Graag zou ik wat hulp willen, als het kan graag in Jip&Janneke taal, want zodra het te technisch wordt begrijp ik het niet meer (vooral in het Engels)
Ik heb sinds een paar dagen regelmatig een blauw scherm, en heel irritant vooral bij het afsluiten, waarna hij weer opnieuw start, door ik dus alleen met de powerknop echt kan afsluiten.
Ik heb WhoCrashed gedraaid en daar komt het volgende uit:
Crash Dump Analysis
Crash dumps are enabled on your computer.
Crash dump directories:
C:\WINDOWS
C:\WINDOWS\Minidump
On Thu 7-3-2019 22:02:49 your computer crashed or a problem was reported
crash dump file: C:\WINDOWS\Minidump\030819-37218-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x1AA0C0)
Bugcheck code: 0x1A (0x3453, 0xFFFFA7825B2D0080, 0x1C8C00, 0x3)
Error: MEMORY_MANAGEMENT
file path: C:\WINDOWS\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: This indicates that a severe memory management error occurred.
This might be a case of memory corruption. This may be because of a hardware issue such as faulty RAM, overheating (thermal issue) or because of a buggy driver. This problem might also be caused because of overheating (thermal issue).
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
crash dump file: C:\WINDOWS\MEMORY.DMP
This was probably caused by the following module: ntkrnlmp.exe (nt!memset+0x3C49C)
On Thu 7-3-2019 17:19:20 your computer crashed or a problem was reported
crash dump file: C:\WINDOWS\Minidump\030719-33781-01.dmp
Bugcheck code: 0x1A (0x3453, 0xFFFFCB022AF1F080, 0x20F90, 0x3)
Conclusion
3 crash dumps have been found and analyzed. No offending third party drivers have been found. Connsider using WhoCrashed Professional which offers more detailed analysis using symbol resolution. Also configuring your system to produce a full memory dump may help you.
Read the topic general suggestions for troubleshooting system crashes for more information.
Note that it's not always possible to state with certainty whether a reported driver is responsible for crashing your system or that the root cause is in another module. Nonetheless it's suggested you look for updates for the products that these drivers belong to and regularly visit Windows update or enable automatic updates for Windows. In case a piece of malfunctioning hardware is causing trouble, a search with Google on the bug check errors together with the model name and brand of your computer may help you investigate this further.
Crash Dump Analysis
C:\WINDOWS
C:\WINDOWS\Minidump
