Opgelost Computer start heel traag op
danzie
31 jan 2021
14
42
Wat bedoel je met weblink, de XML versie
Hierbij heb bestand van WhySoSlow
danzie
31 jan 2021
14
42
System Information
Computer name: DESKTOP-JO0KK0S
OS version: Windows 10, 10.0, version 2009, build: 19042 (x64)
Hardware: ASUSTeK COMPUTER INC., TUF B450-PRO GAMING
CPU: AuthenticAMD AMD Ryzen 5 3500X 6-Core Processor
Logical processors: 6
Processor groups: 1
RAM: 16297 MB total
CPU Speed
Your CPU speed ranged between 3245 Mhz and 4042 MHz. The advertised clock speed of your processor is 3593 MHz.
Your main processor was always running above its advertised clock speed which means great performance. Your CPUs do not appear to be throttled down. More info..
CPU Temperature
Your CPU temperature could not be measured. Your processor likely does not have a temperature sensor.
CPU Load
While the test was idle, your CPU usage ranged from 20,3% to 41,8%. Your processor's resources do not appear to be used heavily. More info..
Memory Load
The amount of RAM used by your system while the test was running ranged from 18,3% to 19,3%. More info..
Paging Information
During the test hard pagefaults ranged from 0,0 to 196,0 pagefaults per second. The values reported are considered excellent. Your paging file resides on a SSD which fortunately limits the impact of hitting hard pagefaults on your system. More info..
Application responsiveness
The highest application responsiveness on your system was measured at 0,030 ms. This value is considered excellent. Your system appears to be very responsive. More info..
Kernel latencies and real-time capabilities
The highest kernel responsiveness on your system was measured at 0,015 ms. This value is considered excellent. There do not appear to be drivers causing your system to be unsuitable for real-time processing capabilities. More info..
BIOS and chipset behavior
The highest measured SM BIOS interrupt or other stall was 0 microseconds. This value is considered excellent. No problems have been detected during the tests. More info..
Conclusion
Your system has been analyzed. Your system appears to be running fine.
No problems were found.
danzie
31 jan 2021
14
42
Topic mag afgesloten worden
