Farbar MiniToolBox gebruiken:
- Sluit nu eerst alle nog openstaande programmavensters!
- Windows 2000 en Windows XP: start "MiniToolBox.exe" via dubbelklikken.
- Windows Vista, Windows 7, Windows 8 en Windows 10: start "MiniToolBox.exe" via rechtsklik Als Administrator uitvoeren.
- Flush DNS
- Report IE Proxy Settings
- Reset IE Proxy Settings
- Report FF Proxy Settings
- Reset FF Proxy Settings
- List content of Hosts
- List IP configuration
- List Winsock Entries
- List last 10 Event Viewer log
- List Installed Programs
- List Devices - Only Problems
- List Users, Partitions and Memory size
- List Minidump Files
- Klik nu op de knop "Go".
- Aansluitend wordt een log aangemaakt (Result.txt) in de zelfde map waar "MiniToolBox.exe" in zit.
- Kopieer en plak de inhoud van het log in jouw volgende bericht.
Dit was het resultaat:
Ran by Ruben (administrator) on 20-07-2017 at 16:18:24
Running from "C:\Users\Ruben\Downloads"
Microsoft Windows 8.1 (X64)
Model: GP60 2QE Manufacturer: Micro-Star International Co., Ltd.
Boot Mode: Normal
Windows IP Configuration
Proxy is not enabled.
No Proxy Server is set.
Killer e2200 Gigabit Ethernet Controller (NDIS 6.30) = Ethernet 2 (Connected)
Intel(R) Dual Band Wireless-AC 3160 = Wi-Fi 2 (Media disconnected)
Bluetooth Device (Personal Area Network) = Bluetooth-netwerkverbinding 2 (Media disconnected)
# IPv4 Configuration
pushd interface ipv4
reset
set interface interface="Bluetooth-netwerkverbinding" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="LAN-verbinding* 3" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="Wi-Fi 2" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="Bluetooth-netwerkverbinding 2" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="LAN-verbinding* 4" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
popd
# End of IPv4 configuration
Host Name . . . . . . . . . . . . : MSI
DNS Suffix Search List. . . . . . : dynamic.ziggo.nl
Wireless LAN adapter LAN-verbinding* 4:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter #2
Physical Address. . . . . . . . . : D0-7E-35-F0-4D-4F
Ethernet adapter Bluetooth-netwerkverbinding 2:
Description . . . . . . . . . . . : Bluetooth Device (Personal Area Network) #2
Physical Address. . . . . . . . . : D0-7E-35-F0-4D-52
Wireless LAN adapter Wi-Fi 2:
Connection-specific DNS Suffix . : dynamic.ziggo.nl
Description . . . . . . . . . . . : Intel(R) Dual Band Wireless-AC 3160 #2
Physical Address. . . . . . . . . : D0-7E-35-F0-4D-4E
Ethernet adapter Ethernet 2:
Description . . . . . . . . . . . : Killer e2200 Gigabit Ethernet Controller (NDIS 6.30) #2
Physical Address. . . . . . . . . : 44-8A-5B-F1-F5-6B
Link-local IPv6 Address . . . . . : fe80::b980:d8fe:777:cbcd%8(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.178.25(Preferred)
Lease Obtained. . . . . . . . . . : donderdag 20 juli 2017 13:57:14
Lease Expires . . . . . . . . . . : vrijdag 21 juli 2017 15:55:20
Default Gateway . . . . . . . . . : 192.168.178.1
DHCP Server . . . . . . . . . . . : 192.168.178.1
DHCPv6 IAID . . . . . . . . . . . : 138709595
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-20-FE-62-14-44-8A-5B-EF-AC-82
DNS Servers . . . . . . . . . . . : 89.101.251.228
89.101.251.229
Tunnel adapter isatap.dynamic.ziggo.nl:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
Tunnel adapter Teredo Tunneling Pseudo-Interface:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
IPv6 Address. . . . . . . . . . . : 2001:0:9d38:90d7:3801:1c66:2b80:1e4a(Preferred)
Link-local IPv6 Address . . . . . : fe80::3801:1c66:2b80:1e4a%14(Preferred)
Default Gateway . . . . . . . . . : ::
DHCPv6 IAID . . . . . . . . . . . : 486539264
NetBIOS over Tcpip. . . . . . . . : Disabled
Server: 089-101-251228.ntlworld.ie
Address: 89.101.251.228
Addresses: 2a00:1450:400e:808::200e
216.58.211.110
Pinging google.com [172.217.19.206] with 32 bytes of data:
Reply from 172.217.19.206: bytes=32 time=10ms TTL=56
Reply from 172.217.19.206: bytes=32 time=11ms TTL=56
Ping statistics for 172.217.19.206:
Minimum = 10ms, Maximum = 11ms, Average = 10ms
Addresses: 2001:4998:c:a06::2:4008
2001:4998:58:c02::a9
2001:4998:44:204::a7
98.139.180.149
98.138.253.109
206.190.36.45
Pinging yahoo.com [98.138.253.109] with 32 bytes of data:
Reply from 98.138.253.109: bytes=32 time=135ms TTL=50
Reply from 98.138.253.109: bytes=32 time=136ms TTL=50
Ping statistics for 98.138.253.109:
Minimum = 135ms, Maximum = 136ms, Average = 135ms
Interface List
11...d0 7e 35 f0 4d 4f ......Microsoft Wi-Fi Direct Virtual Adapter #2
10...d0 7e 35 f0 4d 52 ......Bluetooth Device (Personal Area Network) #2
9...d0 7e 35 f0 4d 4e ......Intel(R) Dual Band Wireless-AC 3160 #2
8...44 8a 5b f1 f5 6b ......Killer e2200 Gigabit Ethernet Controller (NDIS 6.30) #2
13...00 00 00 00 00 00 00 e0 Microsoft ISATAP Adapter
14...00 00 00 00 00 00 00 e0 Teredo Tunneling Pseudo-Interface
IPv4 Route Table
Active Routes:
0.0.0.0 0.0.0.0 192.168.178.1 192.168.178.25 10
127.0.0.0 255.0.0.0 On-link 127.0.0.1 306
127.0.0.1 255.255.255.255 On-link 127.0.0.1 306
127.255.255.255 255.255.255.255 On-link 127.0.0.1 306
192.168.178.0 255.255.255.0 On-link 192.168.178.25 266
192.168.178.25 255.255.255.255 On-link 192.168.178.25 266
192.168.178.255 255.255.255.255 On-link 192.168.178.25 266
224.0.0.0 240.0.0.0 On-link 127.0.0.1 306
224.0.0.0 240.0.0.0 On-link 192.168.178.25 266
255.255.255.255 255.255.255.255 On-link 127.0.0.1 306
255.255.255.255 255.255.255.255 On-link 192.168.178.25 266
Persistent Routes:
None
IPv6 Route Table
Active Routes:
14 306 ::/0 On-link
1 306 ::1/128 On-link
14 306 2001::/32 On-link
14 306 2001:0:9d38:90d7:3801:1c66:2b80:1e4a/128
On-link
8 266 fe80::/64 On-link
14 306 fe80::/64 On-link
14 306 fe80::3801:1c66:2b80:1e4a/128
On-link
8 266 fe80::b980:d8fe:777:cbcd/128
On-link
1 306 ff00::/8 On-link
8 266 ff00::/8 On-link
14 306 ff00::/8 On-link
Persistent Routes:
None
Catalog5 01 C:\Windows\SysWOW64\napinsp.dll [55296] (Microsoft Corporation)
Catalog5 02 C:\Windows\SysWOW64\pnrpnsp.dll [70144] (Microsoft Corporation)
Catalog5 03 C:\Windows\SysWOW64\pnrpnsp.dll [70144] (Microsoft Corporation)
Catalog5 04 C:\Windows\SysWOW64\NLAapi.dll [65536] (Microsoft Corporation)
Catalog5 05 C:\Windows\SysWOW64\mswsock.dll [286208] (Microsoft Corporation)
Catalog5 06 C:\Windows\SysWOW64\winrnr.dll [23040] (Microsoft Corporation)
Catalog5 07 C:\Windows\SysWOW64\wshbth.dll [50688] (Microsoft Corporation)
Catalog9 01 C:\Windows\SysWOW64\mswsock.dll [286208] (Microsoft Corporation)
Catalog9 02 C:\Windows\SysWOW64\mswsock.dll [286208] (Microsoft Corporation)
Catalog9 03 C:\Windows\SysWOW64\mswsock.dll [286208] (Microsoft Corporation)
Catalog9 04 C:\Windows\SysWOW64\mswsock.dll [286208] (Microsoft Corporation)
Catalog9 05 C:\Windows\SysWOW64\mswsock.dll [286208] (Microsoft Corporation)
Catalog9 06 C:\Windows\SysWOW64\mswsock.dll [286208] (Microsoft Corporation)
Catalog9 07 C:\Windows\SysWOW64\mswsock.dll [286208] (Microsoft Corporation)
Catalog9 08 C:\Windows\SysWOW64\mswsock.dll [286208] (Microsoft Corporation)
Catalog9 09 C:\Windows\SysWOW64\mswsock.dll [286208] (Microsoft Corporation)
Catalog9 10 C:\Windows\SysWOW64\mswsock.dll [286208] (Microsoft Corporation)
Catalog9 11 C:\Windows\SysWOW64\mswsock.dll [286208] (Microsoft Corporation)
x64-Catalog5 01 C:\Windows\System32\napinsp.dll [69120] (Microsoft Corporation)
x64-Catalog5 02 C:\Windows\System32\pnrpnsp.dll [88576] (Microsoft Corporation)
x64-Catalog5 03 C:\Windows\System32\pnrpnsp.dll [88576] (Microsoft Corporation)
x64-Catalog5 04 C:\Windows\System32\NLAapi.dll [86016] (Microsoft Corporation)
x64-Catalog5 05 C:\Windows\System32\mswsock.dll [339456] (Microsoft Corporation)
x64-Catalog5 06 C:\Windows\System32\winrnr.dll [30720] (Microsoft Corporation)
x64-Catalog5 07 C:\Windows\System32\wshbth.dll [63488] (Microsoft Corporation)
x64-Catalog9 01 C:\Windows\System32\mswsock.dll [339456] (Microsoft Corporation)
x64-Catalog9 02 C:\Windows\System32\mswsock.dll [339456] (Microsoft Corporation)
x64-Catalog9 03 C:\Windows\System32\mswsock.dll [339456] (Microsoft Corporation)
x64-Catalog9 04 C:\Windows\System32\mswsock.dll [339456] (Microsoft Corporation)
x64-Catalog9 05 C:\Windows\System32\mswsock.dll [339456] (Microsoft Corporation)
x64-Catalog9 06 C:\Windows\System32\mswsock.dll [339456] (Microsoft Corporation)
x64-Catalog9 07 C:\Windows\System32\mswsock.dll [339456] (Microsoft Corporation)
x64-Catalog9 08 C:\Windows\System32\mswsock.dll [339456] (Microsoft Corporation)
x64-Catalog9 09 C:\Windows\System32\mswsock.dll [339456] (Microsoft Corporation)
x64-Catalog9 10 C:\Windows\System32\mswsock.dll [339456] (Microsoft Corporation)
x64-Catalog9 11 C:\Windows\System32\mswsock.dll [339456] (Microsoft Corporation)
Application errors:
Error: (07/20/2017 02:13:13 PM) (Source: SideBySide) (User: )
Description: Kan activeringscontext voor '1' niet maken. Fout in manifest of beleidsbestand '2' op regel 3.
Het hoofdelement van het manifestbestand moet een assemblage zijn.
Error: (07/19/2017 08:57:37 PM) (Source: Microsoft-Windows-WMI) (User: NT AUTHORITY)
Description: Gebeurtenisfilter met query select * from CIntelWLANEvent is niet opnieuw geactiveerd in naamruimte //./ROOT/default vanwege fout 0x80041010. Er worden geen gebeurtenissen doorgegeven via dit filter totdat het probleem is verholpen.
Error: (07/19/2017 06:11:24 PM) (Source: Perflib) (User: )
Description: BITSC:\Windows\System32\bitsperf.dll8
Error: (07/19/2017 05:14:12 PM) (Source: Application Error) (User: )
Description: Naam van toepassing met fout: ZeroConfigService.exe, versie: 17.0.5.0, tijdstempel: 0x5387ee07
Naam van module met fout: MurocApi.dll, versie: 17.0.5.0, tijdstempel: 0x5387ed02
Uitzonderingscode: 0xc0000005
Foutmarge: 0x000000000002bd48
Id van proces met fout: 0x9bc
Starttijd van toepassing met fout: 0xZeroConfigService.exe0
Pad naar toepassing met fout: ZeroConfigService.exe1
Pad naar module met fout: ZeroConfigService.exe2
Rapport-id: ZeroConfigService.exe3
Volledige pakketnaam met fout: ZeroConfigService.exe4
Relatieve toepassings-id van pakket met fout: ZeroConfigService.exe5
Error: (07/19/2017 05:09:42 PM) (Source: Windows Search Service) (User: )
Description: Kan het filterhostproces niet initialiseren. Wordt beëindigd.
Details:
Deze bewerking is geretourneerd omdat de time-outperiode verlopen is. (HRESULT : 0x800705b4) (0x800705b4)
Error: (07/18/2017 02:59:22 PM) (Source: VSS) (User: )
Description: Fout in de Volume Shadow Copy-service: onverwachte fout bij het uitvoeren van een query voor de IVssWriterCallback-interface. hr = 0x80070005, Toegang geweigerd.
Dit wordt vaak veroorzaakt door onjuiste beveiligingsinstellingen in het writer- of requestorproces.
Bewerking:
Schrijvergegevens verzamelen
Context:
Klasse-id van schrijver: {e8132975-6f93-4464-a53e-1050253ae220}
Naam van schrijver: System Writer
Instantie-id van schrijver: {7b15c7c7-c323-4824-938a-eae9830f1aff}
Error: (07/18/2017 02:46:55 PM) (Source: VSS) (User: )
Bewerking:
Context:
Instantie-id van schrijver: {a4da1199-af09-466e-94ea-a744b8ee6634}
Error: (07/17/2017 09:19:16 PM) (Source: Application Error) (User: )
Description: Naam van toepassing met fout: RzSDKServer.exe, versie: 1.0.5.0, tijdstempel: 0x5948ebb8
Naam van module met fout: i-ms-win-crt-runtime-l1-1-0.dll, versie: 6.3.9600.17278, tijdstempel: 0x53eeb4a3
Uitzonderingscode: 0xc0000135
Foutmarge: 0x00098f05
Id van proces met fout: 0x11a4
Starttijd van toepassing met fout: 0xRzSDKServer.exe0
Pad naar toepassing met fout: RzSDKServer.exe1
Pad naar module met fout: RzSDKServer.exe2
Rapport-id: RzSDKServer.exe3
Volledige pakketnaam met fout: RzSDKServer.exe4
Relatieve toepassings-id van pakket met fout: RzSDKServer.exe5
Error: (07/17/2017 09:19:14 PM) (Source: Application Error) (User: )
Id van proces met fout: 0xecc
Error: (07/17/2017 09:19:13 PM) (Source: Application Error) (User: )
Description: Naam van toepassing met fout: RzSDKService.exe, versie: 2.0.3.1, tijdstempel: 0x5948eaf8
Id van proces met fout: 0x55c
Starttijd van toepassing met fout: 0xRzSDKService.exe0
Pad naar toepassing met fout: RzSDKService.exe1
Pad naar module met fout: RzSDKService.exe2
Rapport-id: RzSDKService.exe3
Volledige pakketnaam met fout: RzSDKService.exe4
Relatieve toepassings-id van pakket met fout: RzSDKService.exe5
System errors:
Error: (07/20/2017 01:57:10 PM) (Source: EventLog) (User: )
Description: De vorige afsluiting van het systeem om 23:06:25 op 19-7-2017 is onverwacht gebeurd.
Error: (07/19/2017 11:18:10 PM) (Source: Service Control Manager) (User: )
Description: Time-out (30000 seconden) tijdens het wachten op een reactie op een transactie van deze service: iphlpsvc.
Error: (07/19/2017 06:46:44 PM) (Source: Service Control Manager) (User: )
Description: De Bluetooth Device Monitor-service is onverwacht beëindigd. Dit is nu 1 keer gebeurd.
Error: (07/19/2017 06:42:56 PM) (Source: DCOM) (User: NT AUTHORITY)
Description: {DDCFD26B-FEED-44CD-B71D-79487D2E5E5A}
Error: (07/19/2017 06:16:31 PM) (Source: Service Control Manager) (User: )
Error: (07/19/2017 06:16:29 PM) (Source: Service Control Manager) (User: )
Description: De Bluetooth OBEX Service-service is onverwacht beëindigd. Dit is nu 1 keer gebeurd.
Error: (07/19/2017 05:16:05 PM) (Source: Microsoft-Windows-Eventlog) (User: NT AUTHORITY)
Description: Er is een fout (5) in de service opgetreden tijdens het inschakelen van uitgever {0BF2FB94-7B60-4B4D-9766-E82F658DF540} op kanaal Microsoft-Windows-Kernel-ShimEngine/Operational. Dit heeft geen invloed op de werking van het kanaal, maar het heeft invloed op de mogelijkheid van de uitgever om gebeurtenissen op het kanaal te plaatsen. Een veelvoorkomende reden voor deze fout is dat de provider de ETW Provider Security gebruikt en deze heeft geen machtigingen gegeven voor de Event Log-service-identiteit.
Error: (07/19/2017 05:16:00 PM) (Source: Microsoft-Windows-Eventlog) (User: NT AUTHORITY)
Error: (07/19/2017 05:14:36 PM) (Source: Service Control Manager) (User: )
Description: De Intel(R) PROSet/Wireless Zero Configuration Service-service is onverwacht beëindigd. Dit is nu 1 keer gebeurd.
Error: (07/19/2017 05:10:09 PM) (Source: Service Control Manager) (User: )
Description: De Superfetch-service is gestopt met de volgende foutcode:
%%1062 = De service is niet gestart.
Microsoft Office Sessions:
Error: (07/20/2017 02:13:13 PM) (Source: SideBySide)(User: )
Description: c:\Program Files\WinZip\adxloader.dll.Manifestc:\Program Files\WinZip\adxloader.dll.Manifest2
Error: (07/19/2017 08:57:37 PM) (Source: Microsoft-Windows-WMI)(User: NT AUTHORITY)
Description: //./ROOT/defaultselect * from CIntelWLANEvent0x80041010
Error: (07/19/2017 06:11:24 PM) (Source: Perflib)(User: )
Error: (07/19/2017 05:14:12 PM) (Source: Application Error)(User: )
Description: ZeroConfigService.exe17.0.5.05387ee07MurocApi.dll17.0.5.05387ed02c0000005000000000002bd489bc01d300aa00202f3eC:\Program Files\Intel\WiFi\bin\ZeroConfigService.exeC:\Program Files\Intel\WiFi\bin\MurocApi.dll4cecafbd-6c9d-11e7-8269-d07e35f04d52
Error: (07/19/2017 05:09:42 PM) (Source: Windows Search Service)(User: )
Description:
Details:
Error: (07/18/2017 02:59:22 PM) (Source: VSS)(User: )
Description: 0x80070005, Toegang geweigerd.
Bewerking:
Context:
Error: (07/18/2017 02:46:55 PM) (Source: VSS)(User: )
Bewerking:
Context:
Error: (07/17/2017 09:19:16 PM) (Source: Application Error)(User: )
Description: RzSDKServer.exe1.0.5.05948ebb8i-ms-win-crt-runtime-l1-1-0.dll6.3.9600.1727853eeb4a3c000013500098f0511a401d2ff39f6902b66C:\Program Files (x86)\Razer Chroma SDK\bin\RzSDKServer.exei-ms-win-crt-runtime-l1-1-0.dll34425867-6b2d-11e7-8263-d07e35f04d52
Error: (07/17/2017 09:19:14 PM) (Source: Application Error)(User: )
Description: RzSDKServer.exe1.0.5.05948ebb8i-ms-win-crt-runtime-l1-1-0.dll6.3.9600.1727853eeb4a3c000013500098f05ecc01d2ff39f5b82f5cC:\Program Files (x86)\Razer Chroma SDK\bin\RzSDKServer.exei-ms-win-crt-runtime-l1-1-0.dll33699201-6b2d-11e7-8263-d07e35f04d52
Error: (07/17/2017 09:19:13 PM) (Source: Application Error)(User: )
Description: RzSDKService.exe2.0.3.15948eaf8i-ms-win-crt-runtime-l1-1-0.dll6.3.9600.1727853eeb4a3c000013500098f0555c01d2ff39f4e10b18C:\Program Files (x86)\Razer Chroma SDK\bin\RzSDKService.exei-ms-win-crt-runtime-l1-1-0.dll328e6c01-6b2d-11e7-8263-d07e35f04d52
„Windows Live Essentials“ (HKLM-x32\...\{0821D14F-A0CF-470D-88ED-E255B4535D34}) (Version: 16.4.3528.0331 - Microsoft Corporation) Hidden
Ansel (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Ansel) (Version: 384.76 - NVIDIA Corporation) Hidden
Battery Calibration (HKLM-x32\...\{619FA785-489B-4D22-911F-82D6EDF5BDB0}) (Version: 1.0.1405.0701 - Micro-Star International Co., Ltd.)
Boot Configure (HKLM-x32\...\{5563D674-6B02-43F4-B9D0-C2A944E84F3C}) (Version: 20.014.12127 - Micro-Star International Co., Ltd.)
BurnRecovery (HKLM-x32\...\{2892E1B7-E24D-4CCB-B8A7-B63D4B66F89F}) (Version: 4.0.1412.2301 - )
Counter-Strike: Global Offensive (HKLM\...\Steam App 730) (Version: - Valve)
CyberLink PowerDVD 10 (HKLM-x32\...\InstallShield_{DEC235ED-58A4-4517-A278-C41E8DAEAB3B}) (Version: 10.0.5509.52 - CyberLink Corp.)
D3DX10 (HKLM-x32\...\{E09C4DB7-630C-4F06-A631-8EA7239923AF}) (Version: 15.4.2368.0902 - Microsoft) Hidden
DayZ (HKLM\...\Steam App 221100) (Version: - Bohemia Interactive)
Dragon Gaming Center (HKLM-x32\...\{965B16C7-0778-4C45-B7D1-83A59E6FBBCB}) (Version: 1.0.1410.1301 - Micro-Star International Co., Ltd.) Hidden
Dragon Gaming Center (HKLM-x32\...\InstallShield_{965B16C7-0778-4C45-B7D1-83A59E6FBBCB}) (Version: 1.0.1410.1301 - Micro-Star International Co., Ltd.)
ELAN Touchpad 11.13.11.4_X64_WHQL (HKLM\...\Elantech) (Version: 11.13.11.4 - ELAN Microelectronic Corp.)
Fotoattēlu galerija (HKLM-x32\...\{FFF8279A-9FFE-4A3B-A7CD-14143B3D67AC}) (Version: 16.4.3528.0331 - Microsoft Corporation) Hidden
Fotogaléria (HKLM-x32\...\{5B87607E-E781-49C5-9891-80990E45BCA1}) (Version: 16.4.3528.0331 - Microsoft Corporation) Hidden
Fotogalerie (HKLM-x32\...\{41BF4A3B-D60A-4E92-883F-C88C8C157261}) (Version: 16.4.3528.0331 - Microsoft Corporation) Hidden
Fotogalerie (HKLM-x32\...\{F37D360D-9308-4BB1-8515-DC6B637B9486}) (Version: 16.4.3528.0331 - Microsoft Corporation) Hidden
Fotogalerii (HKLM-x32\...\{3F597A24-BC7C-49AC-B96A-F30934C1AC3F}) (Version: 16.4.3528.0331 - Microsoft Corporation) Hidden
Foto-galerija (HKLM-x32\...\{4A45C9C7-5EB4-4C25-A0CB-8AD08D642F0A}) (Version: 16.4.3528.0331 - Microsoft Corporation) Hidden
Fotogalerija (HKLM-x32\...\{5D5B5672-1A0F-4412-B6A0-3A16706DE82D}) (Version: 16.4.3528.0331 - Microsoft Corporation) Hidden
Fotogalerija (HKLM-x32\...\{78D9B622-3BB0-4A44-B7BF-3FECCA0CC63D}) (Version: 16.4.3528.0331 - Microsoft Corporation) Hidden
Fotogalleri (HKLM-x32\...\{85E3592A-8C11-44F4-AABD-F82EF41167AD}) (Version: 16.4.3528.0331 - Microsoft Corporation) Hidden
Fotogalleriet (HKLM-x32\...\{5FF3045E-4A36-4B98-9F7F-48B49F4469C7}) (Version: 16.4.3528.0331 - Microsoft Corporation) Hidden
Fotoğraf Galerisi (HKLM-x32\...\{B743ABDD-E681-4B32-A33E-6E7F3F845AEA}) (Version: 16.4.3528.0331 - Microsoft Corporation) Hidden
Fotótár (HKLM-x32\...\{6F19A9AE-85C6-4EBB-BADC-CC1B8B9F3F91}) (Version: 16.4.3528.0331 - Microsoft Corporation) Hidden
Galeria de Fotografias (HKLM-x32\...\{23079EF2-2617-4BFC-BDFF-E6AE8D79B734}) (Version: 16.4.3528.0331 - Microsoft Corporation) Hidden
Galería de fotos (HKLM-x32\...\{198CEF22-A27F-4DC7-9B66-2C22A4B1CA09}) (Version: 16.4.3528.0331 - Microsoft Corporation) Hidden
Galeria de Fotos (HKLM-x32\...\{9EE1AE8B-4872-41CA-8C9A-C33D899523E0}) (Version: 16.4.3528.0331 - Microsoft Corporation) Hidden
Galeria fotografii (HKLM-x32\...\{77655DF6-A143-4A25-A5F8-127C8CE63EDA}) (Version: 16.4.3528.0331 - Microsoft Corporation) Hidden
Galerie de photos (HKLM-x32\...\{439B34FF-F74E-4807-B5E2-4B758551DA6B}) (Version: 16.4.3528.0331 - Microsoft Corporation) Hidden
Galerie foto (HKLM-x32\...\{429BEB2D-4EB8-49E6-A135-823FCB2AAAC5}) (Version: 16.4.3528.0331 - Microsoft Corporation) Hidden
Galerija fotografija (HKLM-x32\...\{343C0612-37DC-4914-95A7-0845EE0C8F04}) (Version: 16.4.3528.0331 - Microsoft Corporation) Hidden
Google Chrome (HKLM-x32\...\Google Chrome) (Version: 59.0.3071.115 - Google Inc.)
Google Update Helper (HKLM-x32\...\{60EC980A-BDA2-4CB6-A427-B07A5498B4CA}) (Version: 1.3.33.5 - Google Inc.) Hidden
Google Update Helper (HKLM-x32\...\{A92DAB39-4E2C-4304-9AB6-BC44E68B55E2}) (Version: 1.3.21.115 - Google Inc.) Hidden
Intel(R) Management Engine Components (HKLM-x32\...\{65153EA5-8B6E-43B6-857B-C6E4FC25798A}) (Version: 9.5.15.1730 - Intel Corporation)
Intel(R) Processor Graphics (HKLM-x32\...\{F0E3AD40-2BBD-4360-9C76-B9AC9A5886EA}) (Version: 10.18.14.4264 - Intel Corporation)
Intel(R) Rapid Storage Technology (HKLM\...\{409CB30E-E457-4008-9B1A-ED1B9EA21140}) (Version: 13.5.0.1056 - Intel Corporation)
Intel(R) Wireless Bluetooth(R)(patch version 17.1.1440.2) (HKLM\...\{302600C1-6BDF-4FD1-1409-148929CC1385}) (Version: 17.1.1409.0486 - Intel Corporation)
Intel® PROSet/Wireless Software (HKLM-x32\...\{66614300-cd9b-4a62-8b18-c97e9562dc3e}) (Version: 19.50.0 - Intel Corporation)
KB9X Radio Switch Driver (HKLM\...\5AADE1068CF70DD983F763B20CF2CAAB72883915) (Version: 1.1.0.0 - ENE TECHNOLOGY INC.)
MAGIX MX Suite (HKLM\...\{43136332-880B-458A-966C-900C18752B66}) (Version: 1.13.0.121 - MAGIX AG) Hidden
MAGIX MX Suite (HKLM-x32\...\MAGIX_{43136332-880B-458A-966C-900C18752B66}) (Version: 1.13.0.121 - MAGIX AG)
Microsoft ASP.NET MVC 4 Runtime (HKLM-x32\...\{3FE312D5-B862-40CE-8E4E-A6D8ABF62736}) (Version: 4.0.40804.0 - Microsoft Corporation)
Microsoft Office (HKLM-x32\...\{90150000-0138-0409-0000-0000000FF1CE}) (Version: 15.0.4641.1005 - Microsoft Corporation)
Microsoft Silverlight (HKLM\...\{89F4137D-6C26-4A84-BDB8-2E5A4BB71E00}) (Version: 5.1.50907.0 - Microsoft Corporation)
Microsoft SQL Server 2005 Compact Edition [ENU] (HKLM-x32\...\{F0B430D1-B6AA-473D-9B06-AA3DD01FD0B8}) (Version: 3.1.0000 - Microsoft Corporation)
Microsoft Visual C++ 2015 Redistributable (x64) - 14.0.24215 (HKLM-x32\...\{d992c12e-cab2-426f-bde3-fb8c53950b0d}) (Version: 14.0.24215.1 - Microsoft Corporation)
Microsoft Visual C++ 2015 Redistributable (x86) - 14.0.24215 (HKLM-x32\...\{e2803110-78b3-4664-a479-3611a381656a}) (Version: 14.0.24215.1 - Microsoft Corporation)
Movie Maker (HKLM-x32\...\{0A0C9DBA-5AB2-43F1-9932-A60DAA6EBEFC}) (Version: 16.4.3528.0331 - Microsoft Corporation) Hidden
Movie Maker (HKLM-x32\...\{0CD05078-D4F3-4006-8726-B01E10A89B28}) (Version: 16.4.3528.0331 - Microsoft Corporation) Hidden
Movie Maker (HKLM-x32\...\{178984AA-ABE7-4DD1-934B-E2BB45DD7B88}) (Version: 16.4.3528.0331 - Microsoft Corporation) Hidden
Movie Maker (HKLM-x32\...\{1FA9CD0B-A51B-405F-9F25-D83D36F89404}) (Version: 16.4.3528.0331 - Microsoft Corporation) Hidden
Movie Maker (HKLM-x32\...\{21764A96-6748-4B83-89E7-7A5063BF156C}) (Version: 16.4.3528.0331 - Microsoft Corporation) Hidden
Movie Maker (HKLM-x32\...\{26E474C7-E63A-4EC2-A08C-909B996AA75D}) (Version: 16.4.3528.0331 - Microsoft Corporation) Hidden
Movie Maker (HKLM-x32\...\{312F7EE7-37D0-484D-B974-0CE1B8560C79}) (Version: 16.4.3528.0331 - Microsoft Corporation) Hidden
Movie Maker (HKLM-x32\...\{3777096E-85F8-426B-A4C7-0935B22D3F99}) (Version: 16.4.3528.0331 - Microsoft Corporation) Hidden
Movie Maker (HKLM-x32\...\{38F03569-A636-4CF3-BDDE-032C8C251304}) (Version: 16.4.3528.0331 - Microsoft Corporation) Hidden
Movie Maker (HKLM-x32\...\{3B5AAF87-531E-4163-BE79-8989FC249173}) (Version: 16.4.3528.0331 - Microsoft Corporation) Hidden
Movie Maker (HKLM-x32\...\{3D2CF65C-B544-4308-B996-700D3E5F6C4C}) (Version: 16.4.3528.0331 - Microsoft Corporation) Hidden
Movie Maker (HKLM-x32\...\{57430A7B-EB42-41ED-88F8-ACB2DEDB8416}) (Version: 16.4.3528.0331 - Microsoft Corporation) Hidden
Movie Maker (HKLM-x32\...\{5B3D4718-9146-45CB-8989-C4E87B239B3A}) (Version: 16.4.3528.0331 - Microsoft Corporation) Hidden
Movie Maker (HKLM-x32\...\{5D3B997B-DF28-4BC1-82E6-E6C29A53AF6E}) (Version: 16.4.3528.0331 - Microsoft Corporation) Hidden
Movie Maker (HKLM-x32\...\{70C91B91-61E8-4D06-86D6-A9DCC291983A}) (Version: 16.4.3528.0331 - Microsoft Corporation) Hidden
Movie Maker (HKLM-x32\...\{97B23646-3F2F-4E3F-AE0A-763BA2ECB8A2}) (Version: 16.4.3528.0331 - Microsoft Corporation) Hidden
Movie Maker (HKLM-x32\...\{9C82436F-F19C-42A4-B476-F87A28A95BF9}) (Version: 16.4.3528.0331 - Microsoft Corporation) Hidden
Movie Maker (HKLM-x32\...\{A27180D0-17BB-498B-89FF-A72656B85978}) (Version: 16.4.3528.0331 - Microsoft Corporation) Hidden
Movie Maker (HKLM-x32\...\{AC20CAEC-CC13-4877-A7DC-30BC97936645}) (Version: 16.4.3528.0331 - Microsoft Corporation) Hidden
Movie Maker (HKLM-x32\...\{B44E699A-94F8-406C-9A1B-C2574F5863CB}) (Version: 16.4.3528.0331 - Microsoft Corporation) Hidden
Movie Maker (HKLM-x32\...\{B653D7B1-41B5-4982-9A25-E91FF46D131A}) (Version: 16.4.3528.0331 - Microsoft Corporation) Hidden
Movie Maker (HKLM-x32\...\{C05F4139-CB6B-4272-A0BF-861FEB667F27}) (Version: 16.4.3528.0331 - Microsoft Corporation) Hidden
Movie Maker (HKLM-x32\...\{DAE8CC57-EBF5-4D46-8572-9A0C769D6F16}) (Version: 16.4.3528.0331 - Microsoft Corporation) Hidden
Movie Maker (HKLM-x32\...\{DC5E5027-65E8-41CB-815C-9AAB48BFB8E2}) (Version: 16.4.3528.0331 - Microsoft Corporation) Hidden
Movie Maker (HKLM-x32\...\{DD3880DF-4CA8-4523-A354-7F8F5A4EB3DC}) (Version: 16.4.3528.0331 - Microsoft Corporation) Hidden
Movie Maker (HKLM-x32\...\{DD67BE4B-7E62-4215-AFA3-F123A800A389}) (Version: 16.4.3528.0331 - Microsoft Corporation) Hidden
Movie Maker (HKLM-x32\...\{E668DD34-04FA-4A11-B07A-8CBA2119401B}) (Version: 16.4.3528.0331 - Microsoft Corporation) Hidden
Movie Maker (HKLM-x32\...\{F215DDB5-BE2A-4453-BABF-8790434F65D0}) (Version: 16.4.3528.0331 - Microsoft Corporation) Hidden
Movie Maker (HKLM-x32\...\{F78F19A8-F3F5-4407-B98B-F23ACC82DBF5}) (Version: 16.4.3528.0331 - Microsoft Corporation) Hidden
Movie Maker (HKLM-x32\...\{FDF7A21E-3AEF-46AB-AC22-2BDFF8C9B553}) (Version: 16.4.3528.0331 - Microsoft Corporation) Hidden
MSI Social Media Collection (HKLM-x32\...\{7ADEC426-BE95-48EF-84D4-086BD0F4D331}) (Version: 1.14.2251 - Micro-Star International Co., Ltd.)
Norton Online Backup (HKLM-x32\...\NARA) (Version: 4.5.0.9 - Symantec Corporation) Hidden
NVIDIA GeForce Experience 3.7.0.81 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.GFExperience) (Version: 3.7.0.81 - NVIDIA Corporation)
NVIDIA Grafisch stuurprogramma 384.76 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.Driver) (Version: 384.76 - NVIDIA Corporation)
NVIDIA PhysX Systeem Software 9.17.0524 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.PhysX) (Version: 9.17.0524 - NVIDIA Corporation)
NvNodejs (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_NvNodejs) (Version: 3.7.0.81 - NVIDIA Corporation) Hidden
NvTelemetry (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_NvTelemetry) (Version: 2.6.1.0 - NVIDIA Corporation) Hidden
NvvHci (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_NvvHci) (Version: 2.02.0.5 - NVIDIA Corporation) Hidden
PLAYERUNKNOWN'S BATTLEGROUNDS (HKLM\...\Steam App 578080) (Version: - Bluehole, Inc.)
Podstawowe programy Windows Live (HKLM-x32\...\{8FFD72FC-4FFA-472D-9F76-AEC85F602F9D}) (Version: 16.4.3528.0331 - Microsoft Corporation) Hidden
Qualcomm Atheros Bandwidth Control Filter Driver (HKLM\...\{C045E405-9FD0-4084-9019-41413BEF8A23}) (Version: 1.1.46.1056 - Qualcomm Atheros) Hidden
Qualcomm Atheros Killer E220x Drivers (HKLM\...\{5C4E9278-8F9F-481E-B7A4-38D576DA47FC}) (Version: 1.1.46.1056 - Qualcomm Atheros) Hidden
Qualcomm Atheros Killer Performance Suite (HKLM-x32\...\{E70DB50B-10B4-46BC-9DE2-AB8B49E061EE}) (Version: 1.1.46.1056 - Qualcomm Atheros)
Qualcomm Atheros Network Manager (HKLM\...\{5B62C353-75A3-463F-A52E-CC005846F3CE}) (Version: 1.1.46.1056 - Qualcomm Atheros) Hidden
Raccolta foto (HKLM-x32\...\{86A1CEAD-EF47-47BB-AE79-DA8C09E15382}) (Version: 16.4.3528.0331 - Microsoft Corporation) Hidden
Razer Chroma SDK Core Components (HKLM-x32\...\Razer Chroma SDK) (Version: 2.3.6 - Razer Inc.)
Razer Synapse (HKLM-x32\...\{0D78BEE2-F8FF-4498-AF1A-3FF81CED8AC6}) (Version: 2.20.17.413 - Razer Inc.)
Realtek Card Reader (HKLM-x32\...\{5BC2B5AB-80DE-4E83-B8CF-426902051D0A}) (Version: 6.3.9600.21249 - Realtek Semiconductor Corp.)
Realtek High Definition Audio Driver (HKLM-x32\...\{F132AF7F-7BCA-4EDE-8A7C-958108FE7DBC}) (Version: 6.0.1.7179 - Realtek Semiconductor Corp.)
SCM (HKLM\...\{9BC0C4F3-ACBB-42DF-9559-93175E3B4095}) (Version: 13.014.11068 - Application)
SHIELD Streaming (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_GFExperience.NvStreamSrv) (Version: 7.1.0380 - NVIDIA Corporation) Hidden
Sizing Options (HKLM-x32\...\{DFAB6DE8-E45F-4D5D-95C0-E54C58993F9F}) (Version: 2.0.1412.1501 - Application) Hidden
Sizing Options (HKLM-x32\...\InstallShield_{DFAB6DE8-E45F-4D5D-95C0-E54C58993F9F}) (Version: 2.0.1412.1501 - Application)
Sound Blaster Cinema (HKLM-x32\...\{8801CA65-921A-4CCC-9D63-879D1D0BAA97}) (Version: 1.00.05 - Creative Technology Limited)
SUPER CHARGER (HKLM-x32\...\{7CDF10DD-A9B5-4DA3-AB95-E193248D4369}_is1) (Version: 1.2.024 - MSI)
Valokuvavalikoima (HKLM-x32\...\{B315ABA6-8217-484E-9AC5-38806E265664}) (Version: 16.4.3528.0331 - Microsoft Corporation) Hidden
Vulkan Run Time Libraries 1.0.42.1 (HKLM\...\VulkanRT1.0.42.1) (Version: 1.0.42.1 - LunarG, Inc.)
Windows Live Essentials (HKLM-x32\...\WinLiveSuite) (Version: 16.4.3528.0331 - Microsoft Corporation)
WinZip 17.5 (HKLM\...\{CD95F661-A5C4-44F5-A6AA-ECDD91C240DD}) (Version: 17.5.10562 - WinZip Computing, S.L. )
Συλλογή φωτογραφιών (HKLM-x32\...\{2D5C287A-1D2D-46BA-8EF8-D2747575DB6E}) (Version: 16.4.3528.0331 - Microsoft Corporation) Hidden
Основи Windows Live (HKLM-x32\...\{F8B795A7-CF9A-4B32-8E77-2E9D74A6900F}) (Version: 16.4.3528.0331 - Microsoft Corporation) Hidden
Основные компоненты Windows Live (HKLM-x32\...\{D177E45E-2BA3-42C1-8570-CCA2217B958C}) (Version: 16.4.3528.0331 - Microsoft Corporation) Hidden
Фотоальбом (HKLM-x32\...\{B27EB36C-9860-42FD-AA90-23648E49F15C}) (Version: 16.4.3528.0331 - Microsoft Corporation) Hidden
Фотогалерия (HKLM-x32\...\{3AAB928E-40E9-4DC5-A9CC-FB979E1B2C03}) (Version: 16.4.3528.0331 - Microsoft Corporation) Hidden
Фотографии (общедоступная версия) (HKLM-x32\...\{7D6C9057-7F50-4CAB-A557-A68A7932B48E}) (Version: 16.4.3528.0331 - Microsoft Corporation) Hidden
Фотоколекція (HKLM-x32\...\{3DB06CA5-1CB0-4A0C-8814-7F04B9969809}) (Version: 16.4.3528.0331 - Microsoft Corporation) Hidden
גלריית התמונות (HKLM-x32\...\{F1BEEA80-1419-45EE-A4C7-41FD4450ED92}) (Version: 16.4.3528.0331 - Microsoft Corporation) Hidden
Percentage of memory in use: 44%
Total physical RAM: 8109.38 MB
Available physical RAM: 4499.61 MB
Total Virtual: 10029.38 MB
Available Virtual: 6567.06 MB
1 Drive c: (OS_Install) (Fixed) (Total:558.91 GB) (Free:449.92 GB) NTFS
2 Drive d: (Data) (Fixed) (Total:351.37 GB) (Free:351.24 GB) NTFS
Gebruikersaccounts voor \\MSI
Administrator Gast Ruben
De opdracht is voltooid.
No minidump file found
**** End of log ****
