YdieresiS zei:Ook leuk, ga je akkoord met de terms of service. en dan yes of no invullen.
Maar nergens een linkje naar de terms of service.
En idd nogal wat errors op de sites. Als ik daar een site zou aanmaken, zou je dan ook steeds die errors krijgen??
To the use of Xanma Free Webhosting fair Use Policy apply (FUP).
This keeps in that there no fixed date limit is put on the quantity date
movement which you if user can use.
This implies tevens that Xanma Free Webhosting can intervene if you
download regularly relative more than the average user.
As, in the opinion of Xanma Free Webhosting, a customer
Xanma Free Webhosting have exceeded the provision of these FUP
a customer a e-mail will inform. We preserve ourselves however the right
for in extreme cases after 1 warning, with immediate entrance block the subscription.
This regulation has that for you as an advantage you from time to time much
date movement can use, as long as your average use over a longer period is
not significant higher than that of other users.
As Xanma Free Webhosting a fixed monthly limit for date movement establish,
that contents that you will get an extra account for everything above this limit.
Why do Xanma Free Webhosting give no unlimited date movement on Webhosting?
As all web-leap about-delicate ones pays Xanma Free Webhosting for the band width
which it are customers makes available. This keeps each megabyte which in that
you download by our paid must become.
jawel kan welGeen reclame: http://www.funpic.org/
Wel reclame: http://www.funpic.de/
(Bij Funpic.org moet je ip United States zijn, dus met een Nederlands ip kan je daar geen account maken! Maar dan moet je gewoon een United States proxy instellen en je kunt wel een een account aanmaken! )
