Adaware: nieuwe versies, taalinstellingen,...
Er is een nieuwe versie van Adaware, Adaware 6 SE Personal Edition, beschikbaar.
# Adaware 6 SE Personal Edition#
Status: Freeware. Adaware SE Personal Edition is gratis voor persoonlijk gebruik
Besturingssystemen:alle Windows behalve Win95
Homepage: Lavasoft
Alternatieve downloadlink: Majorgeeks
downl.grootte: +/- 2,5 MB
What's new in Ad-Aware SE Personal edition?
Hardened against third party uninstall with encrypted preference files
Scanning engine improvements
- Extended protection against DLL-injection, SE can unload process modules on the fly
- Extended Memory scanning
- Now scans all modules loaded by a process
- Uses our all new CSI (Code Sequence Identification) technology to identify new and unknown variants of known targets
Extended Registry scanning
- Now scans registry branches of multiple user accounts
- Performs additional smart checks to detect dynamically created references
- Scanning speed noticeably faster
- Extended Scanning for known and unknown/possible Browser-Hijackers
Extended Disk scanning
- Now scans and lists alternate Data-streams on NTFS volumes
- Now Ad-Aware supports scanning of Cabinet files, (including spanned archives)
- Scanning speed increased
- Improved Hosts-file scan
- Now Ad-Aware and Ad-Watch Use much smaller reference files
Several User Interface improvements
- Improved Graphical UI
- Ad-Aware now supports custom graphical Skins
- More user friendly Plug-in/Extension GUI (Plug-ins and Extensions now shown on separate screens)
- New Scan Result view, includes a scan summary and detailed view
- Ad-Aware now linked to the online TAC database
Multiple New Tweak options
- Unloading of process modules during a scan
- Obtaining command line of scanned processes
- Ignoring spanned cab files
- Permanent archive caching
- Always try to unload modules before deletion
- Disable manual quarantine if auto quarantine is selected
- Write protect system files after repair
- Use gridlines in item lists
- Log file detail section condensed
Several logfile improvements
- Includes support for separate removal logfiles
- Allows adding a Reference summary/index to logfiles
- Logfile contains overall more detailed information
Bron: Hulpbestand bij de nieuwe Adaware SE
Wel dient de oude versie eerst verwijderd te worden vooraleer de nieuwe succesvol geïnstalleerd kan worden. Dit kan je ook automatisch laten doen" tijdens de installatie van de nieuwe :)
*Kingpin*
#3
Enkele screenshots :)
- Instellingen van de scanopties blijven eigenlijk hetzelfde als bij de vorige versie
- Er worden meer bestanden gescand en ook beter (net nog met de oude versie (geupdate) gescand en die gaf niets aan , deze geeft wel enkele 'kwalijke' objecten aan
- Hou best wel de backups nog even bij, je weet maar nooit met nieuwe versies of er evtl bugs zijn, false positives, te agressieve cleaning, ... :ph34r:
*Kingpin*
#4
normaal doe je zo'n topic toch closed?
Hoi anja :)
Bij viruswaarsch. ed idd wel, maar dit staat nog open voor aanvullingen :)
Bvendien was er blijkb iets foutgelopen en kan ik het eerste bericht niet meer bewerken of sluiten :huh:
Maar voorlopig nog even open voor evtle opmerkingen, toevoegingen en verdere info :)
*Kingpin*
#5
Hoi zodiac :D
haha dan ben ik toch niet de enige :lol: ik durfde de afbeelding van het resultaat bij mij hierboven al niet als screenshot erbij plaatsen :lol: ;)
Hij scant wel goed he, amai :)
*Kingpin*
#7
Hoi Diederik :)
dat slaat terug op de MRU-bestanden (dat wat je bij start terugvindt bij "onlangs geopend" ed)
Het zijn geen echte risico's in de zin van echte spyware ofz, maar toch worden ze als 'risk' aangeduid omdat het op privacy-vlak wel wel "gevaarlijk" zou kunnen zijn omdat andere gebruikers op je pc die na jou komen, via die MRU lijst kunnen zien wat jij onlangs geopend hebt enzo.. Niet iedereen wil dat anderen achter gen zien wat zun geopend hebben gehad :rolleyes: :lol: is eigenlijk ook soort spionage dan maar van mensen die achter jou op je pc komen..
maar is dus geen echt gevaar ofzo, enkel voor privacy-redenen evtl, je hoeft die optie dan ook niet aan te vinken eigenlijk ... :)
*Kingpin*
*Kingpin*
Nieuwe versie Adaware SE beschikbaar: Ad-Aware SE Personal 1.04
Homepage: Lavasoft
(server Lavasoft op dit moment overbezet, mogelijk niet (goed) bereikbaar => via Majorgeeks of wachten :) )
Announcing the next build of Ad-Aware SE 1.04
1.04 contains some updates, changes and minor corrections. For more details please see the changelog below.
It is essential that you always use the latest build and definition file.
To download build 1.04 please use the same download location or link you have used to download previous updates.
Changelog Ad-Aware SE 1.04
Updates
- Minor graphical GUI changes/updates.
- Additional textual changes and updates to GUI and Manual.
- Additional support for skinning implemented.
- Several improvements concerning the installer.
- Each Add-on now has it's own helpfile.
- Ad-Aware now uses the default browser to show online content.
- Additional tracking-cookie information is written to logfile.
Changes
- Ad-Watch no longer blocks IE from running in full screen mode if initiated by the user.
- The context menu in quarantine is now disabled if no items are present.
- Jump To Key now disabled if no path to RegHance is set.
- Changing the location for event history will now be rememberd after restaring Ad-Watch.
- Ad-Aware now scans tracking cookies when scanning the text-files in the cookie folder from Explorer.
- Adding alternate data stream details to logfile is now enabled in Ad-Aware SE Personal.
- Listing of modules in logfile is now enabled in Ad-Aware SE Personal.
- Ad-Aware SE Plus will now support the CLP +silent.
Corrections
- The automatic updating of the definition file on installation will now work on all systems.
- If enabled, "Scan with Ad-Aware" is now removed from Explorer context menu when Ad-Aware SE is uninstalled.
- Corrected an issue where Ad-AWare would not launch from Ad-watch if Ad-Watch was run at startup.
- Corrected an issue with selection of folders for custom scans.
- Corrected an issue where removal of site from the Ad-Watch sites list would not be rememberd after restart.
- Corrected an issue where some string where displayed out of place if running Ad-- Aware using 640x480 screen resolution.
- Corrected an issue where start menu objects were not created on some systems.
This build 1.04 also includes a new definition file (SE1R7 06.09.2004)
New Definitions
Win32.Backdoor.Jeemp.ref (1 new variant)
Win32.Backdoor.Optix.ref (1 new variant)
Win32.Backdoor.Padodor.ref (1 new variant)
Win32.Trojan.StartPage.ref (2 variants)
Win32.TrojanClicker.ref (1 variant)
Win32.TrojanDropper.ref (5 variants)
Updated Definitions
Updated
404search.ref (1 new variant)
BargainBuddy.ref (1 new variant)
CoolWebSearch.ref (1 new variant)
EzuLa.ref (1 new variant)
Lop.ref (5 new variants)
midADdle.ref (1 new variant)
PurityScan.ref (2 variants)
Rads01.Quadrogram.ref (1 new variant)
Virtumundo.ref (1 new variant)
Win32.Adverts.TrojanDownloader.ref (14 new variants)
Win32.Backdoor.RBot.ref (1 new variant)
Definition File Details
Reference Number : SE1R7 06.09.2004
Internal build : 10
File size : 334604 Bytes
Total size : 1062308 Bytes
Signature data size : 1039594 Bytes
Reference data size : 22202 Bytes
Signatures total : 29277
Fingerprints size : 4655 Bytes
Target categories : 15
Target families : 545
Bron: Lavasoft
frankw
Slumdog millionaire
#9
mm, deze gemist :lol: dacht dat ik bij liep met ad-aware se :lol:
Kan deze er overheen geinstalleerd worden zonder ad-aware eerst zelf te verwijderen of niet :)
W
willem1940
Guest
#11
Ja, ik heb ook al heel lang Adaware maar ook het taal-programma'tje erbij want ik vind Nederlands prettiger waar mogelijk.
Dat nieuwe spul kreeg ik, doordat ik de boel netjes geregistreerd had, via een e-mailtje aangeboden.
Wel typisch, wat ik overigens ook ken van een paar zeldzame MS-programma'tjes die ik "oneigenlijk" uit Windows Update-map vandaan op harde schijf had gereserveerd omdat de installatie via de download-site niet wilde starten: die nieuwe te downloaden module is ter installatie ONZICHTBAAR in mijn Windows Installer, werkt alleen door opzoeken met Verkenner of Zoeken en aanklikken. Het is ook een bijzonder "model", merkwaardig pictogrammetje, wazig-lichtblauw.
Ik laat Adaware zo automatisch mogelijk alles vernietigen wat-ie niet vertrouwt, tot nog toe ging daar niets mee fout.
*Kingpin*
#12
hehe best ingewikkelde situatie :lol: ;)
fijn zo! :)
nee, daar kan je wel van op aan
(vroeger is het wel eens een keer geweest dat er na een update iets te veel mee werd aangegeven als zijnde spyware, terwijl het dat helemaal niet was, maar dat is al ene hele tijd geleden en lan altijd gebeuren, en je hebt steeds nog de backups :)
dus na een nieuwe versie de backups niet meteen al weggooien (kan later natuutlijk wel) want het kan altijd zijn -met eender welke progupdate- dat ze toch iets te scherp zoeken/ detecteren :ph34r: )
Er is trouwens sinds vandaag ook een nieuwe Ad-Aware Personal edition-versie beschikbaar: Ad-Aware Personal edition v. Build 1.05 :)
De mirror-sites zijn nog niet allemaal geupdate op dit moment, deze al wel:
http://www.majorgeeks.com/download506.html
Evtl via webupdate :)
Manual Installation: Unzip the archive, replace the existing file and restart Ad-AwareAd-Watch.You can also use the webupdate component implemented in Ad-Aware to install this update
Changelog Ad-Aware SE 1.05
Updates:
- Additional parameters for skinning
- Minor graphical GUI updates
- Hitrate displayed for tracking cookies on the results list
- Objects found within archives are displayed using a "zip" icon
- Nested archives are now scanned recursively
- Results list information on detected regvalues is now presented in a more readable format.
- The Object details windows information on detected regvalues is now presented in a more readable format.
Changes:
- GUI improvements concerning language files
- Ad-Aware will continue scanning archives even after an object has been detected
- The +log CLP is now supported in Plus
- Removing URLs from the sites list does no longer require a re-start of Ad-Watch to be put in effect.
http://www.lavasoftusa.com/
http://www.lavasoft.de/
frankw
Slumdog millionaire
#13
Dat is bijna niet meer bij te houden al die nieuwe versies van ad-aware.
*Kingpin*
#14
is he .. :huh:
maar deze is een 'recommanded' update, bij heel veel mensen bleef vorige (pas nieuwe) versie hangen op een bepaald windows bestand, deze zou dat oplossen + een paar extra troefjes
N
nano
Guest
#15
is nu al weer een nieuwe versie uit.
1.05 build 1501
heb nog niet gekeken wat de change log is.
frankw
Slumdog millionaire
#17
Nog niet, de taalmodules zijn vaak het laatste wat ze ontwikkelen voor de nieuwste ad-aware versie. Maar de nieuwe ziet er als uiterlijk precies hetzelfde uit als de oude versie.
*Kingpin*
*Kingpin*
Alles wat hij aangeeft is spy-/adware dus in principe kan je gewoon alles laten verwijderen :)
Maar je kan ook evenzogoed met het progje nog eerst in quarantaine zetten en na een week ofzo die backups wegdoen... :)
Bij een veel eerdere versie is het nl wel eens voorgevallen dat bij een toen pas nieuwe versie, er toch wat te veel als adware aangegeven werd, maar dat was in een beginstadium van Adaware
Deze laatste nieuwe versie is trouwens ook al niet zo recent meer, indien er zulke bugs zouden zijn bij die update, was dat al lang bekend geweest :)
Je kan er wel gerust in zijn :)
Succes! :)
*Kingpin*
#20
Is hier ook een NL versie van?
Nu wel :)
Er is juist een taalpakket uitgegeven voor de op dit moment recentste versie van Adaware-SE (build 1.05)
Volgende talen zijn beschikbaar gesteld:
Deens, Duits, Fins, Frans, Italiaans, Nederlands, Noors, Portugees, Spaans en Zweeds
Hier te downloaden:
http://download.lavasoft.de.edgesuite.net/...lic/pllangs.exe (directe download)
Installatie:
- Downloaden en opslaan
- Dubbelklik het gedownloade bestand (openen)
- Lezen/ aantal keer "next" klikken
- Standaard zijn alle talen die beschikbaar zijn, aangevinkt. Het is het duidelijkste (en meest logische :rolleyes: ) dat je enkel Nederlands (Dutch) aangevinkt laat staan, en de rest dus ontvinkt.
- Als dat gebeurd is, en je next hebt geklikt komt er nog een venster met de downloadlocatie, deze is reeds ingevuld. Klik weer op next.
- Klik op Finish
- Open je Ad Aware
- Open het "Ad Aware Configuration Window" (het boutvormige symbooltje)
- Kies in dat configuratiescherm via het menu links voor het tabbladje "Interface"
- Stel bij de optie "Language File" Dutch als taal in.
- Klik op "Proceed"
- et voil :D
Kijk ineens nog eens of er updates zijn en een scan kan ook nooit kwaad ;)
Succes! :)
