Hier is de LOG file.
"List last 10 Event Viewer log" komt niet voor in het rijtje, wel: "List last 10 Events Viewer Errors". Die heb ik aangevinkt.
Ik moest alle programma's uitzetten, maar Firefox (zonder Internet!!) heb ik aangelaten om de opdrachten te kunnen uitvoeren. De file " UnifiedUi.exe " is gelieerd aan mijn Internet Phonekey. Dat weet ik. Die blijft wel eens staan en moet ik deleten om mijn phonekey weer te kunnen gebruiken.
Ran by CvP (administrator) on 11-11-2018 at 13:44:08
Running from "C:\Users\CvP\Desktop"
Microsoft Windows 7 Ultimate Service Pack 1 (X64)
Model: HP G62 Notebook PC Manufacturer: Hewlett-Packard
Boot Mode: Normal
Application errors:
Error: (11/10/2018 05:13:41 PM) (Source: Application Error) (User: )
Description: Faulting application name: UnifiedUi.exe, version: 0.0.0.0, time stamp: 0x53ba08be
Faulting module name: UniSdk.dll_unloaded, version: 0.0.0.0, time stamp: 0x539ff196
Exception code: 0xc0000005
Fault offset: 0x6d75cca0
Faulting process id: 0x13dc
Faulting application start time: 0xUnifiedUi.exe0
Faulting application path: UnifiedUi.exe1
Faulting module path: UnifiedUi.exe2
Report Id: UnifiedUi.exe3
Error: (11/10/2018 12:22:59 PM) (Source: System Restore) (User: )
Description: Failed to create restore point (Process = C:\PROGRA~2\COMMON~1\INSTAL~1\Engine\6\INTEL3~1\IKernel.exe -Embedding; Description = Installed Atheros Wireless LAN; Error = 0x8004231f).
Error: (11/08/2018 11:20:29 AM) (Source: Application Error) (User: )
Faulting module name: ntdll.dll, version: 6.1.7601.18247, time stamp: 0x521ea8e7
Fault offset: 0x0002ff47
Faulting process id: 0x1494
Error: (11/05/2018 03:41:17 PM) (Source: System Restore) (User: )
Description: Failed to create restore point (Process = C:\ProgramData\Package Cache\{e5a12991-d0a9-4922-a125-fce431f55219}\Intel Driver and Support Assistant Installer.exe Cache\{e5a12991-d0a9-4922-a125-fce431f55219}\Intel Driver and Support Assistant Installer.exe" -q -burn.elevated BurnPipe.{6FC53AAC-2096-4DB8-AD47-9264F6D696BB} {30F28423-86BC-4C69-9350-8A22A8DF68AE} 4184; Description = Intel® Driver & Support Assistant; Error = 0x8004231f).
Error: (11/05/2018 03:30:03 PM) (Source: System Restore) (User: )
Description: Failed to create restore point (Process = C:\Users\CvP\AppData\Local\Temp\{B33A1631-1A28-4CE1-A2D2-6832CF9629A3}\.be\Intel Driver and Support Assistant Installer.exe Driver and Support Assistant Installer.exe" -q -burn.elevated BurnPipe.{93F2EA26-02AE-4B40-9649-D03744176277} {CA6EEEEC-81CB-45BA-A643-68B2CE455CC6} 5060; Description = Intel® Driver & Support Assistant; Error = 0x8004231f).
Error: (11/02/2018 12:02:39 PM) (Source: MsiInstaller) (User: CvP-PC)
Description: Product: Intel(R) Network Connections -- Cannot install drivers. No Intel(R) Adapters are present in this computer.
Error: (11/02/2018 11:43:44 AM) (Source: MsiInstaller) (User: CvP-PC)
Error: (10/29/2018 12:33:53 PM) (Source: RasClient) (User: )
Description: CoId={38ACD569-2778-4675-B0D4-3D7B59EA5C90}: The user CvP-PC\CvP dialed a connection named Movitel which has failed. The error code returned on failure is 628.
Error: (10/28/2018 05:18:42 AM) (Source: RasClient) (User: )
Description: CoId={D48B6700-50EA-4D4D-BC0D-E08E1830DCE8}: The user CvP-PC\CvP dialed a connection named Movitel which has failed. The error code returned on failure is 628.
Error: (10/27/2018 11:12:01 AM) (Source: System Restore) (User: )
Description: Failed to create restore point (Process = C:\swsetup\sp50702\setup.exe; Description = Installed Realtek Ethernet Controller Driver; Error = 0x8004231f).
System errors:
Error: (11/11/2018 01:09:08 PM) (Source: Microsoft Antimalware) (User: )
Description: %NT AUTHORITY60 has encountered an error trying to update signatures.
New Signature Version:
Previous Signature Version: 119.0.0.0
Update Source: %NT AUTHORITY51
Update Stage: 4.10.209.00
Source Path: 4.10.209.01
Signature Type: %NT AUTHORITY602
Update Type: %NT AUTHORITY604
User: NT AUTHORITY\NETWORK SERVICE
Current Engine Version: %NT AUTHORITY605
Previous Engine Version: %NT AUTHORITY606
Error code: %NT AUTHORITY607
Error description: %NT AUTHORITY608
Previous Signature Version: 1.279.1506.0
Error: (11/11/2018 01:09:00 PM) (Source: Microsoft Antimalware) (User: )
Update Source: %NT AUTHORITY59
User: NT AUTHORITY\SYSTEM
Error: (11/11/2018 11:05:03 AM) (Source: Microsoft Antimalware) (User: )
Error: (11/11/2018 10:55:38 AM) (Source: Service Control Manager) (User: )
Description: The following boot-start or system-start driver(s) failed to load:
cdrom
Microsoft Office Sessions:
Error: (11/10/2018 05:13:41 PM) (Source: Application Error)(User: )
Description: UnifiedUi.exe0.0.0.053ba08beUniSdk.dll_unloaded0.0.0.0539ff196c00000056d75cca013dc01d47907b9cf777bC:\Program Files (x86)\D-com 3.5G\UnifiedUi.exeUniSdk.dll34b12203-e4fb-11e8-9052-001e101f0000
Error: (11/10/2018 12:22:59 PM) (Source: System Restore)(User: )
Description: C:\PROGRA~2\COMMON~1\INSTAL~1\Engine\6\INTEL3~1\IKernel.exe -EmbeddingInstalled Atheros Wireless LAN0x8004231f
Error: (11/08/2018 11:20:29 AM) (Source: Application Error)(User: )
Description: UnifiedUi.exe0.0.0.053ba08bentdll.dll6.1.7601.18247521ea8e7c00000050002ff47149401d477400dc63c4dC:\Program Files (x86)\D-com 3.5G\UnifiedUi.exeC:\Windows\SysWOW64\ntdll.dll883bacb3-e337-11e8-bf23-8ddd98cad54f
Error: (11/05/2018 03:41:17 PM) (Source: System Restore)(User: )
Description: C:\ProgramData\Package Cache\{e5a12991-d0a9-4922-a125-fce431f55219}\Intel Driver and Support Assistant Installer.exe Cache\{e5a12991-d0a9-4922-a125-fce431f55219}\Intel Driver and Support Assistant Installer.exe" -q -burn.elevated BurnPipe.{6FC53AAC-2096-4DB8-AD47-9264F6D696BB} {30F28423-86BC-4C69-9350-8A22A8DF68AE} 4184Intel® Driver & Support Assistant0x8004231f
Error: (11/05/2018 03:30:03 PM) (Source: System Restore)(User: )
Description: C:\Users\CvP\AppData\Local\Temp\{B33A1631-1A28-4CE1-A2D2-6832CF9629A3}\.be\Intel Driver and Support Assistant Installer.exe Driver and Support Assistant Installer.exe" -q -burn.elevated BurnPipe.{93F2EA26-02AE-4B40-9649-D03744176277} {CA6EEEEC-81CB-45BA-A643-68B2CE455CC6} 5060Intel® Driver & Support Assistant0x8004231f
Error: (11/02/2018 12:02:39 PM) (Source: MsiInstaller)(User: CvP-PC)
Description: Product: Intel(R) Network Connections -- Cannot install drivers. No Intel(R) Adapters are present in this computer.(NULL)(NULL)(NULL)(NULL)(NULL)
Error: (11/02/2018 11:43:44 AM) (Source: MsiInstaller)(User: CvP-PC)
Error: (10/29/2018 12:33:53 PM) (Source: RasClient)(User: )
Description: {38ACD569-2778-4675-B0D4-3D7B59EA5C90}CvP-PC\CvPMovitel628
Error: (10/28/2018 05:18:42 AM) (Source: RasClient)(User: )
Description: {D48B6700-50EA-4D4D-BC0D-E08E1830DCE8}CvP-PC\CvPMovitel628
Error: (10/27/2018 11:12:01 AM) (Source: System Restore)(User: )
Description: C:\swsetup\sp50702\setup.exeInstalled Realtek Ethernet Controller Driver0x8004231f
CodeIntegrity Errors:
Date: 2018-03-03 15:31:39.801
Description: Windows is unable to verify the image integrity of the file \Device\HarddiskVolume2\Windows\System32\drivers\eagleGet.sys because file hash could not be found on the system. A recent hardware or software change might have installed a file that is signed incorrectly or damaged, or that might be malicious software from an unknown source.
Date: 2018-03-03 15:31:39.583
Date: 2018-03-03 15:31:37.134
Date: 2018-03-03 15:31:36.993
Date: 2018-03-03 07:33:59.292
Date: 2018-03-03 07:33:59.214
Date: 2018-03-03 07:33:58.434
Date: 2018-03-03 07:33:58.356
Date: 2018-03-02 10:30:39.949
Description: Code Integrity is unable to verify the image integrity of the file \Device\HarddiskVolume2\Windows\System32\drivers\eagleGet.sys because the set of per-page image hashes could not be found on the system.
Date: 2018-03-02 10:30:39.819
7-Zip 16.04 (x64) (HKLM\...\7-Zip) (Version: 16.04 - Igor Pavlov)
Adobe Flash Player 31 NPAPI (HKLM-x32\...\Adobe Flash Player NPAPI) (Version: 31.0.0.122 - Adobe Systems Incorporated)
Adobe Help Manager (HKLM-x32\...\chc.4875E02D9FB21EE389F73B8D1702B320485DF8CE.1) (Version: 4.0.244 - Adobe Systems Incorporated)
Atheros Wireless LAN (HKLM-x32\...\{D70DE630-0D13-4394-A15B-5ACE6CF2A18D}) (Version: - )
CDBurnerXP (HKLM\...\{7E265513-8CDA-4631-B696-F40D983F3B07}_is1) (Version: 4.3.8.2560 - CDBurnerXP)
Connect (HKLM-x32\...\MAGIX_connector_is1) (Version: 2.6.1.117 - MAGIX Software GmbH)
D-com 3.5G (HKLM-x32\...\{C06C7DD7-9611-42E8-9254-7FC6A9E26160}) (Version: 1.0.0.1 - )
Defraggler (HKLM\...\Defraggler) (Version: 2.21 - Piriform)
FileSearchEX (HKLM-x32\...\FileSearchEX) (Version: 1.0.9.8 - GOFF Concepts LLC)
FreshDownload (HKLM-x32\...\FreshDevices - FreshDownload_is1) (Version: - )
GetDataBack for NTFS (HKLM-x32\...\{56582EEA-3AEF-4D84-8B9D-C87A3CD9250F}) (Version: 3.66.000 - Runtime Software)
HP Deskjet 1510 series Basic Device Software (HKLM\...\{D17E60E8-478A-4D4A-8147-21D481B5CA55}) (Version: 32.2.188.47710 - Hewlett-Packard Co.)
HP Deskjet 1510 series Help (HKLM-x32\...\{2E25FCEB-EFCB-4696-AA01-D3CBAC721831}) (Version: 30.0.0 - Hewlett Packard)
HP Support Solutions Framework (HKLM-x32\...\{930B5F2B-8DB9-42F4-90E4-5D3DC30541C3}) (Version: 12.8.47.1 - HP Inc.)
Intel(R) Computing Improvement Program (HKLM\...\{2C895850-899F-4E06-ADB6-28A654FFCF9D}) (Version: 2.2.04036 - Intel Corporation)
Intel(R) Management Engine Components (HKLM-x32\...\{65153EA5-8B6E-43B6-857B-C6E4FC25798A}) (Version: 6.0.0.1179 - Intel Corporation)
Intel(R) Processor Graphics (HKLM-x32\...\{F0E3AD40-2BBD-4360-9C76-B9AC9A5886EA}) (Version: 8.15.10.2993 - Intel Corporation)
Intel(R) Processor Identification Utility (HKLM-x32\...\{A92A4DB0-CD37-42D1-BE1D-603D53C24328}) (Version: 1.0.0.0 - Intel Corporation)
Java 8 Update 131 (HKLM-x32\...\{26A24AE4-039D-4CA4-87B4-2F32180131F0}) (Version: 8.0.1310.11 - Oracle Corporation)
Macrium Reflect - Free Edition (HKLM\...\{FD66A549-5110-48C8-ACE6-3F52AB3BF100}) (Version: 4.2.3141 - Macrium)
Malwarebytes version 3.5.1.2522 (HKLM\...\{35065F43-4BB2-439A-BFF7-0F1014F2E0CD}_is1) (Version: 3.5.1.2522 - Malwarebytes)
Microsoft .NET Framework 4.6.1 (HKLM\...\{92FB6C44-E685-45AD-9B20-CADF4CABA132} - 1033) (Version: 4.6.01055 - Microsoft Corporation)
Microsoft Security Essentials (HKLM\...\Microsoft Security Client) (Version: 4.10.209.0 - Microsoft Corporation)
Microsoft Xbox One Controller for Windows (HKLM\...\{DC2CB48C-FD96-48EB-A36A-7D995BB587EB}) (Version: 1.0.2 - Microsoft Corporation)
Mobile Broadband HL Service (HKLM-x32\...\Mobile Broadband HL Service) (Version: 22.001.29.00.03 - Huawei Technologies Co.,Ltd)
Mozilla Firefox 63.0 (x64 en-US) (HKLM\...\Mozilla Firefox 63.0 (x64 en-US)) (Version: 63.0 - Mozilla)
Mozilla Maintenance Service (HKLM\...\MozillaMaintenanceService) (Version: 57.0 - Mozilla)
MSXML 4.0 SP3 Parser (KB2721691) (HKLM-x32\...\{355B5AC0-CEEE-42C5-AD4D-7F3CFD806C36}) (Version: 4.30.2114.0 - Microsoft Corporation)
Notepad++ (32-bit x86) (HKLM-x32\...\Notepad++) (Version: 7.4.1 - Notepad++ Team)
Ralink RT2870 Wireless LAN Card (HKLM-x32\...\{28DA7D8B-F9A4-4F18-8AA0-551B1E084D0D}) (Version: 1.5.31.0 - Ralink)
Realtek Ethernet Controller Driver (HKLM-x32\...\{8833FFB6-5B0C-4764-81AA-06DFEED9A476}) (Version: 7.25.824.2010 - Realtek)
Realtek High Definition Audio Driver (HKLM-x32\...\{F132AF7F-7BCA-4EDE-8A7C-958108FE7DBC}) (Version: 6.0.1.6196 - Realtek Semiconductor Corp.)
Realtek USB 2.0 Card Reader (HKLM-x32\...\{96AE7E41-E34E-47D0-AC07-1091A8127911}) (Version: 6.1.7600.30105 - Realtek Semiconductor Corp.)
RtVOsd (HKLM\...\{091A0130-A82F-4A6D-9C61-3BBBB3289030}) (Version: 1.0.6 - Realtek Semiconductor Corp.)
Sid Meier's Civilization V (HKLM-x32\...\steam app 8930) (Version: - 2K Games, Inc.)
Speccy (HKLM\...\Speccy) (Version: 1.31 - Piriform)
Spybot Anti-Beacon (HKLM-x32\...\{419A7FCF-93E1-474D-BFE9-987CF3F90C88}_is1) (Version: 1.6 - Safer-Networking Ltd.)
Synaptics Pointing Device Driver (HKLM\...\SynTPDeinstKey) (Version: 15.1.6.64 - Synaptics Incorporated)
TrueCrypt (HKLM-x32\...\TrueCrypt) (Version: 7.1a - TrueCrypt Foundation)
Tweaking.com - Windows Repair (HKLM-x32\...\Tweaking.com - Windows Repair) (Version: 4.0.9 - Tweaking.com)
VLC media player 2.0.1 (HKLM-x32\...\VLC media player) (Version: 2.0.1 - VideoLAN)
Windows Driver Package - Microsoft (xusb21) XnaComposite (08/13/2009 2.1.0.1349) (HKLM\...\0AEBEF6F936CFE16E003F7E141631FAB754D9816) (Version: 08/13/2009 2.1.0.1349 - Microsoft)
Windows XP Mode (HKLM\...\{1374CC63-B520-4f3f-98E8-E9020BF01CFF}) (Version: 1.3.7600.16423 - Microsoft Corporation)
xHarbour Builder Personal (HKLM-x32\...\{21F1DC11-A9ED-436B-ACAF-16EAB90DF2FA}) (Version: 1.0.0 - xHarbour)
xHarbour Builder Personal, Build October 2003 (HKLM-x32\...\xHarbour Builder Personal, Build October 2003) (Version: - )
ZDServer (HKLM-x32\...\{C8197F5F-E0DC-44f1-8AF2-1AA5A84F695D}) (Version: 1.0.1.2 - ZTE Corporation)
ZTE Mobile Broadband Device Drivers 1.0.0.17 (HKLM-x32\...\{9194B665-5134-4B6B-AD73-A5292CB072D3}_is1) (Version: - ZTE)
Percentage of memory in use: 55%
Total physical RAM: 3893.86 MB
Available physical RAM: 1719.01 MB
Total Virtual: 7785.9 MB
Available Virtual: 4446.96 MB
1 Drive c: () (Fixed) (Total:97.66 GB) (Free:55.76 GB) NTFS
2 Drive d: (Data) (Fixed) (Total:351.47 GB) (Free:115.22 GB) NTFS
3 Drive f: () (Removable) (Total:7.26 GB) (Free:7.08 GB) NTFS
User accounts for \\CVP-PC
Administrator CvP Guest
C:\Windows\Minidump\011218-17971-01.dmp
C:\Windows\Minidump\011218-29546-01.dmp
C:\Windows\Minidump\011418-16910-01.dmp
C:\Windows\Minidump\011418-17394-01.dmp
C:\Windows\Minidump\011618-18080-01.dmp
C:\Windows\Minidump\011618-53383-01.dmp
C:\Windows\Minidump\011818-25927-01.dmp
C:\Windows\Minidump\011918-16442-01.dmp
C:\Windows\Minidump\011918-17581-01.dmp
C:\Windows\Minidump\012018-16052-01.dmp
C:\Windows\Minidump\012018-17799-01.dmp
C:\Windows\Minidump\012118-16660-01.dmp
C:\Windows\Minidump\012118-17721-01.dmp
C:\Windows\Minidump\012118-25506-01.dmp
C:\Windows\Minidump\012218-17347-01.dmp
C:\Windows\Minidump\012218-49171-01.dmp
C:\Windows\Minidump\012518-17908-01.dmp
C:\Windows\Minidump\012718-20810-01.dmp
C:\Windows\Minidump\012718-46909-01.dmp
C:\Windows\Minidump\012818-19546-01.dmp
C:\Windows\Minidump\012918-37736-01.dmp
C:\Windows\Minidump\020218-20280-01.dmp
C:\Windows\Minidump\020418-16801-01.dmp
C:\Windows\Minidump\020518-17628-01.dmp
C:\Windows\Minidump\020818-19172-01.dmp
C:\Windows\Minidump\020918-26036-01.dmp
C:\Windows\Minidump\030218-54225-01.dmp
C:\Windows\Minidump\030318-17862-01.dmp
C:\Windows\Minidump\030318-19515-01.dmp
C:\Windows\Minidump\030518-20794-01.dmp
C:\Windows\Minidump\031318-18330-01.dmp
C:\Windows\Minidump\031318-21871-01.dmp
C:\Windows\Minidump\092217-27019-01.dmp
C:\Windows\Minidump\100817-91603-01.dmp
**** End of log ****
Overigens, de HD doet weer normaal!
perloc
