:OTL
FF - prefs.js..extensions.enabledAddons: %7B972ce4c6-7e08-4474-a285-3208198ce6fd%7D:50.1.0
FF - prefs.js..keyword.URL: "http://www.bing.com/search?FORM=UP97DF&PC=UP97&q="
FF - user.js - File not found
FF:[b]64bit:[/b] - HKLM\Software\MozillaPlugins\@adobe.com/FlashPlayer: C:\Windows\system32\Macromed\Flash\NPSWF64_22_0_0_192.dll File not found
FF - HKLM\Software\MozillaPlugins\@google.com/npPicasa3,version=3.0.0: C:\Program Files (x86)\Google\Picasa3\npPicasa3.dll File not found
FF - HKLM\Software\MozillaPlugins\@tools.google.com/Google Update;version=3: C:\Program Files (x86)\Google\Update\1.3.33.7\npGoogleUpdate3.dll File not found
FF - HKLM\Software\MozillaPlugins\@tools.google.com/Google Update;version=9: C:\Program Files (x86)\Google\Update\1.3.33.7\npGoogleUpdate3.dll File not found
O2:[b]64bit:[/b] - BHO: (Google Toolbar Helper) - {AA58ED58-01DD-4d91-8333-CF10577473F7} - C:\Program Files (x86)\Google\Google Toolbar\GoogleToolbar_64.dll File not found
O2 - BHO: (Google Toolbar Helper) - {AA58ED58-01DD-4d91-8333-CF10577473F7} - C:\Program Files (x86)\Google\Google Toolbar\GoogleToolbar_32.dll File not found
O3:[b]64bit:[/b] - HKLM\..\Toolbar: (Google Toolbar) - {2318C2B1-4965-11d4-9B18-009027A5CD4F} - C:\Program Files (x86)\Google\Google Toolbar\GoogleToolbar_64.dll File not found
O3 - HKLM\..\Toolbar: (Google Toolbar) - {2318C2B1-4965-11d4-9B18-009027A5CD4F} - C:\Program Files (x86)\Google\Google Toolbar\GoogleToolbar_32.dll File not found
O4 - HKU\S-1-5-19..\Run: [Sidebar] %ProgramFiles%\Windows Sidebar\Sidebar.exe /autoRun File not found
O4 - HKU\S-1-5-20..\Run: [Sidebar] %ProgramFiles%\Windows Sidebar\Sidebar.exe /autoRun File not found
O4 - HKU\S-1-5-21-4071099201-3717120772-1477128104-1001..\Run: [Sidebar] %ProgramFiles%\Windows Sidebar\Sidebar.exe /autoRun File not found
O4 - Startup: C:\Users\Yvan\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\OneNote 2010 Schermopname en Snel starten.lnk = File not found
O8:[b]64bit:[/b] - Extra context menu item: Add to Google Photos Screensa&ver - res://C:\Windows\system32\GPhotos.scr/200 File not found
O18:[b]64bit:[/b] - Protocol\Handler\livecall - No CLSID value found
O18:[b]64bit:[/b] - Protocol\Handler\msnim - No CLSID value found
O18:[b]64bit:[/b] - Protocol\Handler\skype4com - No CLSID value found
O18:[b]64bit:[/b] - Protocol\Handler\wlmailhtml - No CLSID value found
O18 - Protocol\Handler\ms-help - No CLSID value found
O21:[b]64bit:[/b] - SSODL: WebCheck - {E6FB5E20-DE35-11CF-9C87-00AA005127ED} - No CLSID value found.
O21 - SSODL: WebCheck - {E6FB5E20-DE35-11CF-9C87-00AA005127ED} - No CLSID value found.
O30:[b]64bit:[/b] - LSA: Security Packages - (livessp) - File not found
O30 - LSA: Security Packages - (livessp) - File not found
[2012/12/01 15:20:38 | 000,000,902 | ---- | C] () -- C:\WINDOWS\Tasks\FacebookUpdateTaskUserS-1-5-21-4071099201-3717120772-1477128104-1001Core.job
[2012/12/01 15:20:39 | 000,000,924 | ---- | C] () -- C:\WINDOWS\Tasks\FacebookUpdateTaskUserS-1-5-21-4071099201-3717120772-1477128104-1001UA.job
@Alternate Data Stream - 141 bytes -> C:\ProgramData\TEMP:73B1147D
@Alternate Data Stream - 135 bytes -> C:\ProgramData\TEMP:9BAC4211
@Alternate Data Stream - 132 bytes -> C:\ProgramData\TEMP:6ED8B881
:Services
:Reg
:Files
ipconfig /flushdns /c
:Commands
[purity]
[emptytemp]
[emptyjava]
[emptyflash]
[createrestorepoint]
[reboot]
