 000608768 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\EdgeManager.dll
2018-10-09 20:49 - 2018-09-20 06:11 - 000578560 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\webplatstorageserver.dll
2018-10-09 20:49 - 2018-09-20 06:11 - 000561152 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\jscript9diag.dll
2018-10-09 20:49 - 2018-09-20 06:11 - 000074240 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\dtdump.exe
2018-10-09 20:49 - 2018-09-20 06:10 - 002719032 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\tcpip.sys
2018-10-09 20:49 - 2018-09-20 06:10 - 001221128 _____ (Microsoft Corporation) C:\WINDOWS\system32\hvix64.exe
2018-10-09 20:49 - 2018-09-20 06:10 - 001029432 _____ (Microsoft Corporation) C:\WINDOWS\system32\hvax64.exe
2018-10-09 20:49 - 2018-09-20 06:10 - 000566800 _____ (Microsoft Corporation) C:\WINDOWS\system32\tcblaunch.exe
2018-10-09 20:49 - 2018-09-20 06:10 - 000500536 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\mrxsmb.sys
2018-10-09 20:49 - 2018-09-20 06:10 - 000355840 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\PhotoMetadataHandler.dll
2018-10-09 20:49 - 2018-09-20 06:10 - 000134968 _____ (Microsoft Corporation) C:\WINDOWS\system32\hvloader.dll
2018-10-09 20:49 - 2018-09-20 06:10 - 000076088 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\hvservice.sys
2018-10-09 20:49 - 2018-09-20 06:09 - 002825232 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\dxgkrnl.sys
2018-10-09 20:49 - 2018-09-20 06:09 - 002462888 _____ (Microsoft Corporation) C:\WINDOWS\system32\msxml6.dll
2018-10-09 20:49 - 2018-09-20 06:09 - 002421248 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\ntfs.sys
2018-10-09 20:49 - 2018-09-20 06:09 - 001767096 _____ (Microsoft Corporation) C:\WINDOWS\system32\WindowsCodecs.dll
2018-10-09 20:49 - 2018-09-20 06:09 - 001540096 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\rdpserverbase.dll
2018-10-09 20:49 - 2018-09-20 06:09 - 001097744 _____ (Microsoft Corporation) C:\WINDOWS\system32\msvproc.dll
2018-10-09 20:49 - 2018-09-20 06:09 - 000885952 _____ (Microsoft Corporation) C:\WINDOWS\system32\CoreMessaging.dll
2018-10-09 20:49 - 2018-09-20 06:09 - 000793088 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\dxgmms2.sys
2018-10-09 20:49 - 2018-09-20 06:09 - 000713472 _____ (Microsoft Corporation) C:\WINDOWS\system32\MSVideoDSP.dll
2018-10-09 20:49 - 2018-09-20 06:09 - 000412984 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\dxgmms1.sys
2018-10-09 20:49 - 2018-09-20 06:08 - 001627648 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\urlmon.dll
2018-10-09 20:49 - 2018-09-20 05:43 - 000052736 _____ C:\WINDOWS\system32\runexehelper.exe
2018-10-09 20:49 - 2018-09-20 05:42 - 000433664 _____ (Microsoft Corporation) C:\WINDOWS\system32\MusNotification.exe
2018-10-09 20:49 - 2018-09-20 05:42 - 000099328 _____ (Microsoft Corporation) C:\WINDOWS\system32\utcutil.dll
2018-10-09 20:49 - 2018-09-20 05:41 - 000898560 _____ (Microsoft Corporation) C:\WINDOWS\system32\MusUpdateHandlers.dll
2018-10-09 20:49 - 2018-09-20 05:41 - 000894464 _____ (Microsoft Corporation) C:\WINDOWS\system32\webplatstorageserver.dll
2018-10-09 20:49 - 2018-09-20 05:41 - 000319488 _____ (Microsoft Corporation) C:\WINDOWS\system32\MusNotificationUx.exe
2018-10-09 20:49 - 2018-09-20 05:41 - 000154112 _____ (Microsoft Corporation) C:\WINDOWS\system32\Chakradiag.dll
2018-10-09 20:49 - 2018-09-20 05:40 - 003090432 _____ (Microsoft Corporation) C:\WINDOWS\system32\diagtrack.dll
2018-10-09 20:49 - 2018-09-20 05:40 - 000808448 _____ (Microsoft Corporation) C:\WINDOWS\system32\EdgeManager.dll
2018-10-09 20:49 - 2018-09-20 05:40 - 000726528 _____ (Microsoft Corporation) C:\WINDOWS\system32\jscript9diag.dll
2018-10-09 20:49 - 2018-09-20 05:38 - 001724416 _____ (Microsoft Corporation) C:\WINDOWS\system32\rdpserverbase.dll
2018-10-09 20:49 - 2018-09-20 05:38 - 000433664 _____ (Microsoft Corporation) C:\WINDOWS\system32\PhotoMetadataHandler.dll
2018-10-09 20:49 - 2018-09-20 05:37 - 001804288 _____ (Microsoft Corporation) C:\WINDOWS\system32\urlmon.dll
2018-10-09 20:49 - 2018-09-20 05:36 - 001375232 _____ (Microsoft Corporation) C:\WINDOWS\system32\usocore.dll
2018-10-09 20:49 - 2018-09-20 04:21 - 000001312 _____ C:\WINDOWS\system32\tcbres.wim
2018-10-09 20:49 - 2018-09-20 03:28 - 000343552 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msrd3x40.dll
2018-10-09 20:49 - 2018-09-08 10:12 - 000452112 _____ (Microsoft Corporation) C:\WINDOWS\system32\invagent.dll
2018-10-09 20:49 - 2018-09-08 10:07 - 002868536 _____ (Microsoft Corporation) C:\WINDOWS\system32\aitstatic.exe
2018-10-09 20:49 - 2018-09-08 10:07 - 000792376 _____ (Microsoft Corporation) C:\WINDOWS\system32\generaltel.dll
2018-10-09 20:49 - 2018-09-08 10:07 - 000689464 _____ (Microsoft Corporation) C:\WINDOWS\system32\aeinv.dll
2018-10-09 20:49 - 2018-09-08 10:07 - 000612360 _____ (Microsoft Corporation) C:\WINDOWS\system32\devinv.dll
2018-10-09 20:49 - 2018-09-08 10:07 - 000309560 _____ (Microsoft Corporation) C:\WINDOWS\system32\acmigration.dll
2018-10-09 20:49 - 2018-09-08 10:07 - 000144696 _____ (Microsoft Corporation) C:\WINDOWS\system32\CompatTelRunner.exe
2018-10-09 20:49 - 2018-09-08 10:07 - 000069944 _____ (Microsoft Corporation) C:\WINDOWS\system32\win32appinventorycsp.dll
2018-10-09 20:49 - 2018-09-08 10:02 - 000645112 _____ (Microsoft Corporation) C:\WINDOWS\system32\advapi32.dll
2018-10-09 20:49 - 2018-09-08 10:02 - 000540984 _____ (Microsoft Corporation) C:\WINDOWS\system32\pcasvc.dll
2018-10-09 20:49 - 2018-09-08 09:58 - 001639352 _____ (Microsoft Corporation) C:\WINDOWS\system32\user32.dll
2018-10-09 20:49 - 2018-09-08 09:58 - 001520744 _____ (Microsoft Corporation) C:\WINDOWS\system32\msctf.dll
2018-10-09 20:49 - 2018-09-08 09:57 - 000204800 _____ (Microsoft Corporation) C:\WINDOWS\system32\basecsp.dll
2018-10-09 20:49 - 2018-09-08 09:44 - 000068096 _____ (Microsoft Corporation) C:\WINDOWS\system32\fdBth.dll
2018-10-09 20:49 - 2018-09-08 09:43 - 000085504 _____ (Microsoft Corporation) C:\WINDOWS\system32\INETRES.dll
2018-10-09 20:49 - 2018-09-08 09:43 - 000047616 _____ (Microsoft Corporation) C:\WINDOWS\system32\SCardBi.dll
2018-10-09 20:49 - 2018-09-08 09:42 - 000256000 _____ (Microsoft Corporation) C:\WINDOWS\system32\scksp.dll
2018-10-09 20:49 - 2018-09-08 09:42 - 000188928 _____ (Microsoft Corporation) C:\WINDOWS\system32\certprop.dll
2018-10-09 20:49 - 2018-09-08 09:42 - 000169984 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.UI.XamlHost.dll
2018-10-09 20:49 - 2018-09-08 09:42 - 000114176 _____ (Microsoft Corporation) C:\WINDOWS\system32\bthci.dll
2018-10-09 20:49 - 2018-09-08 09:41 - 000258560 _____ (Microsoft Corporation) C:\WINDOWS\system32\SCardSvr.dll
2018-10-09 20:49 - 2018-09-08 09:40 - 001724928 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.UI.Immersive.dll
2018-10-09 20:49 - 2018-09-08 09:40 - 000677888 _____ (Microsoft Corporation) C:\WINDOWS\system32\winlogon.exe
2018-10-09 20:49 - 2018-09-08 09:40 - 000593408 _____ (Microsoft Corporation) C:\WINDOWS\system32\cryptui.dll
2018-10-09 20:49 - 2018-09-08 09:40 - 000522240 _____ (Microsoft Corporation) C:\WINDOWS\system32\winspool.drv
2018-10-09 20:49 - 2018-09-08 09:40 - 000402944 _____ (Microsoft Corporation) C:\WINDOWS\system32\bdesvc.dll
2018-10-09 20:49 - 2018-09-08 09:40 - 000249344 _____ (Microsoft Corporation) C:\WINDOWS\system32\bthprops.cpl
2018-10-09 20:49 - 2018-09-08 09:39 - 005505024 _____ (Microsoft Corporation) C:\WINDOWS\system32\aclui.dll
2018-10-09 20:49 - 2018-09-08 09:39 - 002052096 _____ (Microsoft Corporation) C:\WINDOWS\system32\wsp_fs.dll
2018-10-09 20:49 - 2018-09-08 09:39 - 001787904 _____ (Microsoft Corporation) C:\WINDOWS\system32\wsp_health.dll
2018-10-09 20:49 - 2018-09-08 09:39 - 000615936 _____ (Microsoft Corporation) C:\WINDOWS\system32\resutils.dll
2018-10-09 20:49 - 2018-09-08 09:38 - 001004544 _____ (Microsoft Corporation) C:\WINDOWS\system32\clusapi.dll
2018-10-09 20:49 - 2018-09-08 09:38 - 000986112 _____ (Microsoft Corporation) C:\WINDOWS\system32\inetcomm.dll
2018-10-09 20:49 - 2018-09-08 09:38 - 000882688 _____ (Microsoft Corporation) C:\WINDOWS\system32\SmartcardCredentialProvider.dll
2018-10-09 20:49 - 2018-09-08 09:38 - 000836608 _____ (Microsoft Corporation) C:\WINDOWS\system32\win32spl.dll
2018-10-09 20:49 - 2018-09-08 09:37 - 000091136 _____ (Microsoft Corporation) C:\WINDOWS\system32\mcbuilder.exe
2018-10-09 20:49 - 2018-09-08 09:16 - 000482080 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\advapi32.dll
2018-10-09 20:49 - 2018-09-08 09:14 - 001328056 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msctf.dll
2018-10-09 20:49 - 2018-09-08 09:13 - 001626656 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\user32.dll
2018-10-09 20:49 - 2018-09-08 09:13 - 000181288 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\basecsp.dll
2018-10-09 20:49 - 2018-09-08 09:03 - 000084992 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\INETRES.dll
2018-10-09 20:49 - 2018-09-08 09:03 - 000059392 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\fdBth.dll
2018-10-09 20:49 - 2018-09-08 09:02 - 000236032 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\scksp.dll
2018-10-09 20:49 - 2018-09-08 09:00 - 000548864 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\cryptui.dll
2018-10-09 20:49 - 2018-09-08 08:59 - 001530368 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.UI.Immersive.dll
2018-10-09 20:49 - 2018-09-08 08:59 - 001452544 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\wsp_fs.dll
2018-10-09 20:49 - 2018-09-08 08:59 - 000485376 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\resutils.dll
2018-10-09 20:49 - 2018-09-08 08:59 - 000133632 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.UI.XamlHost.dll
2018-10-09 20:49 - 2018-09-08 08:58 - 001308672 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\wsp_health.dll
2018-10-09 20:49 - 2018-09-08 08:58 - 000897536 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\inetcomm.dll
2018-10-09 20:49 - 2018-09-08 08:58 - 000775680 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\clusapi.dll
2018-10-09 20:49 - 2018-09-08 08:57 - 005391360 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\aclui.dll
2018-10-09 20:49 - 2018-09-08 08:57 - 000625664 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\SmartcardCredentialProvider.dll
2018-10-09 20:49 - 2018-09-08 08:57 - 000423936 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\winspool.drv
2018-10-09 20:49 - 2018-09-08 08:57 - 000223744 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\bthprops.cpl
2018-10-09 20:49 - 2018-09-08 08:56 - 000080384 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mcbuilder.exe
2018-10-09 20:49 - 2018-09-08 06:08 - 000462880 _____ (Microsoft Corporation) C:\WINDOWS\system32\aepic.dll
2018-10-09 20:49 - 2018-09-08 05:59 - 000433664 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\rdbss.sys
2018-10-09 20:49 - 2018-09-08 05:59 - 000361544 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Storage.ApplicationData.dll
2018-10-09 20:49 - 2018-09-08 05:58 - 000744976 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\fvevol.sys
2018-10-09 20:49 - 2018-09-08 05:58 - 000376120 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\fastfat.sys
2018-10-09 20:49 - 2018-09-08 05:58 - 000368440 _____ (Microsoft Corporation) C:\WINDOWS\system32\thumbcache.dll
2018-10-09 20:49 - 2018-09-08 05:57 - 002571128 _____ (Microsoft Corporation) C:\WINDOWS\system32\KernelBase.dll
2018-10-09 20:49 - 2018-09-08 05:57 - 001016984 _____ (Microsoft Corporation) C:\WINDOWS\system32\ucrtbase.dll
2018-10-09 20:49 - 2018-09-08 05:57 - 000930616 _____ (Microsoft Corporation) C:\WINDOWS\system32\WWAHost.exe
2018-10-09 20:49 - 2018-09-08 05:57 - 000482384 _____ (Microsoft Corporation) C:\WINDOWS\system32\ucrtbase_enclave.dll
2018-10-09 20:49 - 2018-09-08 05:57 - 000368448 _____ (Microsoft Corporation) C:\WINDOWS\system32\sechost.dll
2018-10-09 20:49 - 2018-09-08 05:57 - 000267576 _____ (Microsoft Corporation) C:\WINDOWS\system32\browserbroker.dll
2018-10-09 20:49 - 2018-09-08 05:51 - 000380728 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\aepic.dll
2018-10-09 20:49 - 2018-09-08 05:45 - 000295416 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\thumbcache.dll
2018-10-09 20:49 - 2018-09-08 05:45 - 000286824 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Storage.ApplicationData.dll
2018-10-09 20:49 - 2018-09-08 05:44 - 000829752 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\WWAHost.exe
2018-10-09 20:49 - 2018-09-08 05:43 - 001174448 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ucrtbase.dll
2018-10-09 20:49 - 2018-09-08 05:43 - 000269104 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\sechost.dll
2018-10-09 20:49 - 2018-09-08 05:32 - 000025600 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\Dumpstorport.sys
2018-10-09 20:49 - 2018-09-08 05:31 - 000342528 _____ (Microsoft Corporation) C:\WINDOWS\system32\browserexport.exe
2018-10-09 20:49 - 2018-09-08 05:31 - 000272384 _____ (Microsoft Corporation) C:\WINDOWS\system32\Microsoft.Bluetooth.Proxy.dll
2018-10-09 20:49 - 2018-09-08 05:30 - 000189440 _____ (Microsoft Corporation) C:\WINDOWS\system32\BluetoothApis.dll
2018-10-09 20:49 - 2018-09-08 05:30 - 000137728 _____ (Microsoft Corporation) C:\WINDOWS\system32\InputLocaleManager.dll
2018-10-09 20:49 - 2018-09-08 05:30 - 000115200 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\hidbth.sys
2018-10-09 20:49 - 2018-09-08 05:30 - 000101888 _____ (Microsoft Corporation) C:\WINDOWS\system32\BthRadioMedia.dll
2018-10-09 20:49 - 2018-09-08 05:29 - 000358912 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\exfat.sys
2018-10-09 20:49 - 2018-09-08 05:29 - 000241152 _____ (Microsoft Corporation) C:\WINDOWS\system32\HttpsDataSource.dll
2018-10-09 20:49 - 2018-09-08 05:29 - 000183808 _____ (Microsoft Corporation) C:\WINDOWS\system32\bthserv.dll
2018-10-09 20:49 - 2018-09-08 05:29 - 000174080 _____ (Microsoft Corporation) C:\WINDOWS\system32\wuuhosdeployment.dll
2018-10-09 20:49 - 2018-09-08 05:28 - 000481280 _____ (Microsoft Corporation) C:\WINDOWS\system32\ngccredprov.dll
2018-10-09 20:49 - 2018-09-08 05:28 - 000473088 _____ (Microsoft Corporation) C:\WINDOWS\system32\schannel.dll
2018-10-09 20:49 - 2018-09-08 05:28 - 000273408 _____ (Microsoft Corporation) C:\WINDOWS\system32\ubpm.dll
2018-10-09 20:49 - 2018-09-08 05:28 - 000265728 _____ (Microsoft Corporation) C:\WINDOWS\system32\psmsrv.dll
2018-10-09 20:49 - 2018-09-08 05:28 - 000153088 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Microsoft.Bluetooth.Proxy.dll
2018-10-09 20:49 - 2018-09-08 05:27 - 000983040 _____ (Microsoft Corporation) C:\WINDOWS\system32\wbiosrvc.dll
2018-10-09 20:49 - 2018-09-08 05:27 - 000596992 _____ (Microsoft Corporation) C:\WINDOWS\system32\TileDataRepository.dll
2018-10-09 20:49 - 2018-09-08 05:27 - 000499200 _____ (Microsoft Corporation) C:\WINDOWS\system32\winipcfile.dll
2018-10-09 20:49 - 2018-09-08 05:27 - 000301056 _____ (Microsoft Corporation) C:\WINDOWS\system32\ProximityService.dll
2018-10-09 20:49 - 2018-09-08 05:27 - 000271872 _____ (Microsoft Corporation) C:\WINDOWS\system32\dafBth.dll
2018-10-09 20:49 - 2018-09-08 05:26 - 002328064 _____ (Microsoft Corporation) C:\WINDOWS\system32\winmsipc.dll
2018-10-09 20:49 - 2018-09-08 05:26 - 000814592 _____ (Microsoft Corporation) C:\WINDOWS\system32\ieproxy.dll
2018-10-09 20:49 - 2018-09-08 05:26 - 000784896 _____ (Microsoft Corporation) C:\WINDOWS\system32\ngcsvc.dll
2018-10-09 20:49 - 2018-09-08 05:26 - 000471552 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\TileDataRepository.dll
2018-10-09 20:49 - 2018-09-08 05:26 - 000387584 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ngccredprov.dll
2018-10-09 20:49 - 2018-09-08 05:26 - 000365568 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ieproxy.dll
2018-10-09 20:49 - 2018-09-08 05:26 - 000359424 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\winipcfile.dll
2018-10-09 20:49 - 2018-09-08 05:26 - 000142848 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\BluetoothApis.dll
2018-10-09 20:49 - 2018-09-08 05:25 - 002789376 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msftedit.dll
2018-10-09 20:49 - 2018-09-08 05:25 - 000882688 _____ (Microsoft Corporation) C:\WINDOWS\system32\winipcsecproc.dll
2018-10-09 20:49 - 2018-09-08 05:25 - 000466432 _____ (Microsoft Corporation) C:\WINDOWS\system32\wuuhext.dll
2018-10-09 20:49 - 2018-09-08 05:25 - 000415744 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\schannel.dll
2018-10-09 20:49 - 2018-09-08 05:25 - 000341504 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Networking.Proximity.dll
2018-10-09 20:49 - 2018-09-08 05:24 - 001096704 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\bthport.sys
2018-10-09 20:49 - 2018-09-08 05:24 - 000899072 _____ (Microsoft Corporation) C:\WINDOWS\system32\kerberos.dll
2018-10-09 20:49 - 2018-09-08 05:24 - 000845824 _____ (Microsoft Corporation) C:\WINDOWS\system32\fveapi.dll
2018-10-09 20:49 - 2018-09-08 05:24 - 000463360 _____ (Microsoft Corporation) C:\WINDOWS\system32\das.dll
2018-10-09 20:49 - 2018-09-08 05:23 - 001655296 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\winmsipc.dll
2018-10-09 20:49 - 2018-09-08 05:23 - 000807936 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\winipcsecproc.dll
2018-10-09 20:49 - 2018-09-08 05:23 - 000667136 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\fveapi.dll
2018-10-09 20:49 - 2018-09-08 05:23 - 000314368 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Networking.Proximity.dll
2018-10-09 20:49 - 2018-09-08 05:22 - 000778240 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\kerberos.dll
2018-10-07 06:31 - 2018-10-07 06:31 - 000605317 _____ C:\Users\Gebruiker\Downloads\DesignBundles-Be-Kind.zip
2018-10-07 06:29 - 2018-10-07 06:29 - 000920477 _____ C:\Users\Gebruiker\Downloads\DesignBundles-Girls-Just-Wanna-Have-Sun.zip
2018-10-05 20:23 - 2018-10-05 20:23 - 000000000 ____D C:\Users\Gebruiker\Downloads\championship
2018-10-05 20:16 - 2018-10-05 20:16 - 000030124 _____ C:\Users\Gebruiker\Downloads\championship.zip
2018-10-01 06:31 - 2018-10-01 06:31 - 002163208 _____ C:\Users\Gebruiker\Downloads\A0-Print-Shop-File-Reagan-Raglan-Kids-UPDATED-9.21.2017 (1).pdf
2018-10-01 06:30 - 2018-10-01 06:30 - 005990209 _____ C:\Users\Gebruiker\Downloads\BSD_Reagan_Raglan_Kids_6M-12_UPDATED_9.22.2017 (1).pdf
2018-09-28 02:57 - 2018-09-05 00:36 - 001476904 _____ (Microsoft Corporation) C:\WINDOWS\system32\mcupdate_GenuineIntel.dll
2018-09-24 20:12 - 2018-09-24 20:12 - 000059198 _____ C:\Users\Gebruiker\Downloads\doctor_punk.zip
2018-09-24 20:11 - 2018-09-24 20:11 - 000022409 _____ C:\Users\Gebruiker\Downloads\badlystamped.zip
2018-09-24 20:10 - 2018-09-24 20:10 - 000056581 _____ C:\Users\Gebruiker\Downloads\punishment.zip
2018-09-24 20:08 - 2018-09-24 20:08 - 000556339 _____ C:\Users\Gebruiker\Downloads\cure_of_pain.zip
2018-09-24 20:00 - 2018-09-24 20:00 - 000012247 _____ C:\Users\Gebruiker\Downloads\bun_ting.zip
2018-09-24 19:59 - 2018-09-24 19:59 - 000150390 _____ C:\Users\Gebruiker\Downloads\the_enemigo.zip
2018-09-24 19:59 - 2018-09-24 19:59 - 000025993 _____ C:\Users\Gebruiker\Downloads\strange_shadow.zip
2018-09-24 19:20 - 2018-09-24 19:20 - 000000000 ____D C:\Users\Gebruiker\Downloads\white_on_black (1)
2018-09-24 19:12 - 2018-09-24 19:12 - 000141732 _____ C:\Users\Gebruiker\Downloads\white_on_black (1).zip
2018-09-24 19:10 - 2018-09-24 19:10 - 000141732 _____ C:\Users\Gebruiker\Downloads\white_on_black.zip
2018-09-24 19:08 - 2018-09-24 19:08 - 000094858 _____ C:\Users\Gebruiker\Downloads\only_the_strong.zip
2018-09-24 19:07 - 2018-09-24 19:07 - 000003907 _____ C:\Users\Gebruiker\Downloads\bonushearts.zip
2018-09-24 18:57 - 2018-09-24 18:57 - 003780724 _____ C:\Users\Gebruiker\Downloads\gobold_blocky.zip
2018-09-24 18:49 - 2018-09-24 18:49 - 000319610 _____ C:\Users\Gebruiker\Downloads\campus.zip
2018-09-24 18:37 - 2018-09-24 18:37 - 000160021 _____ C:\Users\Gebruiker\Downloads\star_light.zip
2018-09-24 18:35 - 2018-09-24 18:35 - 000156541 _____ C:\Users\Gebruiker\Downloads\choppers.zip
2018-09-24 18:29 - 2018-09-24 18:29 - 000168832 _____ C:\Users\Gebruiker\Downloads\attraction.zip
==================== Een Maand Gewijzigd bestanden en mappen ========
2021-10-21 15:36 - 2013-12-01 11:15 - 000000852 _____ C:\WINDOWS\system32\Drivers\RTKHDRC.dat
2021-10-04 09:34 - 2013-12-01 11:15 - 000000712 _____ C:\WINDOWS\system32\Drivers\RTMICEQ0.dat
2018-10-24 15:10 - 2018-06-03 00:31 - 000003542 _____ C:\WINDOWS\System32\Tasks\Adobe Acrobat Update Task
2018-10-24 15:10 - 2018-06-03 00:31 - 000002920 _____ C:\WINDOWS\System32\Tasks\OneDrive Standalone Update Task-S-1-5-21-1014441568-1594974271-3246346139-1001
2018-10-24 15:10 - 2018-06-03 00:31 - 000002280 _____ C:\WINDOWS\System32\Tasks\CCleanerSkipUAC
2018-10-24 15:10 - 2018-06-03 00:31 - 000000000 ____D C:\WINDOWS\System32\Tasks\AVAST Software
2018-10-24 15:06 - 2018-04-12 01:38 - 000000000 ____D C:\ProgramData\regid.1991-06.com.microsoft
2018-10-24 14:51 - 2015-03-29 13:55 - 000000000 ____D C:\Users\Gebruiker\AppData\Local\CrashDumps
2018-10-24 14:42 - 2015-03-06 16:38 - 000000000 ____D C:\Users\Gebruiker\AppData\Local\SweetLabs App Platform
2018-10-24 13:55 - 2018-06-02 23:50 - 000000000 ____D C:\WINDOWS\system32\SleepStudy
2018-10-24 10:32 - 2014-05-14 05:28 - 000000000 ___RD C:\Users\Gebruiker\OneDrive
2018-10-24 10:30 - 2016-04-18 18:32 - 000000000 __SHD C:\Users\Gebruiker\IntelGraphicsProfiles
2018-10-23 16:25 - 2018-06-03 00:31 - 000000006 ____H C:\WINDOWS\Tasks\SA.DAT
2018-10-23 16:25 - 2018-04-12 01:38 - 000000000 ____D C:\WINDOWS\AppReadiness
2018-10-23 16:24 - 2018-04-11 23:04 - 000786432 _____ C:\WINDOWS\system32\config\BBI
2018-10-23 16:11 - 2018-04-12 01:38 - 000000000 ___HD C:\Program Files\WindowsApps
2018-10-23 12:01 - 2015-03-12 21:53 - 000000000 ____D C:\Users\Gebruiker\AppData\Roaming\Corel
2018-10-23 11:53 - 2018-08-24 08:37 - 000000000 ____D C:\Users\Gebruiker\Documents\Mijn PSP-bestanden
2018-10-23 11:53 - 2015-03-12 21:53 - 000001786 _____ C:\WINDOWS\SysWOW64\KGyGaAvL.sys
2018-10-23 07:24 - 2018-04-12 01:38 - 000000000 ____D C:\WINDOWS\LiveKernelReports
2018-10-22 23:38 - 2018-06-03 00:31 - 000003990 _____ C:\WINDOWS\System32\Tasks\Avast Emergency Update
2018-10-22 23:37 - 2018-06-02 16:51 - 000467904 _____ (AVAST Software) C:\WINDOWS\system32\Drivers\aswSP.sys
2018-10-22 23:37 - 2018-06-02 16:51 - 000381144 _____ (AVAST Software) C:\WINDOWS\system32\Drivers\aswVmm.sys
2018-10-22 23:37 - 2018-06-02 16:51 - 000208640 _____ (AVAST Software) C:\WINDOWS\system32\Drivers\aswStm.sys
2018-10-22 23:37 - 2018-06-02 16:51 - 000201408 _____ (AVAST Software) C:\WINDOWS\system32\Drivers\aswArPot.sys
2018-10-22 23:37 - 2018-06-02 16:51 - 000163376 _____ (AVAST Software) C:\WINDOWS\system32\Drivers\aswMonFlt.sys
2018-10-22 23:37 - 2018-06-02 16:51 - 000111968 _____ (AVAST Software) C:\WINDOWS\system32\Drivers\aswRdr2.sys
2018-10-22 23:37 - 2018-06-02 16:51 - 000088112 _____ (AVAST Software) C:\WINDOWS\system32\Drivers\aswRvrt.sys
2018-10-22 23:37 - 2018-06-02 16:51 - 000047064 _____ (AVAST Software) C:\WINDOWS\system32\Drivers\aswHwid.sys
2018-10-22 23:37 - 2018-04-12 01:38 - 000000000 ___HD C:\WINDOWS\ELAMBKUP
2018-10-22 23:36 - 2018-06-02 16:51 - 001028840 _____ (AVAST Software) C:\WINDOWS\system32\Drivers\aswSnx.sys
2018-10-22 23:36 - 2018-06-02 16:51 - 000346760 _____ (AVAST Software) C:\WINDOWS\system32\Drivers\aswbloga.sys
2018-10-22 23:36 - 2018-06-02 16:51 - 000230512 _____ (AVAST Software) C:\WINDOWS\system32\Drivers\aswbidsdrivera.sys
2018-10-22 23:36 - 2018-06-02 16:51 - 000201928 _____ (AVAST Software) C:\WINDOWS\system32\Drivers\aswbidsha.sys
2018-10-22 23:36 - 2018-06-02 16:51 - 000059664 _____ (AVAST Software) C:\WINDOWS\system32\Drivers\aswbuniva.sys
2018-10-22 23:36 - 2018-01-10 18:43 - 000185240 _____ (AVAST Software) C:\WINDOWS\system32\Drivers\aswHdsKe.sys
2018-10-22 23:23 - 2018-08-20 18:21 - 000000000 ____D C:\Users\Gebruiker\AppData\Roaming\com.silhouettesoftware
2018-10-22 23:20 - 2018-08-20 18:21 - 000000000 ____D C:\Users\Gebruiker\AppData\Roaming\com.silhouettesoftware.scratch.1
2018-10-22 23:19 - 2018-08-20 18:22 - 000000000 ____D C:\Users\Gebruiker\AppData\Roaming\com.aspexsoftware.ss_bluetooth
2018-10-22 17:51 - 2015-12-26 16:40 - 000002457 _____ C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Acrobat Reader DC.lnk
2018-10-18 11:05 - 2018-09-17 13:47 - 000000000 ____D C:\Users\Gebruiker\AppData\Local\ElevatedDiagnostics
2018-10-17 20:57 - 2018-06-02 23:57 - 000002403 _____ C:\Users\Gebruiker\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\OneDrive.lnk
2018-10-13 10:11 - 2018-04-12 01:30 - 000000000 ____D C:\WINDOWS\CbsTemp
2018-10-12 23:19 - 2018-06-02 23:57 - 000000000 ____D C:\Users\Gebruiker
2018-10-11 12:06 - 2018-04-12 01:36 - 000000000 ____D C:\WINDOWS\INF
2018-10-10 10:22 - 2018-06-03 00:13 - 001767124 _____ C:\WINDOWS\system32\PerfStringBackup.INI
2018-10-10 10:22 - 2018-04-12 18:01 - 000785364 _____ C:\WINDOWS\system32\perfh013.dat
2018-10-10 10:22 - 2018-04-12 18:01 - 000153682 _____ C:\WINDOWS\system32\perfc013.dat
2018-10-10 10:13 - 2017-12-08 07:53 - 000000000 ___RD C:\Users\Gebruiker\3D Objects
2018-10-10 10:13 - 2016-02-13 15:33 - 000000000 __RHD C:\Users\Public\AccountPictures
2018-10-10 10:12 - 2018-06-02 23:50 - 000333936 _____ C:\WINDOWS\system32\FNTCACHE.DAT
2018-10-09 23:00 - 2018-04-12 01:38 - 000000000 ___RD C:\WINDOWS\ImmersiveControlPanel
2018-10-09 23:00 - 2018-04-12 01:38 - 000000000 ___RD C:\Program Files\Windows Defender
2018-10-09 23:00 - 2018-04-12 01:38 - 000000000 ____D C:\WINDOWS\TextInput
2018-10-09 23:00 - 2018-04-12 01:38 - 000000000 ____D C:\WINDOWS\system32\ShellExperiences
2018-10-09 23:00 - 2018-04-12 01:38 - 000000000 ____D C:\WINDOWS\bcastdvr
2018-10-09 23:00 - 2018-04-12 01:38 - 000000000 ____D C:\Program Files (x86)\Windows Defender
2018-10-09 21:02 - 2015-03-10 12:43 - 000000000 ____D C:\WINDOWS\system32\MRT
2018-10-09 21:00 - 2015-03-10 12:43 - 136745976 ____C (Microsoft Corporation) C:\WINDOWS\system32\MRT.exe
2018-10-05 11:56 - 2018-08-25 13:41 - 000000000 ____D C:\Users\Gebruiker\AppData\Roaming\com.aspexsoftware.Silhouette_Studio
2018-10-04 09:47 - 2015-12-26 16:41 - 000000000 ____D C:\Users\Gebruiker\AppData\LocalLow\Adobe
2018-10-02 22:13 - 2018-07-12 10:28 - 000835152 _____ (Adobe Systems Incorporated) C:\WINDOWS\SysWOW64\FlashPlayerApp.exe
2018-10-02 22:13 - 2018-07-12 10:28 - 000179792 _____ (Adobe Systems Incorporated) C:\WINDOWS\SysWOW64\FlashPlayerCPLApp.cpl
2018-10-01 22:21 - 2018-07-10 02:04 - 000000000 ____D C:\ProgramData\Packages
2018-09-29 09:38 - 2018-06-03 00:31 - 000000000 ____D C:\WINDOWS\system32\Drivers\wd
2018-09-28 07:49 - 2016-04-18 21:11 - 000563832 ____N (Microsoft Corporation) C:\WINDOWS\system32\MpSigStub.exe
2018-09-28 07:48 - 2018-04-11 23:04 - 000032768 _____ C:\WINDOWS\system32\config\ELAM
==================== Bestanden in de root van sommige mappen =======
2018-08-20 18:22 - 2018-08-20 18:22 - 000000008 _____ () C:\Users\Gebruiker\AppData\Roaming\com.silhouettesoftware.id
2015-03-12 21:59 - 2016-07-29 12:20 - 000003584 _____ () C:\Users\Gebruiker\AppData\Local\DCBC2A71-70D8-4DAN-EHR8-E0D61DEA3FDF.ini
==================== Bamital & volsnap ======================
(Er is geen automatische fix voor bestanden die de verificatie niet doorkomen.)
C:\WINDOWS\system32\winlogon.exe => Bestand is getekend
C:\WINDOWS\system32\wininit.exe => Bestand is getekend
C:\WINDOWS\explorer.exe => Bestand is getekend
C:\WINDOWS\SysWOW64\explorer.exe => Bestand is getekend
C:\WINDOWS\system32\svchost.exe => Bestand is getekend
C:\WINDOWS\SysWOW64\svchost.exe => Bestand is getekend
C:\WINDOWS\system32\services.exe => Bestand is getekend
C:\WINDOWS\system32\User32.dll => Bestand is getekend
C:\WINDOWS\SysWOW64\User32.dll => Bestand is getekend
C:\WINDOWS\system32\userinit.exe => Bestand is getekend
C:\WINDOWS\SysWOW64\userinit.exe => Bestand is getekend
C:\WINDOWS\system32\rpcss.dll => Bestand is getekend
C:\WINDOWS\system32\dnsapi.dll => Bestand is getekend
C:\WINDOWS\SysWOW64\dnsapi.dll => Bestand is getekend
C:\WINDOWS\system32\Drivers\volsnap.sys => Bestand is getekend
LastRegBack: 2018-06-02 23:50
==================== Eind van FRST.txt ============================
schults2005
schults2005
#3
En tekst adition van FRST
Extra scanresultaten van Farbar Recovery Scan Tool (x64) Versie: 10.10.2018
Gestart door Gebruiker (24-10-2018 15:11:02)
Gestart vanaf C:\Users\Gebruiker\Desktop
Windows 10 Home Versie 1803 17134.345 (X64) (2018-06-02 22:32:35)
Boot Modus: Normal
==================== Accounts: =============================
Administrator (S-1-5-21-1014441568-1594974271-3246346139-500 - Administrator - Disabled) => C:\Users\Administrator
DefaultAccount (S-1-5-21-1014441568-1594974271-3246346139-503 - Limited - Disabled)
Gast (S-1-5-21-1014441568-1594974271-3246346139-501 - Limited - Disabled)
Gebruiker (S-1-5-21-1014441568-1594974271-3246346139-1001 - Administrator - Enabled) => C:\Users\Gebruiker
HomeGroupUser$ (S-1-5-21-1014441568-1594974271-3246346139-1004 - Limited - Enabled)
WDAGUtilityAccount (S-1-5-21-1014441568-1594974271-3246346139-504 - Limited - Disabled)
==================== Security Center ========================
(Als een item is opgenomen in de fixlist, zal het worden verwijderd.)
AV: Avast Antivirus (Disabled - Up to date) {8EA8924E-BC81-DC44-8BB0-8BAE75D86EBF}
AV: Windows Defender (Disabled - Up to date) {D68DDC3A-831F-4fae-9E44-DA132C1ACF46}
AV: Malwarebytes (Enabled - Up to date) {23007AD3-69FE-687C-2629-D584AFFAF72B}
AS: Malwarebytes (Enabled - Up to date) {98619B37-4FC4-67F2-1C99-EEF6D47DBD96}
AS: Windows Defender (Disabled - Up to date) {D68DDC3A-831F-4fae-9E44-DA132C1ACF46}
AS: Avast Antivirus (Disabled - Up to date) {35C973AA-9ABB-D3CA-B100-B0DC0E5F2402}
==================== Geïnstalleerde programma's ======================
(Alleen de adware-programma's met 'verborgen' vlag kunnen worden toegevoegd aan de fixlist om ze zichtbaar te maken. De adware-programma's moeten handmatig gedeïnstalleerd worden.)
Acer Docs (HKLM-x32\...\{CA4FE8B0-298C-4E5D-A486-F33B126D6A0A}) (Version: 1.01.3006 - Acer Incorporated)
Acer Games (HKU\S-1-5-21-1014441568-1594974271-3246346139-1001\...\Pokki_03d432a7e610c3e908213e7689d4342ce2111caf) (Version: 1.1.9.43466 - Pokki)
Acer Launch Manager (HKLM\...\{C18D55BD-1EC6-466D-B763-8EEDDDA9100E}) (Version: 8.00.8101 - Acer Incorporated)
Acer Media (HKLM-x32\...\{E9AF1707-3F3A-49E2-8345-4F2D629D0876}) (Version: 2.02.3104.3 - Acer Incorporated)
Acer Photo (HKLM-x32\...\{B5AD89F2-03D3-4206-8487-018298007DD0}) (Version: 2.02.3104.6 - Acer Incorporated)
Acer Power Management (HKLM\...\{91F52DE4-B789-42B0-9311-A349F10E5479}) (Version: 7.00.8100 - Acer Incorporated)
Acer Quick Access (HKLM\...\{C1FA525F-D701-4B31-9D32-504FC0CF0B98}) (Version: 1.00.3000 - Acer Incorporated)
Acer Recovery Management (HKLM\...\{07F2005A-8CAC-4A4B-83A2-DA98A722CA61}) (Version: 6.00.8100 - Acer Incorporated)
Acer Remote Files (HKLM\...\{13885028-098C-4799-9B71-27DAC96502D5}) (Version: 1.00.3007 - Acer Incorporated)
Adobe Acrobat Reader DC - Nederlands (HKLM-x32\...\{AC76BA86-7AD7-1043-7B44-AC0F074E4100}) (Version: 19.008.20080 - Adobe Systems Incorporated)
Adobe Flash Player 18 NPAPI (HKLM-x32\...\Adobe Flash Player NPAPI) (Version: 18.0.0.160 - Adobe Systems Incorporated)
Avast Free Antivirus (HKLM-x32\...\Avast Antivirus) (Version: 18.7.2354 - AVAST Software)
Avast Update Helper (HKLM-x32\...\{A92DAB39-4E2C-4304-9AB6-BC44E68B55E2}) (Version: 1.4.136.333 - AVAST Software) Hidden
Broadcom Card Reader Driver Installer (HKLM\...\{67AA948F-8D83-4566-B84A-7CAABCF64E3F}) (Version: 16.0.2.8 - Broadcom Corporation)
Broadcom NetLink Controller (HKLM\...\{D1D7ED66-5C08-40A0-AEC0-B6DF977697BB}) (Version: 16.2.1.2 - Broadcom Corporation)
CCleaner (HKLM\...\CCleaner) (Version: 5.42 - Piriform)
Corel Paint Shop Pro Photo XI (HKLM-x32\...\{E1C7EF5E-3A7B-4ED4-A48B-F70F1B36EAB4}) (Version: 11.00.0000 - Corel Inc)
Corel Painter Essentials 3 (HKLM-x32\...\{0C180787-F8C8-42FD-A9D3-689BA44BEAAF}) (Version: 3.0 - Corel Corporation)
Corel Snapfire (HKLM-x32\...\{0EE4030A-8FD4-4798-A21D-17E525B1F7CF}) (Version: 1.00.0000 - Uw bedrijfsnaam)
CyberLink PowerDVD 12 (HKLM-x32\...\InstallShield_{B46BEA36-0B71-4A4E-AE41-87241643FA0A}) (Version: 12.0.3126.57 - CyberLink Corp.)
D3DX10 (HKLM-x32\...\{E09C4DB7-630C-4F06-A631-8EA7239923AF}) (Version: 15.4.2368.0902 - Microsoft) Hidden
eBay Worldwide (HKLM-x32\...\{91589413-6675-4C27-8AFC-EFB9103B90A5}) (Version: 2.4.0105 - OEM)
ELAN Touchpad 11.15.0.18_X64 (HKLM\...\Elantech) (Version: 11.15.0.18 - ELAN Microelectronic Corp.)
Facebook (HKU\S-1-5-21-1014441568-1594974271-3246346139-1001\...\Pokki_a65116cdc0b4377bed428e280c19949d56248d11) (Version: 1.1.4 - SweetLabs)
Google Chrome (HKLM-x32\...\Google Chrome) (Version: 69.0.3497.100 - Google Inc.)
Google Toolbar for Internet Explorer (HKLM-x32\...\{18455581-E099-4BA8-BC6B-F34B2F06600C}) (Version: 1.0.0 - Google Inc.) Hidden
Google Update Helper (HKLM-x32\...\{60EC980A-BDA2-4CB6-A427-B07A5498B4CA}) (Version: 1.3.33.17 - Google Inc.) Hidden
Host App Service (HKU\S-1-5-21-1014441568-1594974271-3246346139-1001\...\SweetLabs_AP) (Version: 0.269.8.414 - Pokki) <==== AANDACHT
Identity Card (HKLM-x32\...\{3D9CB654-99AD-4301-89C6-0D12A790767C}) (Version: 2.00.8100 - Acer Incorporated)
inSSIDer Home (HKLM-x32\...\{9E54E4AE-B67A-4925-8E92-0E1F9817FD73}) (Version: 3.1.2.1 - MetaGeek, LLC)
Intel(R) Management Engine Components (HKLM-x32\...\{65153EA5-8B6E-43B6-857B-C6E4FC25798A}) (Version: 9.5.14.1724 - Intel Corporation)
Intel(R) Processor Graphics (HKLM-x32\...\{F0E3AD40-2BBD-4360-9C76-B9AC9A5886EA}) (Version: 10.18.10.4276 - Intel Corporation)
Junk Mail filter update (HKLM-x32\...\{0BE9E708-5DC0-4963-9CFD-0AA519090E79}) (Version: 16.4.3528.0331 - Microsoft Corporation) Hidden
Kobo (HKLM-x32\...\Kobo) (Version: 4.0.5579 - Rakuten Kobo Inc.)
Live Updater (HKLM-x32\...\{EE26E302-876A-48D9-9058-3129E5B99999}) (Version: 2.00.8102 - Acer Incorporated)
Malwarebytes versie 3.6.1.2711 (HKLM\...\{35065F43-4BB2-439A-BFF7-0F1014F2E0CD}_is1) (Version: 3.6.1.2711 - Malwarebytes)
Microsoft Office 2000 Premium (HKLM-x32\...\{00000413-78E1-11D2-B60F-006097C998E7}) (Version: 9.00.2720 - Microsoft Corporation)
Microsoft OneDrive (HKU\S-1-5-21-1014441568-1594974271-3246346139-1001\...\OneDriveSetup.exe) (Version: 18.172.0826.0010 - Microsoft Corporation)
Microsoft Visual C++ 2005 Redistributable (HKLM-x32\...\{A49F249F-0C91-497F-86DF-B2585E8E76B7}) (Version: 8.0.50727.42 - Microsoft Corporation)
Microsoft Visual C++ 2008 Redistributable - x64 9.0.30729.17 (HKLM\...\{8220EEFE-38CD-377E-8595-13398D740ACE}) (Version: 9.0.30729 - Microsoft Corporation)
Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.4148 (HKLM-x32\...\{1F1C2DFC-2D24-3E06-BCB8-725134ADF989}) (Version: 9.0.30729.4148 - Microsoft Corporation)
Microsoft Visual C++ 2015 Redistributable (x64) - 14.0.24212 (HKLM-x32\...\{323dad84-0974-4d90-a1c1-e006c7fdbb7d}) (Version: 14.0.24212.0 - Microsoft Corporation)
Microsoft Visual C++ 2015 Redistributable (x86) - 14.0.24212 (HKLM-x32\...\{462f63a8-6347-4894-a1b3-dbfe3a4c981d}) (Version: 14.0.24212.0 - Microsoft Corporation)
Nero BackItUp 12 Essentials OEM.a01 (HKLM-x32\...\{551AC8F2-FEA2-4B45-ACF7-C98681233CC9}) (Version: 12.5.01200 - Nero AG)
Office Addin (HKLM-x32\...\{6D2BBE1D-E600-4695-BA37-0B0E605542CC}) (Version: 2.02.2009 - Acer)
PaintShop Photo Pro X3 Registration Incentive (HKLM-x32\...\{3DA41E54-9526-40C0-8456-66B09379DFCC}) (Version: 1.00.0000 - Uw bedrijfsnaam) Hidden
Prerequisite installer (HKLM-x32\...\{3AAB08A3-F129-4BD5-B409-AE674F93759D}) (Version: 12.0.0003 - Nero AG) Hidden
Qualcomm Atheros Bluetooth Suite (64) (HKLM\...\{A84A4FB1-D703-48DB-89E0-68B6499D2801}) (Version: 8.0.1.305 - Qualcomm Atheros Communications)
Qualcomm Atheros WLAN and Bluetooth Client Installation Program (HKLM-x32\...\{28006915-2739-4EBE-B5E8-49B25D32EB33}) (Version: 12.07 - Qualcomm Atheros)
QuickTime (HKLM-x32\...\{8DC42D05-680B-41B0-8878-6C14D24602DB}) (Version: 7.55.90.70 - Apple Inc.)
Realtek High Definition Audio Driver (HKLM-x32\...\{F132AF7F-7BCA-4EDE-8A7C-958108FE7DBC}) (Version: 6.0.1.7027 - Realtek Semiconductor Corp.)
Silhouette Link (HKLM-x32\...\{C2136C80-F9D4-4096-86D4-C641BB36DFF3}) (Version: 1.0.096 - Silhouette America)
Silhouette Studio (HKLM-x32\...\{40EFBD87-9DDB-412B-A93E-D582790AD500}) (Version: 4.1.468 - Silhouette America)
Visual Studio 2005 Tools for Office Second Edition Runtime (HKLM-x32\...\Microsoft Visual Studio 2005 Tools for Office Runtime) (Version: - Microsoft Corporation)
Visual Studio Tools for the Office system 3.0 Runtime (HKLM-x32\...\Visual Studio Tools for the Office system 3.0 Runtime) (Version: - Microsoft Corporation)
Visual Studio Tools for the Office system 3.0 Runtime Service Pack 1 (KB949258) (HKLM-x32\...\{8FB53850-246A-3507-8ADE-0060093FFEA6}.KB949258) (Version: 1 - Microsoft Corporation)
Windows Live Essentials (HKLM-x32\...\WinLiveSuite) (Version: 16.4.3528.0331 - Microsoft Corporation)
Windows Media Encoder 9 Series (HKLM-x32\...\Windows Media Encoder 9) (Version: - )
==================== Aangepaste CLSID (gefilterd): ==========================
CustomCLSID: HKU\S-1-5-21-1014441568-1594974271-3246346139-1001_Classes\CLSID\{820D63D5-8CFF-46DE-86AF-4997DEDD6DB5}\localserver32 -> C:\WINDOWS\system32\igfxEM.exe (Intel Corporation)
ShellIconOverlayIdentifiers: [00asw] -> {472083B0-C522-11CF-8763-00608CC02F24} => C:\Program Files\AVAST Software\Avast\ashShA64.dll [2018-10-22] (AVAST Software)
ShellIconOverlayIdentifiers: [00avast] -> {472083B0-C522-11CF-8763-00608CC02F24} => C:\Program Files\AVAST Software\Avast\ashShA64.dll [2018-10-22] (AVAST Software)
ContextMenuHandlers1: [avast] -> {472083B0-C522-11CF-8763-00608CC02F24} => C:\Program Files\AVAST Software\Avast\ashShA64.dll [2018-10-22] (AVAST Software)
ContextMenuHandlers3: [00asw] -> {472083B0-C522-11CF-8763-00608CC02F24} => C:\Program Files\AVAST Software\Avast\ashShA64.dll [2018-10-22] (AVAST Software)
ContextMenuHandlers3: [MBAMShlExt] -> {57CE581A-0CB6-4266-9CA0-19364C90A0B3} => C:\Program Files\Malwarebytes\Anti-Malware\mbshlext.dll [2018-09-19] (Malwarebytes)
ContextMenuHandlers5: [igfxcui] -> {3AB1675A-CCFF-11D2-8B20-00A0C93CB1F4} => -> Geen bestand
ContextMenuHandlers5: [igfxDTCM] -> {9B5F5829-A529-4B12-814A-E81BCB8D93FC} => C:\WINDOWS\system32\igfxDTCM.dll [2016-05-03] (Intel Corporation)
ContextMenuHandlers6: [avast] -> {472083B0-C522-11CF-8763-00608CC02F24} => C:\Program Files\AVAST Software\Avast\ashShA64.dll [2018-10-22] (AVAST Software)
ContextMenuHandlers6: [MBAMShlExt] -> {57CE581A-0CB6-4266-9CA0-19364C90A0B3} => C:\Program Files\Malwarebytes\Anti-Malware\mbshlext.dll [2018-09-19] (Malwarebytes)
==================== Geplande Taken (gefilterd) =============
Task: {003F3411-746D-4F14-A06A-5FAB27C37900} - System32\Tasks\Quick Access => C:\Program Files\Acer\Acer Quick Access\QALauncher.exe [2013-08-03] (Acer Incorporate)
Task: {0F76EF53-D934-4DE2-AD8D-4E39E95EFF6E} - \Microsoft\Windows\Setup\gwx\refreshgwxcontent -> Geen bestand <==== AANDACHT
Task: {1D61B05B-0734-4631-8502-4FFF48A14307} - \Microsoft\Windows\Setup\GWXTriggers\ScheduleUpgradeReminderTime -> Geen bestand <==== AANDACHT
Task: {24239F3A-9EBB-49DC-A561-3C3DC8EA0404} - System32\Tasks\Microsoft\Windows\Setup\Notifier => C:\WINDOWS\system32\Notifier.exe
Task: {24A37EB7-2713-4F2F-84D9-EBB184EEB0CC} - System32\Tasks\Microsoft\Windows\RemovalTools\MRT_HB => C:\WINDOWS\system32\MRT.exe [2018-10-09] (Microsoft Corporation)
Task: {273E690B-ED52-4013-8A5E-C3D6CE0A26D1} - System32\Tasks\Launch Manager => C:\Program Files\Acer\Acer Launch Manager\LMLauncher.exe [2013-08-03] (Acer Incorporate)
Task: {2CBDF47B-C6FF-4C59-A763-D1F0EA1E91EA} - System32\Tasks\Adobe Acrobat Update Task => C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\AdobeARM.exe [2018-08-14] (Adobe Systems Incorporated)
Task: {352E6CA0-7314-4DF4-89C4-682368D80D57} - System32\Tasks\Microsoft\Windows\Workplace Join\Automatic-Workplace-Join => C:\WINDOWS\System32\AutoWorkplace.exe
Task: {3842C32C-DBC9-478D-BD83-3A34515820C7} - \Microsoft\Windows\Setup\GWXTriggers\MachineUnlock-5d -> Geen bestand <==== AANDACHT
Task: {390B0BE2-6727-4E43-8E45-2740D23EEF88} - System32\Tasks\Avast Software\Overseer => C:\Program Files\Common Files\Avast Software\Overseer\overseer.exe [2018-09-15] (AVAST Software)
Task: {3D86CDAE-2DAD-4F79-818D-A3036F4265F2} - \Microsoft\Windows\Setup\GWXTriggers\Time-5d -> Geen bestand <==== AANDACHT
Task: {435E38E5-4ED8-4D45-8728-7D1521A83A10} - System32\Tasks\AVAST Software\Avast settings backup => C:\Program Files\Common Files\AV\avast! Antivirus\backup.exe
Task: {5BB29799-5344-4D83-9A9D-5747CB700E4B} - \Microsoft\Windows\UNP\RunCampaignManager -> Geen bestand <==== AANDACHT
Task: {5DDF1B46-3E35-4323-B0D0-38DA84D4B314} - \Microsoft\Windows\Setup\GWXTriggers\ScheduleUpgradeTime -> Geen bestand <==== AANDACHT
Task: {6492DE5A-A44B-4BA4-9BD1-4656ACAA1539} - \Microsoft\Windows\Setup\GWXTriggers\OnIdle-5d -> Geen bestand <==== AANDACHT
Task: {65B85F6F-35B3-4459-A179-28255D5B7B25} - System32\Tasks\Microsoft\Windows\HelloFace\FODCleanupTask => C:\WINDOWS\System32\WinBioPlugIns\FaceFodUninstaller.exe [2018-04-12] ()
Task: {712F24A0-8B45-495C-8DE8-29D710F8A283} - System32\Tasks\Avast Emergency Update => C:\Program Files\AVAST Software\Avast\AvEmUpdate.exe [2018-10-22] (AVAST Software)
Task: {76780F03-719F-4312-8280-FF992F828BAF} - System32\Tasks\AvastUpdateTaskMachineUA => C:\Program Files (x86)\AVAST Software\Browser\Update\AvastBrowserUpdate.exe
Task: {7A3E994E-7F92-4F46-A96F-CDDE0FBDB171} - \Microsoft\Windows\Setup\GWXTriggers\OutOfSleep-5d -> Geen bestand <==== AANDACHT
Task: {810D5BF3-5F2F-495E-8239-C1E9B6255EDC} - \Microsoft\Windows\Setup\GWXTriggers\Logon-5d -> Geen bestand <==== AANDACHT
Task: {82790C35-A414-4AFD-A8F9-6E2E73A16602} - \Microsoft\Windows\Setup\GWXTriggers\refreshgwxconfig-B -> Geen bestand <==== AANDACHT
Task: {9F36C218-0A84-4668-953D-497C8AB9F804} - System32\Tasks\ALU => C:\Program Files (x86)\Acer\Live Updater\updater.exe [2016-07-06] ()
Task: {A0F80259-D2F6-4081-B3E3-44AF80EA2156} - \Microsoft\Windows\Setup\gwx\refreshgwxconfigandcontent -> Geen bestand <==== AANDACHT
Task: {B6D0B238-479E-47B5-A92F-5AF90FAED1C5} - \Microsoft\Windows\Setup\gwx\refreshgwxconfig -> Geen bestand <==== AANDACHT
Task: {B9981762-6394-41A5-9C2E-6AE5D248CADC} - System32\Tasks\SweetLabs App Platform => C:\Users\Gebruiker\AppData\Local\SweetLabs App Platform\Engine\ServiceHostAppUpdater.exe [2018-03-16] (Pokki)
Task: {BDEAA68A-21A2-453E-9D18-166070AC8383} - \WPD\SqmUpload_S-1-5-21-1014441568-1594974271-3246346139-1001 -> Geen bestand <==== AANDACHT
Task: {BEF8E3DC-CB77-41E6-972D-A351431DE2D1} - \Microsoft\Windows\Setup\gwx\launchtrayprocess -> Geen bestand <==== AANDACHT
Task: {C5AE2318-F58D-4585-9693-C4F5A028A7E9} - System32\Tasks\Recovery Management\Notification => C:\Program Files\Acer\Acer Recovery Management\Notification\Notification.exe [2013-07-10] (Acer Incorporated)
Task: {D2141A64-AFE1-4DA2-91F9-B542A80D86D5} - System32\Tasks\GoogleUpdateTaskMachineUA => C:\Program Files (x86)\Google\Update\GoogleUpdate.exe [2015-08-27] (Google Inc.)
Task: {E067C6DC-3B63-4A58-B842-77C61F6AF40E} - System32\Tasks\AvastUpdateTaskMachineCore => C:\Program Files (x86)\AVAST Software\Browser\Update\AvastBrowserUpdate.exe
Task: {E162798B-7C32-4BB8-AB86-5043010D93FF} - System32\Tasks\Power Management => C:\Program Files\Acer\Acer Power Management\ePowerTray.exe [2013-07-06] (Acer Incorporated)
Task: {E86BBE5F-5E04-454F-A3F5-1C7E3712089E} - System32\Tasks\GoogleUpdateTaskMachineCore => C:\Program Files (x86)\Google\Update\GoogleUpdate.exe [2015-08-27] (Google Inc.)
Task: {EDF8FA18-7B48-46A1-9A1D-9A08D3A266C1} - System32\Tasks\CCleaner Update => C:\Program Files\CCleaner\CCUpdate.exe [2018-04-12] (Piriform Ltd)
Task: {F2FD91EB-AE14-4075-9D3F-F1FE8CE54F20} - System32\Tasks\AVAST Software\Gaming mode Task Scheduler recovery => Command(1): schtasks.exe -> /Change /TN "\Adobe Acrobat Update Task" /ENABLE
Task: {F2FD91EB-AE14-4075-9D3F-F1FE8CE54F20} - System32\Tasks\AVAST Software\Gaming mode Task Scheduler recovery => Command(2): schtasks.exe -> /Change /TN "\CCleanerSkipUAC" /ENABLE
Task: {F2FD91EB-AE14-4075-9D3F-F1FE8CE54F20} - System32\Tasks\AVAST Software\Gaming mode Task Scheduler recovery => Command(3): schtasks.exe -> /Change /TN "\OneDrive Standalone Update Task-S-1-5-21-1014441568-1594974271-3246346139-1001" /ENABLE
Task: {F2FD91EB-AE14-4075-9D3F-F1FE8CE54F20} - System32\Tasks\AVAST Software\Gaming mode Task Scheduler recovery => Command(4): schtasks.exe -> /Change /TN "\AVAST Software\Gaming mode Task Scheduler recovery" /DISABLE
Task: {F609348A-7D0E-4182-BA5B-274716580EED} - System32\Tasks\Adobe Flash Player Updater => C:\WINDOWS\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe [2016-04-19] (Adobe Systems Incorporated)
Task: {F6CCF3F6-0AB8-4DA3-9161-DA953EAEDFCB} - System32\Tasks\CCleanerSkipUAC => C:\Program Files\CCleaner\CCleaner.exe [2018-04-12] (Piriform Ltd)
Task: {F984523E-06A3-4535-A1D6-E98E18266BE8} - System32\Tasks\ALUAgent => C:\Program Files (x86)\Acer\Live Updater\liveupdater_agent.exe [2016-07-06] ()
Task: {F9EE8609-D9BB-4A69-8472-755FB6DE23C2} - \Microsoft\Windows\Setup\GWXTriggers\OutOfIdle-5d -> Geen bestand <==== AANDACHT
(Als een item is opgenomen in de fixlist, wordt de taak (job) bestand verplaatst. Het bestand dat wordt uitgevoerd door de taak zal niet worden verplaatst.)
Task: C:\WINDOWS\Tasks\Adobe Flash Player Updater.job => C:\WINDOWS\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
==================== Snelkoppelingen & WMI ========================
(De items kunnen worden opgenomen in de fixlist.txt om hersteld of verwijderd te worden.)
==================== Geladen Modules (gefilterd) ==============
2018-04-12 01:34 - 2018-04-12 01:34 - 000491744 _____ () C:\Windows\System32\InputHost.dll
2016-12-06 13:06 - 2016-12-06 13:06 - 000897200 _____ () C:\Program Files (x86)\Silhouette America\Silhouette Link\Resources\Resources\SPEC_LK\SilhouetteLinkServer.32.exe
2018-04-12 01:34 - 2018-04-12 01:34 - 000472064 _____ () C:\Windows\ShellExperiences\TileControl.dll
2018-04-12 01:34 - 2018-04-12 01:34 - 002759168 _____ () C:\Windows\ShellComponents\TaskFlowUI.dll
2018-10-09 20:49 - 2018-09-20 05:38 - 002185728 _____ () C:\Windows\SystemApps\Microsoft.Windows.Cortana_cw5n1h2txyewy\Cortana.Core.dll
2013-12-01 11:44 - 2013-07-31 04:11 - 000110152 _____ () C:\Program Files (x86)\Acer\clear.fi plug-in\Clearfishellext_x64.dll
2018-09-21 20:36 - 2018-09-21 20:36 - 000479232 _____ () C:\Program Files\WindowsApps\Microsoft.Windows.Photos_2018.18081.14710.0_x64__8wekyb3d8bbwe\Microsoft.Photos.exe
2018-09-21 20:36 - 2018-09-21 20:36 - 069128192 _____ () C:\Program Files\WindowsApps\Microsoft.Windows.Photos_2018.18081.14710.0_x64__8wekyb3d8bbwe\Microsoft.Photos.dll
2018-09-21 20:36 - 2018-09-21 20:36 - 000010752 _____ () C:\Program Files\WindowsApps\Microsoft.Windows.Photos_2018.18081.14710.0_x64__8wekyb3d8bbwe\RenderingPlugin.dll
2018-04-26 08:08 - 2018-04-26 08:11 - 000009216 _____ () C:\Program Files\WindowsApps\Microsoft.Windows.Photos_2018.18081.14710.0_x64__8wekyb3d8bbwe\ImagePipelineNative.dll
2017-10-05 08:16 - 2017-10-05 08:19 - 002523136 _____ () C:\Program Files\WindowsApps\Microsoft.Windows.Photos_2018.18081.14710.0_x64__8wekyb3d8bbwe\UnityEngineDelegates.dll
2018-08-30 21:11 - 2018-08-30 21:15 - 003699200 _____ () C:\Program Files\WindowsApps\Microsoft.Windows.Photos_2018.18081.14710.0_x64__8wekyb3d8bbwe\MediaEngineCSWrapper.dll
2018-08-17 09:58 - 2018-08-17 09:59 - 002480640 _____ () C:\Program Files\WindowsApps\Microsoft.Windows.Photos_2018.18081.14710.0_x64__8wekyb3d8bbwe\opencv_imgproc320.dll
2018-08-17 09:58 - 2018-08-17 09:59 - 002280960 _____ () C:\Program Files\WindowsApps\Microsoft.Windows.Photos_2018.18081.14710.0_x64__8wekyb3d8bbwe\opencv_core320.dll
2018-08-30 21:12 - 2018-08-30 21:16 - 000035328 _____ () C:\Program Files\WindowsApps\Microsoft.Windows.Photos_2018.18081.14710.0_x64__8wekyb3d8bbwe\WinMLWrapper.UWP.dll
2018-03-30 09:03 - 2018-03-30 09:06 - 002283008 _____ () C:\Program Files\WindowsApps\Microsoft.Windows.Photos_2018.18081.14710.0_x64__8wekyb3d8bbwe\TrackingDLLUWP.dll
2018-09-21 20:36 - 2018-09-21 20:36 - 014171648 _____ () C:\Program Files\WindowsApps\Microsoft.Windows.Photos_2018.18081.14710.0_x64__8wekyb3d8bbwe\PhotosApp.Windows.dll
2018-08-30 21:11 - 2018-08-30 21:16 - 003544576 _____ () C:\Program Files\WindowsApps\Microsoft.Windows.Photos_2018.18081.14710.0_x64__8wekyb3d8bbwe\MediaEngine.dll
2018-09-21 20:36 - 2018-09-21 20:36 - 002866176 _____ () C:\Program Files\WindowsApps\Microsoft.Windows.Photos_2018.18081.14710.0_x64__8wekyb3d8bbwe\AppCore.Windows.dll
2018-08-30 21:12 - 2018-08-30 21:16 - 000973312 _____ () C:\Program Files\WindowsApps\Microsoft.Windows.Photos_2018.18081.14710.0_x64__8wekyb3d8bbwe\RuntimeConfiguration.dll
2018-07-26 11:11 - 2018-07-26 11:11 - 004584960 _____ () C:\Program Files\WindowsApps\Microsoft.Windows.Photos_2018.18081.14710.0_x64__8wekyb3d8bbwe\Microsoft.UI.Xaml.dll
2018-09-21 20:36 - 2018-09-21 20:36 - 000145920 _____ () C:\Program Files\WindowsApps\Microsoft.Windows.Photos_2018.18081.14710.0_x64__8wekyb3d8bbwe\SKU.dll
2018-09-21 20:36 - 2018-09-21 20:36 - 000048128 _____ () C:\Program Files\WindowsApps\Microsoft.Windows.Photos_2018.18081.14710.0_x64__8wekyb3d8bbwe\ImageDecoding.dll
2018-10-24 14:50 - 2018-09-12 11:35 - 002701064 _____ () C:\PROGRAM FILES\MALWAREBYTES\ANTI-MALWARE\SelfProtectionSdk.dll
2018-10-24 14:50 - 2018-09-12 17:57 - 002785784 _____ () C:\PROGRAM FILES\MALWAREBYTES\ANTI-MALWARE\MwacLib.dll
2013-12-01 11:08 - 2013-09-04 01:53 - 001242584 _____ () C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\LMS\ACE.dll
2018-03-06 10:17 - 2018-03-06 10:17 - 067126928 _____ () C:\Program Files\AVAST Software\Avast\libcef.dll
2018-10-22 23:36 - 2018-10-22 23:36 - 000598232 _____ () c:\program files\avast software\avast\streamback.dll
2018-03-16 17:43 - 2018-03-16 17:43 - 044752080 _____ () C:\Users\Gebruiker\AppData\Local\SweetLabs App Platform\Engine\libPokki.dll
2018-03-16 17:44 - 2018-03-16 17:44 - 001413856 _____ () C:\Users\Gebruiker\AppData\Local\SweetLabs App Platform\Engine\avcodec-54.dll
2018-03-16 17:44 - 2018-03-16 17:44 - 000164064 _____ () C:\Users\Gebruiker\AppData\Local\SweetLabs App Platform\Engine\avutil-51.dll
2018-03-16 17:44 - 2018-03-16 17:44 - 000235744 _____ () C:\Users\Gebruiker\AppData\Local\SweetLabs App Platform\Engine\avformat-54.dll
==================== Alternate Data Streams (gefilterd) =========
(Als een item is opgenomen in de fixlist, wordt alleen de ADS verwijderd.)
==================== Veilige Modus (gefilterd) ===================
(Als een item is opgenomen in de fixlist, wordt het uit het register verwijderd. De waarde van "AlternateShell" wordt hersteld.)
HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\MBAMService => ""="Service"
HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\MBAMService => ""="Service"
==================== Bestandskoppeling (gefilterd) ===============
(Als een item is opgenomen in de fixlist, zal het registeritem worden teruggezet naar de standaardwaarden of verwijderd.)
==================== Internet Explorer vertrouwde/beperkte toegang ===============
(Als een item is opgenomen in de fixlist, wordt het uit het register verwijderd.)
==================== Hosts inhoud: ===============================
(Indien nodig kan Hosts:-opdracht worden opgenomen in de fixlist om Hosts te resetten.)
2013-08-22 15:25 - 2013-08-22 15:25 - 000000824 _____ C:\WINDOWS\system32\Drivers\etc\hosts
==================== Andere gebieden ============================
(Momenteel is er geen automatische fix voor dit onderdeel.)
HKU\S-1-5-21-1014441568-1594974271-3246346139-1001\Control Panel\Desktop\\Wallpaper -> C:\Users\Gebruiker\Pictures\vaya en bentley\SL388467bew..jpg
HKU\S-1-5-21-1014441568-1594974271-3246346139-500\Control Panel\Desktop\\Wallpaper -> C:\Windows\web\wallpaper\Windows\img0.jpg
DNS Servers: 62.238.255.69 - 212.115.192.100
HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\System => (ConsentPromptBehaviorAdmin: 5) (ConsentPromptBehaviorUser: 3) (EnableLUA: 1)
HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer => (SmartScreenEnabled: RequireAdmin)
Windows Firewall is ingeschakeld.
==================== MSCONFIG/TASK MANAGER Uitgeschakelde items ==
==================== Firewall regels (gefilterd) ===============
(Als een item is opgenomen in de fixlist, wordt het uit het register verwijderd. Het bestand zal niet worden verplaatst tenzij apart vermeld.)
FirewallRules: [{4C37DA02-AD24-4149-B5CD-6DBCB074D716}] => (Allow) C:\Program Files (x86)\Acer\Acer Portal\ccd.exe
FirewallRules: [{0643D671-C0EA-42C2-BDE7-09494BC50A6F}] => (Allow) C:\Program Files (x86)\Acer\Acer Portal\ccd.exe
FirewallRules: [{78966617-E740-4978-9ADB-D8FFE84E4BB5}] => (Allow) C:\Program Files (x86)\Acer\Acer Portal\virtualdrive.exe
FirewallRules: [{E85F4685-7B1C-4307-9A9D-0AF632A004FC}] => (Allow) C:\Program Files (x86)\Acer\Acer Portal\virtualdrive.exe
FirewallRules: [{B9EF4920-B50D-4256-B48A-23CF9ED065E3}] => (Allow) C:\Program Files (x86)\Acer\Acer Portal\Sdd.exe
FirewallRules: [{6324AEEC-C8C3-4E35-85CB-49EC25114F2F}] => (Allow) C:\Program Files (x86)\Acer\Acer Portal\Sdd.exe
FirewallRules: [{3D018A4C-3B25-44F6-8F39-A7D8B03E7A10}] => (Allow) C:\Program Files (x86)\Acer\Acer Portal\ccd.exe
FirewallRules: [{4B5CADD8-0996-4237-85AE-AF9D9A63DBD4}] => (Allow) C:\Program Files (x86)\Acer\Acer Portal\ccd.exe
FirewallRules: [{19FD6DF6-B278-4A6B-834C-32EA720960EA}] => (Allow) C:\Program Files (x86)\Acer\Acer Photo\WindowsUpnp.exe
FirewallRules: [{7AEBBDB0-3222-4A00-8B2D-BDCED4E4A844}] => (Allow) C:\Program Files (x86)\Acer\Acer Photo\WindowsUpnp.exe
FirewallRules: [{A79CEFB1-42AB-444D-8351-A87690DDF67B}] => (Allow) C:\Program Files (x86)\Acer\Acer Photo\DMCDaemon.exe
FirewallRules: [{23B04FD1-8CA7-4ED7-BAFE-4383DC3F0C92}] => (Allow) C:\Program Files (x86)\Acer\Acer Photo\DMCDaemon.exe
FirewallRules: [{D109A257-F4DC-4DC5-9745-D3435D9764F1}] => (Allow) C:\Program Files (x86)\Acer\Acer Photo\WindowsUpnp.exe
FirewallRules: [{1D6D3382-1AA6-4B1A-88BF-4CFB04CC5D26}] => (Allow) C:\Program Files (x86)\Acer\Acer Photo\WindowsUpnp.exe
FirewallRules: [{A4A02162-014B-4109-B927-FA152C7C0A4A}] => (Allow) C:\Program Files (x86)\Acer\Acer Photo\DMCDaemon.exe
FirewallRules: [{B9325123-E8CB-4630-B7EE-B293EF09AEA8}] => (Allow) C:\Program Files (x86)\Acer\Acer Photo\DMCDaemon.exe
FirewallRules: [{7752E0A3-F7F3-484D-8E37-6FBA24CFC84E}] => (Allow) C:\Program Files (x86)\Acer\Acer Media\WindowsUpnpMV.exe
FirewallRules: [{7318080E-13B6-442D-9B0D-F8382A721939}] => (Allow) C:\Program Files (x86)\Acer\Acer Media\WindowsUpnpMV.exe
FirewallRules: [{27942A0C-FAAD-4B82-ACAD-84F493A81E74}] => (Allow) C:\Program Files (x86)\Acer\Acer Media\DMCDaemon.exe
FirewallRules: [{48D327EE-95E1-40F0-B8BB-44DF546DBF12}] => (Allow) C:\Program Files (x86)\Acer\Acer Media\DMCDaemon.exe
FirewallRules: [{59B8026E-3241-4B6E-ACE1-44B5FA1A68A0}] => (Allow) C:\Program Files (x86)\Acer\Acer Media\WindowsUpnpMV.exe
FirewallRules: [{7B76B7A8-24A8-4C5B-976A-78808B11914F}] => (Allow) C:\Program Files (x86)\Acer\Acer Media\WindowsUpnpMV.exe
FirewallRules: [{0EB3CF50-D640-4C52-B32F-5E7A75C63885}] => (Allow) C:\Program Files (x86)\Acer\Acer Media\DMCDaemon.exe
FirewallRules: [{AD365DD3-2381-4957-B3F9-48A39FA345E3}] => (Allow) C:\Program Files (x86)\Acer\Acer Media\DMCDaemon.exe
FirewallRules: [{F92CB1CC-9D30-4F7F-8C7C-B8B926068D1E}] => (Allow) C:\Program Files (x86)\CyberLink\PowerDVD12\Movie\PowerDVD.exe
FirewallRules: [{1BD017FE-DC11-447C-B96C-99BCC7E65D79}] => (Allow) C:\Program Files (x86)\CyberLink\PowerDVD12\PowerDVD12ML.exe
FirewallRules: [{04EC527C-48C1-4565-8485-10D4E4703613}] => (Allow) C:\Program Files (x86)\CyberLink\PowerDVD12\PowerDVD12.exe
FirewallRules: [{43150078-9F69-4DC0-834E-804B7AB2993F}] => (Allow) C:\Program Files (x86)\Nero\Nero 12\Nero BackItUp\BackItUp.exe
FirewallRules: [{2609FBA7-671A-4BC6-9F91-730E2E3050C5}] => (Allow) C:\Program Files (x86)\Nero\Nero 12\Nero BackItUp\BackItUp.exe
FirewallRules: [{475482B8-E1D6-498B-817A-4680BC931B3D}] => (Allow) C:\Program Files (x86)\Windows Live\Contacts\wlcomm.exe
FirewallRules: [{CAE04DFC-7D67-4284-A736-772B2A396A4D}] => (Allow) LPort=2869
FirewallRules: [{0AB420C0-8B15-4D3B-9210-5B171C4B05D9}] => (Allow) LPort=1900
FirewallRules: [{EA7CF7B9-F3A9-4F93-8E2D-480FA4564360}] => (Allow) C:\Program Files (x86)\Windows Live\Messenger\msnmsgr.exe
FirewallRules: [{2FF45AF8-6D7E-424E-A9EF-D48568513AD2}] => (Allow) C:\Program Files (x86)\Silhouette America\Silhouette Link\SilhouetteLinkConsole.exe
FirewallRules: [{D5D3D185-6806-4A51-A111-90DD4A754C2A}] => (Allow) C:\Program Files (x86)\Silhouette America\Silhouette Link\Resources\Resources\SPEC_LK\SilhouetteLinkServer.32.exe
FirewallRules: [{2A5DB7AC-B57A-492D-BC0C-965AF8ABBA4E}] => (Allow) C:\Program Files (x86)\Google\Chrome\Application\chrome.exe
FirewallRules: [{16C4A00C-78EB-4A34-A677-B5582614CD73}] => (Allow) C:\Program Files\AVAST Software\Avast\AvEmUpdate.exe
FirewallRules: [{BD976AE6-1CF9-4E4F-931E-6DA0551CB321}] => (Allow) C:\Program Files\AVAST Software\Avast\AvEmUpdate.exe
==================== Herstelpunten =========================
30-09-2018 11:47:27 Installatieprogramma voor Windows-modules
08-10-2018 21:30:54 Gepland controlepunt
13-10-2018 10:10:44 Windows Update
21-10-2018 22:41:42 Gepland controlepunt
==================== Defecte Apparaatbeheer Apparaten =============
==================== Eventlog fouten: =========================
Applicatiefouten:
Error: (10/24/2018 02:51:13 PM) (Source: Application Error) (EventID: 1000) (User: )
Description: Naam van toepassing met fout: mbamtray.exe, versie: 3.1.0.1614, tijdstempel: 0x5b9bcc06
Naam van module met fout: Qt5Core.dll, versie: 5.11.1.0, tijdstempel: 0x5b9bc256
Uitzonderingscode: 0xc0000005
Foutmarge: 0x0019d749
Id van proces met fout: 0x14ac
Starttijd van toepassing met fout: 0x01d46b983ad33129
Pad naar toepassing met fout: C:\Program Files\Malwarebytes\Anti-Malware\mbamtray.exe
Pad naar module met fout: C:\Program Files\Malwarebytes\Anti-Malware\Qt5Core.dll
Rapport-id: d19d5140-99b5-4ac8-b689-72e55b4eef55
Volledige pakketnaam met fout:
Relatieve toepassings-id van pakket met fout:
Error: (10/24/2018 02:32:20 PM) (Source: Microsoft-Windows-SpellChecker) (EventID: 33) (User: ACER)
Description: brave hendrikbrave hendrik-2147467263
Error: (10/24/2018 02:31:54 PM) (Source: Microsoft-Windows-SpellChecker) (EventID: 33) (User: ACER)
Error: (10/24/2018 12:44:07 PM) (Source: Microsoft-Windows-SpellChecker) (EventID: 33) (User: ACER)
Error: (10/24/2018 12:18:09 PM) (Source: Application Error) (EventID: 1000) (User: )
Description: Naam van toepassing met fout: svchost.exe_WpnUserService, versie: 10.0.17134.1, tijdstempel: 0xa38b9ab2
Naam van module met fout: NotificationController.dll, versie: 10.0.17134.165, tijdstempel: 0xe0385185
Foutmarge: 0x000000000007a24d
Id van proces met fout: 0x1f8c
Starttijd van toepassing met fout: 0x01d46b7ca01ac741
Pad naar toepassing met fout: C:\WINDOWS\system32\svchost.exe
Pad naar module met fout: C:\Windows\System32\NotificationController.dll
Rapport-id: 470b1242-3316-47d4-b899-cadaf16f4b31
Error: (10/24/2018 11:33:10 AM) (Source: Application Error) (EventID: 1000) (User: )
Id van proces met fout: 0x3128
Starttijd van toepassing met fout: 0x01d46b7870eb74f2
Rapport-id: a472f7ff-81aa-4b95-80b6-0d10f45ecd9f
Error: (10/24/2018 11:02:00 AM) (Source: Application Error) (EventID: 1000) (User: )
Foutmarge: 0x000000000007c686
Id van proces met fout: 0x1c08
Starttijd van toepassing met fout: 0x01d46b74cdf24a72
Rapport-id: 53e9419d-c246-43a1-8de3-f3159ff42b27
Error: (10/24/2018 10:37:19 AM) (Source: Microsoft-Windows-SpellChecker) (EventID: 33) (User: ACER)
Systeemfouten:
Error: (10/24/2018 02:29:55 PM) (Source: DCOM) (EventID: 10016) (User: NT AUTHORITY)
Description: In de machtigingsinstellingen toepassingsspecifiek wordt de machtiging Activeren niet verleend aan Lokaal voor de COM-servertoepassing met CLSID
{D63B10C5-BB46-4990-A94F-E40B9D520160}
en APPID
{9CA88EE3-ACB7-47C8-AFC4-AB702511C276}
aan de gebruiker NT AUTHORITY\LOCAL SERVICE SID (S-1-5-19) met het adres LocalHost (via LRPC) die wordt uitgevoerd in de toepassingscontainer Niet beschikbaar SID (Niet beschikbaar). Deze beveiligingsmachtiging kan worden gewijzigd met het beheerprogramma van Component Services.
Error: (10/24/2018 02:18:07 PM) (Source: DCOM) (EventID: 10016) (User: NT AUTHORITY)
en APPID
Error: (10/24/2018 02:15:47 PM) (Source: DCOM) (EventID: 10016) (User: NT AUTHORITY)
en APPID
Error: (10/24/2018 02:13:02 PM) (Source: DCOM) (EventID: 10016) (User: ACER)
en APPID
aan de gebruiker Acer\Gebruiker SID (S-1-5-21-1014441568-1594974271-3246346139-1001) met het adres LocalHost (via LRPC) die wordt uitgevoerd in de toepassingscontainer Niet beschikbaar SID (Niet beschikbaar). Deze beveiligingsmachtiging kan worden gewijzigd met het beheerprogramma van Component Services.
Error: (10/24/2018 12:24:13 PM) (Source: DCOM) (EventID: 10001) (User: ACER)
Description: Kan DCOM Server Microsoft.WebMediaExtensions_1.0.12341.0_x64__8wekyb3d8bbwe!App.AppX5mvjzgfkp7zwcj41y2acxgs5c976dxda.mca niet starten als Niet beschikbaar/Niet beschikbaar. Foutmelding
"0"
is opgetreden bij het uitvoeren van de opdracht
"C:\WINDOWS\system32\backgroundTaskHost.exe" -ServerName:App.AppXr6cxj2m7qt53ysmsgy75gtey09djqa6k.mca
"0"
"0"
"0"
Windows Defender:
Date: 2018-09-30 21:18:35.841
Description:
Scan van Windows Defender Antivirus is gestopt voordat deze was voltooid.
Scan-id: {C475BDB5-3D4B-488C-A2CB-2C1FEFD204BA}
Type scan: Antimalware
Scanparameters: Snelle scan
Gebruiker: NT AUTHORITY\SYSTEM
Date: 2018-09-30 18:37:04.270
Description:
Scan-id: {E919C3A3-C170-4F8D-A8C6-C7B6EC505028}
Date: 2018-09-30 18:29:15.373
Description:
Scan-id: {A8AA9415-0AEF-4F09-BD3B-1F203C50A5FC}
Date: 2018-09-30 16:58:06.906
Description:
Scan-id: {0C94E0ED-DBCC-43A5-8CF8-0AC066BACE99}
Date: 2018-09-30 16:36:50.254
Description:
Scan-id: {F0B0384A-87BA-4458-835D-293EEF43A214}
CodeIntegrity:
Date: 2018-10-24 15:10:26.906
Description:
Code Integrity determined that a process (\Device\HarddiskVolume4\Windows\SystemApps\Microsoft.MicrosoftEdge_8wekyb3d8bbwe\MicrosoftEdgeCP.exe) attempted to load \Device\HarddiskVolume4\Program Files\Malwarebytes\Anti-Malware\mbae64.dll that did not meet the Store signing level requirements.
Date: 2018-10-24 15:10:02.899
Description:
Date: 2018-10-24 15:08:45.256
Description:
Code Integrity determined that a process (\Device\HarddiskVolume4\Program Files\AVAST Software\Avast\wsc_proxy.exe) attempted to load \Device\HarddiskVolume4\Program Files\AVAST Software\Avast\dbghelp.dll that did not meet the Custom 3 / Antimalware signing level requirements.
Date: 2018-10-24 15:08:42.827
Description:
Date: 2018-10-24 15:08:41.033
Description:
Date: 2018-10-24 14:53:25.870
Description:
Date: 2018-10-24 14:53:09.734
Description:
Date: 2018-10-24 14:51:15.175
Description:
==================== Geheugen info ===========================
Processor: Intel(R) Pentium(R) CPU 2117U @ 1.80GHz
Percentage geheugen in gebruik: 67%
Totaal fysiek RAM-geheugen: 3985.27 MB
Beschikbaar fysiek RAM-geheugen: 1275.8 MB
Totaal Virtueel geheugen: 6929.27 MB
Beschikbaar Virtueel geheugen: 3318.2 MB
==================== Schijven ================================
Drive c: (Acer) (Fixed) (Total:447.79 GB) (Free:338.86 GB) NTFS
\\?\Volume{19ca0b02-e39c-4a82-aa9c-63349851c653}\ (Recovery) (Fixed) (Total:0.39 GB) (Free:0.11 GB) NTFS
\\?\Volume{fc4c8478-cb71-4199-87fb-e0c750228078}\ () (Fixed) (Total:0.9 GB) (Free:0.45 GB) NTFS
\\?\Volume{34f2bcce-4850-43c0-8f51-06447f20075f}\ (Push Button Reset) (Fixed) (Total:16.26 GB) (Free:1.34 GB) NTFS
\\?\Volume{068383fa-90f9-423e-93f4-acee5237284c}\ (ESP) (Fixed) (Total:0.29 GB) (Free:0.24 GB) FAT32
==================== MBR & Partitietabel ==================
Disk: 0 (Protective MBR) (Size: 465.8 GB) (Disk ID: 00000000)
Partition: GPT.
==================== Eind van Addition.txt ============================
Twee opmerkingen:
a) Windows 10 is een upgrade vanuit Windows 7.
- het is daarom tijd voor een schone installatie van Windows 10 - zal het tempo ook bevorderen!
b) Office 2000 is niet echt compatibel met Windows 10.
Compatibel zijn die versies vanaf Office 2010.
We gaan
Kopieer en plak de tekst in het code-venster vanaf het woord Code in het lege kladblokvenster.
Code:
start
CreateRestorePoint:
(Pokki) C:\Users\Gebruiker\AppData\Local\SweetLabs App Platform\Engine\ServiceHostApp.exe
(Pokki) C:\Users\Gebruiker\AppData\Local\SweetLabs App Platform\Engine\ServiceHostAppUpdater.exe
HKLM-x32\...\Run: [QuickTime Task] => C:\Program Files (x86)\QuickTime\QTTask.exe [413696 2008-09-06] (Apple Inc.)
Toolbar: HKU\S-1-5-21-1014441568-1594974271-3246346139-1001 -> Geen Naam - {2318C2B1-4965-11D4-9B18-009027A5CD4F} - Geen bestand
FF HKLM\...\Firefox\Extensions: [{4ED1F68A-5463-4931-9384-8FFF5ED91D92}] - C:\Program Files (x86)\McAfee\SiteAdvisor\saffplg.xpi => niet gevonden
FF HKLM-x32\...\Firefox\Extensions: [{4ED1F68A-5463-4931-9384-8FFF5ED91D92}] - C:\Program Files (x86)\McAfee\SiteAdvisor\saffplg.xpi => niet gevonden
FF HKLM-x32\...\Thunderbird\Extensions: [msktbird@mcafee.com] - C:\Program Files\McAfee\MSK => niet gevonden
FF Plugin: @adobe.com/FlashPlayer -> C:\WINDOWS\system32\Macromed\Flash\NPSWF64_18_0_0_160.dll [2016-04-19] ()
FF Plugin: @mcafee.com/MSC,version=10 -> C:\Program Files\mcafee\msc\npMcSnFFPl64.dll [Geen bestand]
FF Plugin-x32: @adobe.com/FlashPlayer -> C:\WINDOWS\SysWOW64\Macromed\Flash\NPSWF32_18_0_0_160.dll [2016-04-19] ()
FF Plugin-x32: @mcafee.com/MSC,version=10 -> C:\Program Files (x86)\McAfee\msc\npMcSnFFPl.dll [Geen bestand]
CHR HKLM\...\Chrome\Extension: [fheoggkfdfchfphceeifdbepaooicaho] - C:\Program Files (x86)\McAfee\SiteAdvisor\McChPlg.crx <niet gevonden>
CHR HKLM-x32\...\Chrome\Extension: [eofcbnmajmjmplflapaojjnihcjkigck] - C:\Program Files\AVAST Software\Avast\WebRep\Chrome\aswWebRepChromeSp.crx <niet gevonden>
CHR HKLM-x32\...\Chrome\Extension: [fheoggkfdfchfphceeifdbepaooicaho] - C:\Program Files (x86)\McAfee\SiteAdvisor\McChPlg.crx <niet gevonden>
CHR HKLM-x32\...\Chrome\Extension: [gomekmidlodglbbmalcneegieacbdmki] - C:\Program Files\AVAST Software\Avast\WebRep\Chrome\aswWebRepChrome.crx <niet gevonden>
R2 SilhouetteLink; C:\Program Files (x86)\Silhouette America\Silhouette Link\Resources\Resources\SPEC_LK\SilhouetteLinkServer.32.exe [897200 2016-12-06] ()
EmptyTemp:
CloseProcesses:
cmd: ipconfig /flushdns
cmd: netsh winsock reset
end
  • Druk op de Fix knop.
schults2005
schults2005
#5
Abraham
Zal even duren, want ik,lees het nu pas en mijn vrouw is nu,druk bezig de laptop te gebruiken samen met haar cameo (soort snijplotter)
schults2005
schults2005
#6
was vergeten dat er ooit office opgezet was, zal straks eens verwijderen. hier de log txt
Fix resultaat van Farbar Recovery Scan Tool (x64) Versie: 24.10.2018
Gestart door Gebruiker (25-10-2018 13:55:14) Run:1
Geladen Profielen: Gebruiker (Beschikbare Profielen: Gebruiker & Administrator)
Boot Modus: Normal
fixlist inhoud:
start
CreateRestorePoint:
EmptyTemp:
CloseProcesses:
end
Herstelpunt is succesvol gemaakt.
C:\Users\Gebruiker\AppData\Local\SweetLabs App Platform\Engine\ServiceHostApp.exe => Geen lopend proces gevonden
C:\Users\Gebruiker\AppData\Local\SweetLabs App Platform\Engine\ServiceHostAppUpdater.exe => Geen lopend proces gevonden
"HKLM\Software\WOW6432Node\Microsoft\Windows\CurrentVersion\Run\\QuickTime Task" => is succesvol verwijderd
"C:\Program Files (x86)\QuickTime" map verplaatsing:
Kon niet verplaatsen "C:\Program Files (x86)\QuickTime" => Gepland om te verplaatsen bij herstart.
"HKU\S-1-5-21-1014441568-1594974271-3246346139-1001\Software\Microsoft\Internet Explorer\Toolbar\WebBrowser\\{2318C2B1-4965-11D4-9B18-009027A5CD4F}" => is succesvol verwijderd
HKLM\Software\Classes\CLSID\{2318C2B1-4965-11D4-9B18-009027A5CD4F} => niet gevonden
"HKLM\Software\Mozilla\Firefox\Extensions\\{4ED1F68A-5463-4931-9384-8FFF5ED91D92}" => is succesvol verwijderd
"HKLM\Software\Wow6432Node\Mozilla\Firefox\Extensions\\{4ED1F68A-5463-4931-9384-8FFF5ED91D92}" => is succesvol verwijderd
"HKLM\Software\Wow6432Node\Mozilla\Thunderbird\Extensions\\msktbird@mcafee.com" => is succesvol verwijderd
HKLM\Software\MozillaPlugins\@adobe.com/FlashPlayer => is succesvol verwijderd
C:\WINDOWS\system32\Macromed\Flash\NPSWF64_18_0_0_160.dll => is succesvol verplaatst
HKLM\Software\MozillaPlugins\@mcafee.com/MSC,version=10 => is succesvol verwijderd
HKLM\Software\Wow6432Node\MozillaPlugins\@adobe.com/FlashPlayer => is succesvol verwijderd
C:\WINDOWS\SysWOW64\Macromed\Flash\NPSWF32_18_0_0_160.dll => is succesvol verplaatst
HKLM\Software\Wow6432Node\MozillaPlugins\@mcafee.com/MSC,version=10 => is succesvol verwijderd
HKLM\SOFTWARE\Google\Chrome\Extensions\fheoggkfdfchfphceeifdbepaooicaho => is succesvol verwijderd
HKLM\SOFTWARE\Wow6432Node\Google\Chrome\Extensions\eofcbnmajmjmplflapaojjnihcjkigck => is succesvol verwijderd
HKLM\SOFTWARE\Wow6432Node\Google\Chrome\Extensions\fheoggkfdfchfphceeifdbepaooicaho => is succesvol verwijderd
HKLM\SOFTWARE\Wow6432Node\Google\Chrome\Extensions\gomekmidlodglbbmalcneegieacbdmki => is succesvol verwijderd
SilhouetteLink => Kon service niet stoppen.
HKLM\System\CurrentControlSet\Services\SilhouetteLink => is succesvol verwijderd
SilhouetteLink => dienst is succesvol verwijderd
Facebook (HKU\S-1-5-21-1014441568-1594974271-3246346139-1001\...\Pokki_a65116cdc0b4377bed428e280c19949d56248d11) (Version: 1.1.4 - SweetLabs) => Fout: Geen automatische fix gevonden voor dit item.
Host App Service (HKU\S-1-5-21-1014441568-1594974271-3246346139-1001\...\SweetLabs_AP) (Version: 0.269.8.414 - Pokki) <==== AANDACHT => Fout: Geen automatische fix gevonden voor dit item.
Proces succesvol afgesloten.
========= ipconfig /flushdns =========
Windows IP Configuration
========= Eind van CMD: =========
========= netsh winsock reset =========
Sucessfully reset the Winsock Catalog.
You must restart the computer in order to complete the reset.
=========== EmptyTemp: ==========
BITS transfer queue => 7888896 B
DOMStore, IE Recovery, AppCache, Feeds Cache, Thumbcache, IconCache => 386646205 B
Java, Flash, Steam htmlcache => 291 B
Windows/system/drivers => 31400245 B
Edge => 375530823 B
Chrome => 19818998 B
Firefox => 0 B
Opera => 0 B
Temp, IE cache, history, cookies, recent:
Default => 0 B
Users => 0 B
ProgramData => 0 B
Public => 0 B
systemprofile => 0 B
systemprofile32 => 0 B
LocalService => 17352 B
LocalService => 0 B
NetworkService => 10712 B
NetworkService => 0 B
Gebruiker => 35422532 B
Administrator => 12245 B
RecycleBin => 86722059 B
EmptyTemp: => 899.8 MB tijdelijke gegevens verwijderd.
Resultaat van geplande bestanden te verplaatsen (Boot Modus: Normal) (Datum&Tijd: 25-10-2018 14:03:55)
C:\Program Files (x86)\QuickTime => is succesvol verplaatst
==== Eind van Fixlog 14:03:56 ====
AdwCleaner by Malwarebytes naar het bureaublad.
Als administrator uitvoeren.
  • Klik vervolgens op de knop Nu scannen.
  • Wanneer de scan gereed is klikt u vervolgens op de knop Reiniging en Reparaties.
  • Klik vervolgens in het informatiescherm op Schoonmaken en nu opnieuw opstarten.
  • Nadat de computer opnieuw is opgestart wordt AdwCleaner automatisch geopend, klik op Logbestand bekijken.
  • (Dit logbestand kunt u tevens terug vinden op de systeemschijf als C:\AdwCleaner\Logs\AdwCleaner[C00].txt.)
schults2005
schults2005
#8
de uitdraai.
# Malwarebytes AdwCleaner 7.2.4.0
# Build: 09-25-2018
# Database: 2018-10-23.1 (Cloud)
# Support: https://www.malwarebytes.com/support
# Mode: Clean
# Start: 10-25-2018
# Duration: 00:02:14
# OS: Windows 10 Home
# Cleaned: 39
# Failed: 0
***** [ Services ] *****
No malicious services cleaned.
***** [ Folders ] *****
Deleted C:\Users\Public\Pokki
Deleted C:\Users\Administrator\AppData\Local\Pokki
Deleted C:\Users\Gebruiker\AppData\Local\Pokki
Deleted C:\Users\Gebruiker\AppData\Local\SweetLabs App Platform
***** [ Files ] *****
Deleted C:\Users\Gebruiker\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Facebook.lnk
Deleted C:\Users\Public\Desktop\eBay.lnk
Deleted C:\Windows\System32\Tasks_Migrated\SweetLabs App Platform
Deleted C:\Users\Gebruiker\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\PC App Store.lnk
***** [ DLL ] *****
No malicious DLLs cleaned.
***** [ WMI ] *****
No malicious WMI cleaned.
***** [ Shortcuts ] *****
No malicious shortcuts cleaned.
***** [ Tasks ] *****
Deleted C:\Windows\System32\Tasks\SweetLabs App Platform
***** [ Registry ] *****
Deleted HKCU\Software\SweetLabs App Platform
Deleted HKCU\Software\Classes\lnkfile\shell\pokki
Deleted HKCU\Software\Classes\Drive\shell\pokki
Deleted HKCU\Software\Classes\Directory\shell\pokki
Deleted HKCU\Software\Classes\AllFileSystemObjects\shell\pokki
Deleted HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Pokki_a65116cdc0b4377bed428e280c19949d56248d11
Deleted HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Pokki_03d432a7e610c3e908213e7689d4342ce2111caf
Deleted HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppContainer\Storage\microsoft.microsoftedge_8wekyb3d8bbwe\Children\001\Internet Explorer\DOMStorage\vertalen.babylon-software.com
Deleted HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppContainer\Storage\microsoft.microsoftedge_8wekyb3d8bbwe\Children\001\Internet Explorer\DOMStorage\babylon-software.com
Deleted HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppContainer\Storage\microsoft.microsoftedge_8wekyb3d8bbwe\Children\001\Internet Explorer\EdpDomStorage\vertalen.babylon-software.com
Deleted HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppContainer\Storage\microsoft.microsoftedge_8wekyb3d8bbwe\Children\001\Internet Explorer\EdpDomStorage\babylon-software.com
Deleted HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppContainer\Storage\microsoft.microsoftedge_8wekyb3d8bbwe\Children\001\Internet Explorer\DOMStorage\www.banggood.com
Deleted HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppContainer\Storage\microsoft.microsoftedge_8wekyb3d8bbwe\Children\001\Internet Explorer\DOMStorage\eu.banggood.com
Deleted HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppContainer\Storage\microsoft.microsoftedge_8wekyb3d8bbwe\Children\001\Internet Explorer\DOMStorage\banggood.com
Deleted HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppContainer\Storage\microsoft.microsoftedge_8wekyb3d8bbwe\Children\001\Internet Explorer\EdpDomStorage\www.banggood.com
Deleted HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppContainer\Storage\microsoft.microsoftedge_8wekyb3d8bbwe\Children\001\Internet Explorer\EdpDomStorage\eu.banggood.com
Deleted HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppContainer\Storage\microsoft.microsoftedge_8wekyb3d8bbwe\Children\001\Internet Explorer\EdpDomStorage\banggood.com
Deleted HKCU\Software\Microsoft\Windows\CurrentVersion\Uninstall\SweetLabs_AP
Deleted HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{B9981762-6394-41A5-9C2E-6AE5D248CADC}
Deleted HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\SweetLabs App Platform
Deleted HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppContainer\Storage\microsoft.microsoftedge_8wekyb3d8bbwe\Children\001\Internet Explorer\DOMStorage\nl.ask.com
Deleted HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppContainer\Storage\microsoft.microsoftedge_8wekyb3d8bbwe\Children\001\Internet Explorer\DOMStorage\ask.com
Deleted HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppContainer\Storage\microsoft.microsoftedge_8wekyb3d8bbwe\Children\001\Internet Explorer\EdpDomStorage\nl.ask.com
Deleted HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppContainer\Storage\microsoft.microsoftedge_8wekyb3d8bbwe\Children\001\Internet Explorer\EdpDomStorage\ask.com
Deleted HKCU\Software\Microsoft\Internet Explorer\SearchScopes\{AA9A4890-4262-4441-8977-E2FFCBFB706C}
Deleted HKLM\Software\Wow6432Node\Microsoft\Internet Explorer\SearchScopes\{AA9A4890-4262-4441-8977-E2FFCBFB706C}
Deleted HKLM\Software\Microsoft\Internet Explorer\SearchScopes\{AA9A4890-4262-4441-8977-E2FFCBFB706C}
***** [ Chromium (and derivatives) ] *****
No malicious Chromium entries cleaned.
***** [ Chromium URLs ] *****
Deleted https://homepage-web.com/?s=acer&m=start
Deleted https://homepage-web.com/?s=acer&m=home
Deleted Web Search
***** [ Firefox (and derivatives) ] *****
No malicious Firefox entries cleaned.
***** [ Firefox URLs ] *****
No malicious Firefox URLs cleaned.
[+] Delete Tracing Keys
[+] Reset Winsock
AdwCleaner[S00].txt - [6725 octets] - [25/10/2018 16:19:40]
########## EOF - C:\AdwCleaner\Logs\AdwCleaner[C00].txt ##########
schults2005
schults2005
#10
Geef nu eerst een update hoe Windows nu draait in die laptop van jouw vrouw.
En een vraag: hoeveel e-mailaccounts heeft zij in Outlook 2000 zitten,
want is het er één of zijn het twee, dan is eM Client als gratis e-mailprogramma de oplossing!
https://www.schoonepc.nl/tools/emclient.html
En als Office pakket adviseer ik de gratis versie van Softmakers Free Office 2018.
https://www.piepcomp.nl/threads/softmakers-nieuwe-en-gratis-versie-office-2018.6036/
volgens haar werkt de laptop nu beter.
ze heeft Hotmail en gmail, maar die laatste gebruik ze niet meer. En kan dus opgedoekt worden.
ze had alleen ofice omdat ze een keer een excel bestand kreeg wat ze wilde lezen.
intussen office verwijderd.
werkt softmakers prettiger dan apache ? heb zelf apache en bevalt m niet maar ja ik heb ook ruim 20 jaar op kantoor met ms office gewerkt :)
vreemd is wel, dat ik 's-avonds laat via tablet kijk of je een reactie geplaatst hebt en dan niets zie staan. nu al 2x gebeurd.
Groet Chris
PS net even in outlook gekeken maar gmail is niet gekoppeld, dus bevat outlook alleen haar Hotmail account voor zover ik kan zien. zijn geen anere accounts gekoppeld.
Softmaker Free Office 2018 kan met Lint zoals de moderne Office pakketten van MS werken, dan wel ingesteld worden met de oude balken, zoals MS Office 2000 en 2003 hadden.
Bovendien is Free Office 2018 volledig compatibel met de moderne Office pakketten van MS.
Heb je aan Word, Excel en PowerPoint genoeg, dan is Free Office 2018 de beste kandidaat om als gratis pakket kantoorsoftware te gebruiken.
eM Client kan je zien als verbetering van de moderne Oulook versies en is, nogmaals, gratis te gebruiken met één - of twee e-mailaccounts.
Wat betreft Free Office 2018 - zodra ik Linux Mint als dualboot erbij heb, zal ik een uitgebreide handleiding voor dit kantoorpakket gaan maken.
We gaan opruimen.
Tip: hou MBAM als ondemand scanner in jouw Windows erbij voor een wekelijkse scan ermee.
Mocht je onverhoopt in de toekomst via een van de scans weer een virus vinden, meld je dan terug in een nieuw topic.
Delfix by Xplode naar het bureaublad.
Delfix by Xplode opstarten:
  • Windows 2000 en Windows XP: dubbelklik op delfix.exe.
  • Windows Vista, Windows 7, Windows 8 en Windows 10 rechtsklik op delfix.exe en kies "Als Administrator uitvoeren".
Zet nu vinkjes voor de volgende items:
  • Remove disinfection tools
  • Purge System Restore
  • Reset system settings
Klik nu op "Run" en wacht geduldig tot de tool gereed is.
Wanneer het tool gereed is wordt er een logbestand aangemaakt. Dit hoeft jij echter niet te plaatsen.
Start jouw computer hierna opnieuw op, indien er daarna nog programma's of log bestanden aanwezig zijn, mag je die handmatig verwijderen.
Maak daarna desgewenst een nieuw herstelpunt aan.
Overigens zal Windows normaal gesproken dit na de herstart ook gedaan hebben.
schults2005
schults2005
#14
als ik even wer de laptop mag gebruiken zal ik die stap ook nog doen.
heb office pakket gedownload ziet er prettiger uit dan die apache versie.
ier is trouwens ook een versie voor anroid van.
Een stagiair op mijn werk heeft hetzelfde pakket ook in zijn notebook gezet en vind het zelfs prettiger werken dan MS Office.
schults2005
schults2005
#16
Toch hier nog 1 vraagje. Denk je dat er een ssd in te zetten is in plaats van hd en dat eea daarmee ook sneller zal gaan. Groet Chris
Een SSD zal een verademing zijn inderdaad.
Je kan Windows vanaf de HD klonen naar de SSD, maar let wel, een schone installatie van Windows op de SSD maakt dat Windows dan sneller is.
Doe nu eerst het volgende in de betreffende laptop:
post enkel de link, die je via onderstaand tool verkrijgt.
Speccy van Piriform
  • Bevestig dat eerste dus.
